Question about Radio Shack Pro-95 Handheld Scanner
Pro 95 dual trunk tracking scanner just stays on channel 3 does not scan up to the other 10 channels
  • 512 Answers
The manual at "http://support.radioshack.com/manuals/ome20-525.pdf" (if you don't have it)
says that you may be in manual mode OR that the channel at 3 might be a "trunk guide", that means that the channel is used to send out digital permissions to the system for each radio in the unit(s) to use a certain freq. when they transmit. good luck!
Posted on Mar 09, 2009
I have a pro 95 dual trunk scanner & it says all
  • Hi, I can help.
  • You probably have all frequencies in that bank locked out and all other banks locket out as well so you are seeing "All Ranges Locked Out."
  • You should be able to just push the number of the bank you want to have active again and activate it. If you have locked out some frequencies just press "MAN" for manual and scroll up and down through all the frequencies and hit "L/O" and the L/O will change to l/o (lower case letters) indicating the frequency is no longer locked. This has to be done manually for every frequency as there is no "master unlock" function on this scanner.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Aug 27, 2011 | Radio Shack Pro-95 Handheld Scanner
Cannot recieve new Motorla trunking Feq after system upgrade on my Pro 95 scanner. What can I do?? Thanks, Ron
Hi.
They probably went into a digital trunking system. Your Pro-95 will only handle Edacs, Type I and II standard trunking.
Or they changed the trunking voice frequencies and the data (control channel) frequency.
Which system are you trying to listen to? Which city area ??
Feb 09, 2011 | Radio Shack Pro-95 Handheld Scanner
Manual for a radio shack scanner 300 channel aao2000523
This might help.
http://support.radioshack.com/support_electronics/doc66/66173.pdf
Direct link to the .pdf file for the manual to the :
PRO-93
300 Channel Dual Track-Trunking
Handheld Scanner
Believe this is the one you are referring to. AAO2000523 at least points to this one.
Aug 21, 2010 | Televison & Video
WHAT CHANNELS CAN YOU USE IF YOU HAVE A POLICE SCANNER 53218
Your PRO-96 has 10 banks of 50 channels, giving you access to 500 channels for conventional systems. It also has 11 banks of 500 channels, giving you access to 5500 users on trunked systems. Detailed instructions for programming the scanner are contained in the factory operating instructions, which you can download and print at no cost here:
http://scancat.com/OnLineHelp/OEM_Radio_Owners_Manuals/RadioShack-OlderManuals/Pro-96/pro96.pdf
For a comprehensive database of active frequencies and trunking systems in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B
Aug 04, 2010 | Radio Shack Pro-96 Scanner
How do I program it for triple truncking?
There is no such thing as "dual trunking" or "triple trunking." Such terms are used by manufacturers to indicate the number of trunking systems that a scanner is capable of monitoring. The PRO-95 is designated as a Dual Trunk-Tracking scanner because it is capable of monitoring both Motorola and EDACS systems. Programming a trunking system in to a scanner is a detailed process that requires a bit of research.
For details on active trunking systems in your area, and a lot of other useful scanning information, visit:
Once you have the system information you can follow the programming steps outlined in your scanner's operating instructions. If you don't already have the manual, you can download and print it here:
http://scancat.com/OnLineHelp/OEM_Radio_Owners_Manuals/RadioShack-OlderManuals/Pro-95/pro95.pdf
Bill B
Jul 24, 2010 | Radio Shack Pro-95 Handheld Scanner
TUNING
no there are no adjustments, you need to check to make sure tha tthe pro-95 you have is compatible with the trunking system in your area, i have the same problem with my pro-97 problem is just the codec that they use is too new for one of my scanners and the only way to listen in is to have the radio scan all output channels that arent control channels or transmitting all time
Mar 08, 2010 | Radio Shack Pro-95 Handheld Scanner
I am trying to program my Uniden BCT8 to track LTR systems but having problems.
LTR systems must be entered in a specific order so that channel 1 is 1st, channel 2 is 2nd etc...
Are you sure that the BCT8 tracks LTR systems? A Radio Shack PRO 92 tracks all 3 trunking systems (analog) including Motorola and LTR, while some Uniden only track 1, and some don't do trunking systems at all.
Dec 27, 2009 | Uniden BCT8 Base Scanner
Radio Shack Pro-95 handheld scanner issues
Here is the online programming tutorial:
http://support.radioshack.com/support_tutorials/communications/200-0523/67345.htm
Here is the full manual Should include Quick guide:
Here is FREE programming software for the PC:
Includes hardware info. You can buy programming cable at Radio Shack to connect to your PC.
http://www.starrsoft.com/freeware/win95/default.asp
Jan 02, 2008 | Radio Shack Pro-95 Handheld Scanner
Pro-95 dual-trunk scanner
Aug 01, 2007 | Radio Shack Pro-95 Handheld Scanner
Radio Shack Pro-95 Handheld Scanner Logo
155 people viewed this question
Top Radio Shack Radio Communications Experts
Iron
Iron
Robert McClure
John
John
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
