I did a full tune up on my car (2000 accent 1.5) im getting codes p0300 random misfire.....p0301misfire cylinder 1..... p0302 misfire cylinder 2
since i already change sparkplugs,wires, fuel filter, airfilter,pcv valve, im thinking it could be the ignition coils going bad but im not sure...can somebody please help
is it possible for plugs to be wrong ones or is it possible the coils can be goingv bad and car still startsis it possible for plugs to be wrong ones or is it possible the coils can be goingv bad and car still starts
You can't post conmments that contain an email address.
Codes p0300 random misfire, p0302-0304 misfire cylinder 2-4. P0133 o2 circuit slow response bank 1 sensor 1. P1176, P1300, P1580, P1543, B0423 r make specific which you didn't say this would cause the problems you are having.
A misfire can be caused by a few things. The most common causes are usually spark supply or fuel supply. Get BOTH of these checked.
All the misfires are on the same side of the engine so I would suspect a fuel rail or an injector issue on that side of the engine.
that particular vehicle has a distributor-less ignition system. completely stand alone and electronic. change around the known good coils and see if the misfires on the computer change. see, what the trouble codes say is your numbers 1 thru 4 cylinders are misfiring inadvertently. if you move the coils around, which there are 4..one to 2 cylinders and if its 4 bad coils giving problems then the codes will move around. it could be the crankshaft tone wheel or the PCM as well. take it to a good diagnostic facility like a hyundai facility if you want it fixed right the first time. the hyundai parts are a little more expensive but they are the BEST part for your car, OEM parts are the way to go and the mechanic has probably seen this before and can tell you whats wrong before you leave easily.
Im assuming your asking about the ODB-II codes, this code,P0300 Random/Multiple Cylinder Misfire Detected. A P0300 diagnostic code indicates a random or multiple misfire. If the last digit is a number other than zero, it corresponds to the cylinder number that is misfiring. A P0302 code, for example, would tell you cylinder number two is misfiring. Unfortunately, a P0300 doesn't tell you specifically which cylinder(s) is/are mis-firing, nor why. Here are a few things that could be the cause.
I would start things out with a tune up, new plugs and wires, wires break down after time and could be grounding out, or arcing between themselves causing a misfire.
You describe a 'Misfire' condition. You'll need and OBD!! scanner to retireve any throuble codes stored in the ECU (Engine Control Unit). Once you know which/what code (i.e., P0300 - Random Misfire Detected, or P0302 - Cylinder #2 misfire detected, etc). then you'll know where to go from there - plugs, wires, coil(s), etc.
