Question about Ovens
Have an alto shaam that wont stop heating up set at 225 degrees and goes up to 400 degrees new thremostat and temp probe installed no help everything else seems to be working ok any ideas? thanks confused
  • huntope Mar 04, 2009
    Thanks, hopefully this will help this is a commerical cook/hold oven we cook prime rib in all i know is that it is a 1000 model alto shaam all mechanical controls one for oven temp and a seperate control for hold temp also a mechanical timer other than that just a on and off switch thanks again confused
  • Dennis Boxerman May 11, 2010
    Is this a commercial oven? Are the temp controls electronic or mechanical. Your terminolgy indicates both. Please clear up and maybe I can get you started on what to do. Also, if there is a model and serial number, I might be able to get details of just what you have.
  • 183 Answers
SOURCE: Gas oven not heating to temp
The fault is either the capillary has fallen away from back or it is a faulty thermostat.
Posted on Nov 17, 2007
SOURCE: Kenmore 911.30464, 30465, 30469.....Wont ignite at all
there is a second ignitor for the oven unlatch bottom panel remove heat panel there is your burner and ignitor
Posted on Oct 06, 2008
  • 205 Answers
SOURCE: Kitchenaid KEMS308 display is saying
mam please check the heat temperature limit of the sensor and if its less than 300 degrees please change it then it will works.
Posted on Sep 07, 2009
SOURCE: kenmore model 790.9621 electric stove error code
it is the bake relay sticking--on the eletronic oven control board.i tried to buy the relays but,no luck.must buy the eoc board-great engineering
Posted on Aug 09, 2010
  • 24 Answers
SOURCE: e-21 is on the panrel
Try turning the power off and back on a minute or so later your clock may reset
Posted on May 29, 2011
I recently ran the self-clean option on my GE Profile JK955B0F5BB. Now when I set the touch pad to 350 degrees or more, the oven heats up to beyond 500.
That is not a valid model number, the issue is most likely the thermostat has failed. The part is about 12 dollars.
Jan 07, 2017 | GE Ovens
E-21 is on the panrel of our alto shaam, what do we do to clear it?
May 29, 2011 | Alto-Shaam (SHOALT610INMLS2082401)...
GE free-standing electric range Pre-heat oven temp is about 50 degrees less than what is set (i.e. set digital display to 400 and over only reaches about 350). Is there an adjustment that can be made to...
We have a new GE Range and the signal beeps at about 100 degrees below the temp which we have set . The dealer replaced the sensor and the control circuit, but there was no change.
A service tech from GE came to our house and explained that the new ovens have a bottom heating element which is covered and therefore heats the lower part of the oven more slowly; but the exposed upper element heats more rapidly and the sensor is located near the upper element. We were advised to wait for about 15-20 minutes after the beep before placing the food in the oven. Judging from the number of comments found online, this seems to be a feature of newer ranges.
Nov 08, 2010 | GE JKS05 Electric Single Oven
Superba convection oven probe display problem
I had a similar problem today with my KitchenAid Superba wall convection oven (2002 model). I was roasting tomatoes at 225 degrees F for 3 or 4 hours when the control pad changed and showed that the probe was in use (never have I used it and had to look for it). I, too, tried to plug in the probe and take it out, but nothing changed. My worry was that I could no longer use the timed bake function. After trying to reset by turning off the oven at the breaker, with no change, I turned on the oven to 400 F and left it on for 10 - 15 minutes hoping that the high temperature would dry out whatever moisture that must have gotten in the place where the probe connects. Then I turned it off and just waited. After a half hour or so the control pad cleared and nothing showed (that is what you want when the oven is off!). Everything is back to working now.
Sep 08, 2009 | KitchenAid KEBC107 Electric Single Oven
Elements do not heat to proper settings
If both elements are not working properly then the problem is either the temperature probe or the control board.
Replace the temp probe first.
May 21, 2009 | Frigidaire 30 in. Electric Gallery Series...
My oven reaches 350 then stops
Apr 28, 2009 | GE JTP20 Electric Single Oven
My Whirlpool oven no longer heats to the set temperature.
Temp probe/thermometer inside oven dirty, or off attachment, or defective. On some models, a small screw head adjustment is provided to calibrate thermometer under dial knob. Else, I would just set dial 50 degrees higher rather than expense of new thermometer or dial.
Mar 02, 2009 | Ovens
Problem again with the Vulcan GCO4C
i wasnt in on this from the begging but have you changed the safty valve on the burners and what code is er-5 havnt had no experence with vulcan but the regulater dont run the gas the safty valve does and have you checked the probe in the oven at 70 degrees it should be 1200 ohms
Jan 30, 2008 | Vulcan GCO2D Gas Single Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
