Question about Delta Saws
Need wiring diagram for king industrial table saw,
Need wiring diagram for magnetic switch for king industrial table saw, model number kc-11fx
rowdy45176
  • 2176 Answers
SOURCE: makita table saw switch wiring
K, from what I can remember there is nothing special about the switch, however the brake works off the armature and brushes and dirty or worn brushes will affect it. I just looked at a breakdown and there is no wiring schematic on it and I did not see any electronic module for the break. You can take the brushes out (unplug tool first) and blow the area out with compressed air. Look at the brush spring for discoloration and condition and length of brush. Makita does have a good website and also a toll free number for tech support. Their site is Makitatools.com and click on the table products and then type in your saw number. Let me know if you still have a problem and I will contact a local Makita center to get more info. Good luck
Posted on Jan 08, 2009
rockitman187
  • 2559 Answers
SOURCE: Hitachi c10fr table saw wiring diagram
Here is a hand drawn diagram
Please rate this a fixya
Posted on Feb 13, 2009
  • 12 Answers
SOURCE: on/off switch table saw
It sounds like you are wiring the switch wrong. Give me the model # and I will look for a wiring diagram for you.
Posted on Feb 25, 2009
  • 86 Answers
SOURCE: ryobi bt 3000 table saw belt installation diagram
The BT3000 actually has TWO v-belts! Here's a link at the end of this solution to an exploded diagram. Basically you have a major disassembly, but it really isnt that complicated.
More great info on the BT3000 is available from the web site http://bt3000.com/
I have a BT3100 saw, and it is a good tool, but does require attention in maintenance procedures, but Ryobi did outline the necessary steps in their manuals. The above website also has the owner manual if you need one.
  1. Unplug saw
  2. Remove the blade
  3. Lower mechanism all the way to the bottom
  4. Flip over saw and lay on it's top
  5. Remove the blade guard panel opposite the motor
  6. Unbolt the motor assembly and remove the belt cover
  7. Replace the broken belts
  8. Re-assemble (be careful not to cross-thread the bolts in the aluminum housings!)
http://bt3000.com/Manuals/BT3000-Parts-Manual.pdf
Posted on Mar 22, 2009
  • 4 Answers
SOURCE: wiring diagram for model 137.248830
SAME SAW I HAVE, I ASSUME YOU DONT HAVE THE ORIGINAL OWNERS MANUAL. GO TO SEARS.COM, AND TOWARDS THE TOP THERE IS A "PARTS" HEADER. CLICK ON IT AND ENTER MODEL NUMBER WHEN REQUESTED, THEY WILL ASK UP IF YOU ARE LOOKING FOR A SPECIFIC PART OR MANUAL . HOPE THIS HELPS
Posted on Apr 15, 2009
Model 36-979. Where can I get a wiring diagram for the power switch?
images for Delta Table Saws wiring diagram for power ...
Replacing a Table Saw Power Box and Switch. Rocket ...
? 7:45
https://www.youtube.com/watch?v=8A25b9BjkmY
Feb 12, 2014 - Uploaded by AdventuresInDIY
See how an in the way power box on a 10 inch Delta table sawwas switched out ... Would you happen to have a wiring diagramfor your saw.
Oct 28, 2015 | Delta Saws
My elu flip saw shorts out when I flip it over from a table saw to the chop saw, it works fine as a table saw
There is a bridge rectifier its a little black round piece in the box of the red green switch that must be replaced i see you have got a gray or bleu ELU not a dw 743 i know this problem that is what i know buy a new rectifier or place 4 diodes 1n4007 in a bridge if you know how to do this to make AC to DC its only for the magnet switch and connect the 4 wires to it .
May 28, 2014 | Dewalt Dw743n 240V 250Mm Combination Saw
Need wiring diagram for a Craftsman Table Saw Model 113.298050
Keep your model number handy and have a look around here. If you can't find the identical model, you may find one of similar vintage with a wiring diagram that will suit your needs.
Otherwise, you may have some luck at the sears support site, at www.managemyhome.com, though I have had poor results finding them there.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 05, 2010 | Craftsman 10" Table Saw
I have a delta ,model 33-055 needs oil maintenance
Go here for a selection of manuals and diagrams:
http://www.dewaltservicenet.com/Products/DocumentView.aspx?productid=43476&typeId=10320&documentId=40207
Unfortunately the manual is not available but anything identified as a bearing or a bushing in the parts diagrams could probably use a drop or two of machine oil (3-in-1). Unless the loud noise is a screech oiling may not reduce it.
Jul 09, 2009 | Saws
Wiring diagram for model 137.248830
Mar 24, 2009 | Craftsman 10" Table Saw
I need a wireing diagram for a king tablesaw model kc10-sc 1 hp
I did some Research and Came up with the King Canada Website, where they Show your Table Saw. You may wish to go to that site, and Click on "Contact Us" and send them a Request for the Proper wiring of Their 220V Motor...Here's the Link for Their Site:
http://www.kingcanada.com/Products.htm?CD=101&ID=644
As far as a 220V Motor Wiring goes, 3 Leads works since you have 2 Hot Leads(Black & Red), 1 Neutral Lead(White). as Far as a Capacitor (probably 2 Black wires) goes That should be Pre-Wired into the Motor coming off the Lugs for Your Wiring to...Should NOT be a 2-Stage Motor Connect to, but you may be referring to a Mag-Starter(sounds to me Like someone was trying to do Step-down Voltage)
In all Honesty "IF" I were you, I would do the "Contact Us" @ the Link I Provided, and Let King Tell you How They Have Their Motor Wired for Your Application. Good Luck. Let me Know How you make out.
Mar 15, 2009 | Saws
Feb 13, 2009 | Hitachi 10", Table Saw with Stand,...
On/off switch table saw
Nov 02, 2008 | Saws
Switch diagram
Be careful with your wiring as some models have a reset switch. Your best bet is to mount new external metal boxes to the frame and obtain industrial switches capable of carring the amperage load that the motors are drawing. Then you'l have identical controls on all units so future control problems will be esasy to solve. In your wiring, always remember that the black is the hot side and always routes through the switch and then to the motor while the white bypasses the switch and goes direct to the motor. In event you have a reset switch,, your black will go in as well as out of the reset and then through the switch to the motor.
Hope this helps.
Apr 06, 2008 | Dewalt DW746X 10" woodworker's table saw...
Saws Logo
201 people viewed this question
Top Delta Saws Experts
Jim London
Jim London
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Delta Saw Expert? Answer questions, earn points and help others
