Question about Kenmore 24032\24036 Top Load Washer
Kenmore Top Loading washer gets very little cold water
The washer (Kenmore Elite 110-230321-00) seems to get very little cold water, but plenty of hot water...the water lines to it are clear (replaced), but whever I use cold or wam water it is usually only hot water with very little cold water.
Is there some type of filter or screen that could be plugged?
    Scholar:
  • 87 Answers
You could try reversing the water lines and see when you select hot if cold comes out strong. If it does not then it should be the valve. If it comes out good in reverse, it could be the tempature sensor. Here is the link to parts and diagrams.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=11023032100&productCategoryId=0153200&brandId=0582&modelName=WASHER&diagramPageId=00003&componentDescription=REAR%20PANEL&documentId=P0110152&backToLink=Return%20to%20Sub%20Components%20list
Posted on Mar 04, 2009
How do i fix the FH error code on a kenmore elite he 3t washer?
This indicates a water problem. Make sure you have both hot and cold water turned on and running to the machine. If pressure is to low on either hot or cold you will also get this reading
Jun 23, 2014 | Kenmore 24032\24036 Top Load Washer
Silt, sand, something from deep water well has migrated past exterior washer hose screens into washing machine. Older Kenmore HD Series 70 top loading washer. How to fix?
probable but unlikely
the control valve for the water ( hot or cold ) has a diaphragm in the main flow with a small hole in it to act like a pressure regulator
so when the solenoid shuts off the water , water flows through that small hole and locks the diaphragm firmly on the seat
I suggest that the low flow is because that diaphragm has been compromised and is not opening correctly for full water flow
take it apart and clean it out or replace it
Feb 04, 2018 | Kenmore Washing Machines
Hot water seems to not enter tub during washing cycle. all connections are correct and the hot water hose is hot up to the back of the washer, im baffled ? does the unit start with cold water on the first...
They start with hot or warm ,what/ever the setting and rinse with cold water. Check the temperature adjustment and the cycle it's on as some do different things on different cycles.
Dec 22, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
My Kenmore top loading washing machine is leaking from the bottom. The water is dripping from the bottom of the front panel. What needs to be fixed and how do I do it?
This symptom usually indicates that you have a failed inlet solenoid water valve assembly. Completely unplug the washer from the electrical supply and see if the water stops filling. If it does, then you likely have a control board failure. This is rare but possible. If the water continues to fill with the washer unplugged from electricity, I recommend shutting off the hot and cold water supply faucets behind the washer. It is likely that the water will stop filling the washer. This would indicate that you have a failed water valve assembly.
Jun 28, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Getting only cold water to my washer; hot water is not there
Hot water solenoid valve on washer not working. Test resistance across connectors. No resistance equals bad solenoid. Their not expensive and easy to install.
Mar 29, 2009 | Kenmore 20722
Washing machine won't heat water
it sounds like the hot water supply hose on the back inlet water valve is not opening up,to check it switch the hoses,cold on hot,and hot on cold,put the washer on fill cold,if hot water comes out you know it's the water valve-mike
Mar 21, 2009 | Kenmore 80754 Top Load Stacked Washer /...
Kenmore Elite Calypso washer won't fill with water!
i assume that the warer is turn on at the warer valves if so then do you have voltage at the water valve if not then water pressure switch could be bad or main control board could be bad
Apr 24, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite washing machine
This code means its not getting a sufficient water supply. I was doing a cold wash and noticed it was sucking down some hot water, so shut off the hot. MISTAKE, after a little bit the HF code came up. Apprently it likes to decide for itself just how cold is cold. Darned Computers.
To make a short story long, when I shut off the hot, it apparently shredded the washer and sent the remnants down to the little filter thingy at the washer itself, whereupon they reassembled themselves into a clog, once again giving me the HF code.
(Check your user manual Troubleshooting section. I think it says to press Pause/Cancel twice)
Mar 30, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite washer
sounds like you have a bad water valve,,either that or a bad water temp select switch,(doubt that). way more common is a bad water valve.
Mar 22, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
104 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
