Question about GE Profile Harmony DPGT750EC Electric Dryer
Squeaky drum I have replaced felt that the drum rides on still squeaks think it is in the back model #DVL223GA G.E.
  • 686 Answers
You will have to open the top once again. Remove the front panel and the belt and then un screw the three screws inside the middle of the drum and remove it. Go to this it will show you the part you need to grease with high temp grease. www.repairclinic.com/SSPartdetail.aspx?s=t-DVL223GA-%3d%3di771336&PartID=771336
Posted on Mar 04, 2009
Ge dryer squeaks
replace the felt that the drum rides on, if you take the front panel off the dryer you will see it on the top of the panel where the drum rides. hope this helps you
Apr 15, 2014 | GE DBSR453EBWW Electric Dryer
Whirlpool dryer was making loud squeaking noise. Now it is not turning at all. Makes a noise when you turn it on, but stops completely.
Check the drum belt. Check the drum rollers on the back & glides on the front that the drum rides on also check the idler pully. Check the felt the drum rides on in case it came loose and won't let the drum turn. Did it hum when you started it if so could be the motor. Good luck
Apr 06, 2014 | Whirlpool GGW9200L Gas Dryer
Loud Squeaky Performa Dryer Mod# PDET910AYW. I am guessing I need a rear drum bearing kit, perhaps as well as the felt pad/glide? For some other models, like Frigidaire, it looks like they sell the...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jul 09, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
Squeaky 4-yr old Frigidaire gas dryer
it's most likely the rear bearing that the drum rides on in the rear of dryer,you'll need the model number located around the door opening to order the right part.
Apr 25, 2010 | Frigidaire Dryers
Our dryer has a terrible squeak. We replaced the
The terrible squeak is probably the idler pulley shaft spalling in the idle pulley mount. When the idler pulley siezes to to pulley shaft it spins in the mount and makes a horrible racket.
It can be the motor bearings also but I doubt it at this time. With the belt off you can spin the motor and listen for any odd sound. If you hear nothing then the problem is definately the idler pulley assy.
It is normal for the drum to float in place. When there is a problem with the drum or drum felts, you usually hear a cyclic scrape or grinding sound that is concurrent with each rotation of the drum.
Thanks for using FixYa.
Kelly
Mar 05, 2010 | Frigidaire GLGT1031C Dryer
My dryer is squeaky. it's a GE model number DVL223EYOWW. how do I fix a squeaky dryer?
It depends on what is making the squeaking noise. Could be drum bearing, drum slides, tensioner pulley, pr even the leveling legs sometimes squeak.
Jan 10, 2010 | GE Dryers
Squeaky drum
The drum rides on felt glides in the front, rollers in the back. The glides can wear out, but more often the rollers just need new grease. It must be high temperature grease. A lot of times the rollers are held in place by snap rings, that means you need snap ring pliers. Time for a technician. Besides, it's a pain to take a dryer apart. While apart, vacuum the insides.
Apr 17, 2009 | Dryers
Squeaky dryer
it the felt and the sliders you will need to change them next or drum will settle in and noise will stop thank you for useing fixya please rate me
Feb 24, 2009 | Frigidaire Dryers
Squeaky dryer drum...felt thing came off how to replace it?
Squeaking is cause by the drum bearing worn out and telling the tale. As it get thinner and thinner it begins to rub against the metal outer casing it is embellished in. To inspect it you must rmove tyhe front and get the drum out. Start by opening the the door and removing the screws holding down the top. Then raise the top and get the screws out thathold the front on. Use the rear acces panel(if applicable) to get the idler loose or access that idler from the front.e24a4b7.jpg
Jan 12, 2009 | GE DVL223EBWW Electric Dryer
GE Profile Harmony DPGT750EC Electric Dryer Logo
130 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
Are you a GE Dryer Expert? Answer questions, earn points and help others
