Question about Jl Audio 1000/1 Car Audio Amplifier
I have a Hifonics XXV Colossous and 2 JL 500/1's. I want to know which I should use to push my 2 12" W7's to get my full money's worth and the best of the subs. Also if someone can describe how I should adjust the settings.
  • rebelnv Mar 04, 2009
    sticky92505 THANK YOU so much. I really appreciate it.
  • 77 Answers
I highly recomend you use the hifonics colossous and wire the subs @ 2 ohms and you would be right about nominal power handling for the W7 which is rated @ 1000W, and your amp would push about 1100W to it. just be carefull when adjusting. and the best advice i can give you on the settings is as follows: Turn up the volume to the desired listening average level. (what you would normally have it on when driving) then adjust your amp by turning the different controls up, and then back down a 1/4 turn after distortion occurs. in your case with so much power dont turn them up all the way right away ease into it be gradual listen to the change in the sound.
Posted on Mar 04, 2009
How do i hook up an amp to my sync sysytem?
Go to jL audio web link. Thayer have a sound processer that I used in my 2013 ford f150. I have two jl amps 1000-2v and a 500-4v. In the front doors are 6.1/2 jl comp and in back doors are 6-8 jl full range. And two 13" jlpancakes. I use a jl cross over. Hope this helps.
Jun 21, 2014 | Hifonics Car Audio & Video
I have 2 12 inch jlw6's and need a amp but dont know what would be better, if i get 2 jl 500/1 or 1 jl 1000/1, or if other amps out there would be good for a reasonal price, any advice would help...
yea the jl either setup will be good for those woofers but for the money an to get the power i would try a hifonics 2000 or the 2600 brutis or mtx or2 poweraqustic 4000 planet audio they will work great or give me a call there are a lot of amps to choose for the money an the power
Jul 08, 2010 | Jl Audio 1000/1 Car Audio Amplifier
My cone on my JL W7 cone is cracked, How can I replace?
JL has good customer service, and usually you can get a drop-in replacement core/coil/former/spider. Call/e-mail the techsupport listed on their website, or contact your local dealer for replacement parts/service.
Jun 16, 2010 | Jl Audio 12W7 Car Subwoofer
Installin car systems
you dont want to connect both of those amplifiers together. You could run them separately to separate subs or the jl to your sub and your alpine to your front speakers. But you dont ever want to mix and match amps to the same sub. Even if you had 2 jl500/1's you wouldnt want to just hook them up together. Because they both have to be putting out the exact same amount of power. Which no 2 amps are ever exactly the same. Some companies make bridges to properly connect 2 exact amps together. I Hooked up 2 JL 1000/1's to each voice coil on a 13.5 W7 and i smoked the sub. So i definitely dont reccommend doing it unless the amps are conneccted to separate things.
Apr 28, 2010 | Jl Audio 500/1 Car Audio Amplifier
Is my amplifier giving my subs the full power they need?
no sony has like 400 rms on that amp. eventualy u will blow the subbs. buy the hifonics 1608d amp to power thees subbs connect them all positives together at amp terminal and all negative together at negitive on amp terminal. this will make it a 1 ohm load with around 1400 true rms so around 500rms each sub.this amp on ebay runns like 250 and is worth every penny
Jul 20, 2009 | Alpine CDA-9884 Car CD/ MP3 Player
Jl audio 1000/1 problems
Hello l_miller36,
Depending on how much you paid for the amp on eBay, and how well you like the JL product, it may very well be worth the money to get it fixed. As for the wallet damage, you'll have to ask JL or one of their dealers. But, since the Slash2's routinely sell for over $1,000, I'd estimate the cost to be pretty high.
First, I'd send an email to JL Audio tech support and see if they have a "flat-rate" repair option or if they can give you an estimate of the repair costs. My second option would be to talk to a local car audio shop that does component level repairs. In the first case, you'd get exact replacement parts and whatever warranty JL gives on repairs. Not so with the local option, but it would most likely be less expensive.
Hope this helps, good luck.
May 31, 2009 | Jl Audio 1000/1 Car Audio Amplifier
If I buy 2 12 inch jl audio w7 subs would it be better to get 1 or 2 jl audio 1000 watt amps
two amps and get a 2 farad cap please because if u dont u could melt wires together cause a fire or toast ur alt.
Oct 30, 2008 | Jl Audio Car Audio & Video
Complicated JL Audio Amp
1. set the amp LP filter frequency at about 80hz and mode/slope to 24db.
2. set the amp gain as recommended in the manual.
3. set the subsonic to on and to about 25hz
4. ste the bass eq to off!
5. set the input voltage to low and signal sensing to off
6. Fine tune by ear.
Oct 28, 2008 | Jl Audio 13W7 Car Subwoofer
I have 2mb quart 15's 2ohm sub and a hifonics bxi1608d amp
The two 2ohm subwoofers can only be wired to a 2ohm or 8ohm load. You are gonna want them wired 2ohms on a monoblock amplifier. the other option is to wire each sub to 4 ohms (series) and then connect each one to a separate channel on a 2 channel (stereo) amplifier. go for an amplifier that produces up to the MB's RMS rating and make sure they are enclosed in a box to their specifications and they should pound.
Jul 30, 2008 | Jl Audio 500/1 Car Audio Amplifier
Jl Audio 1000/1 Car Audio Amplifier Logo
106 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
