Question about Microsoft Xbox 360 Console
Trying to go live online with xbox 360
Is it possible to use my existing wireless router for my laptop?
  • My reply is May 11, 2010
    Yes,
    Use the same security password you use just as your Laptop to access your wireless modem/router.
  • 20 Answers
Ya you willl have to put in the same secuity password hope that helps:)
Posted on Mar 04, 2009
My xbox 360 says im connected to xbox live checked network setings and it says xb ox live is up and running...however when i try to play need for speed online..it says xbox live not working functionally?...
Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings." Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there. Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.) Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP. Save your settings and verify the network is functional. On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live. On the Xbox 360, use the "Test Xbox Live Connection" option instead.
If you need more help post back! Thumbs and testimonial are welcome!
Jan 15, 2011 | Computers & Internet
Get connicetion from laptop to get online
  1. Turn off Xbox 360 console and network hardware (for example, your modem and router).Wait 30 seconds.
  2. Turn on your modem and wait a minute.Turn on the next piece of hardware (for example, your router) and wait another minute.Turn on your Xbox 360 console.On your console, go to My Xbox, and then select System Settings.
  3. Select Network Settings.
  4. Select Wired Network or your wireless network if you are prompted to do so.
  5. Select Test Xbox LIVE Connection.If Xbox LIVE performance is still slow, try the next solution.
Dec 29, 2010 | Microsoft Xbox 360 Console
Trying to get xbox live
reboot your modem and router, then try again...by the way, how are you connecting the 360? hardwired or wireless adapter? either way, you should reboot both.
Apr 05, 2010 | Microsoft Xbox 360 Console
Wireless not working
Run the network tests from within the 360 menus - looking especially at the result for network address translation (NAT). If this is either limited or fail, you will need to change your router for one which is compatible with xbox live. Try xbox.com to work out which routers are recommended.
As far as your router kicking him when you connected your pc, then you must have altered the access permissions of the router maybe by accident.
If all else fails, turn off the pc, router, modem and 360. Find the reset button on your router and press/hold this for at least five seconds. Turn on the modem, then the router. Let that settle for a minute, then connect and setup 360 and laptop.
Apr 10, 2009 | Pelican PL-2050 XBOX EDGE 2.4 GHZ WIRELESS...
Cannot connect xbox 360 to wireless router
If you use DSL I would also check to make sure you are not being port blocked by your ISP. Some will block you if you exceed bandwidth on a particular port rather than throttling you or shutting you down entirely.
Dec 29, 2008 | Linksys Wireless-G WRT54G Router
Xbox 360 live on wireless router
In theory you should be able to "share" your internet connection. I use a Linksys WRT54GS wireless router and I have a Linksys Game adapter on my son's 360. He has not complained about lag or slow server times unless other intensive bandwidth is being used.
Nov 09, 2008 | Microsoft Xbox 360 Console
Cannot connect to xbox live using a wireless laptop
This site has good information relating to connecting your xbox 360 to xbox live wirelessly with laptop or modified router and improving xbox live NAT rating:
[url=http://howtoconnectwirelesslytoxboxlive.blogspot.com/]How to connect to xbox live wirelessly[/url]
Aug 11, 2008 | Microsoft Xbox 360 Console
I'm trying to connect to xbox live over a laptop but it wont let me connect! What's up?
This site has good guides relating to connecting your xbox 360 to xbox live wirelessly with laptop or modified router and improving xbox live NAT rating:
Jul 03, 2008 | Microsoft Xbox 360 Console
Xbox 360 to wireless laptop
Make sure ethernet cable from XBOX 360 is connected to one of the 4 access ports on the back of the router.
Mar 16, 2008 | Microsoft Xbox 360 Console
Problem with streaming from my laptop to my xbox 360 wirelessly
Call microsoft for a solution, they will most likely know in a few minutes. Even though you get punjab from india.
Mar 02, 2008 | Microsoft Wireless Network Adapter Xbox...
Microsoft Xbox 360 Console Logo
16 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
