Question about Gateway 830GM PC Desktop
Ethernet driver for gateway 830gm
I reinstalled windows xp and now I have no ethernet nor usb bus port driver. Please help.
  • renebrutusdi Mar 04, 2009
    this did not work...?
    which one is the ethernet driver? Sorry..... Thanks in advance for any help.
  • Gateway Master
  • 19,396 Answers
Insert computer serial number here to download the drivers.
Alternatively click driver download here: Gateway Support - 4659 Gateway 830GM
Click on the drivers, download them , then install them one by one.
Follow instructions from setup program.
Posted on Mar 04, 2009
  • Ginko
    Ginko Mar 04, 2009
    Hi, I gave the download page for your computer, you have to reinstall the ethernet driver , after downloading from that page.
    I do not understand why you gave me a bad rating.
    I will be grateful if you can correct the rating given.
    Many thanks.
  • Ginko
    Ginko Mar 04, 2009
    Hi, here is the link to the ethernet drver :
    IntelPro8019.exe -
    Intel(r) Pro/100 and PRO/1000 Network Driver
    Version: 8.0.19.0
    Click the red download now link on the page above.
    Please also change then rating given.
    Many thanks.
I need XP driver's for Gateway 830GM Desktop P4 3GHz.
those should have come in the install disc, if possible, can you use the wireless to connect to get the drivers. if not, find a friend that has internet acess and down load the driver to a thumb drive and install that way,
Sep 11, 2014 | Computers & Internet
Tip
USB devices not recognised or not working properly?
Try these steps to reinitialize your usb ports on your pc
1. Unplug ALL USB devices connected to the computer. If you are using a USB mouse and keyboard, temporarily use the older type PS/2 devices if you have them, if you don't then just leave them connected.
2. Hold down the windows key and press r
3. Type devmgmt.msc into the run menu and press ok
4. Click on the + sign next to the Universal Serial Bus Controllers
5. You might need another mouse to do this if you have a usb mouse.. I recommend you get a ps2 connector mouse which goes into the green round connector in the back of your pc.
6. Right click and uninstall first the usb root hubs. all of them then uninstall the rest of the devices you see under Universal serial bus controllers
7. Ones you have uninstalled everything you should see the Universal serial bus controllers there at all.
8. Now go ahead and restart your pc.
9. Ones you have restarted the pc your usb ports will reinstall in a moment stand by while it installs all of them. If you get warning messages click ok or continue installation.
10. Now go ahead and plug the usb devices back in. Install software if required, all usb devices if not faulty or broken should work now. Also note the error code if you get one?
This solution doesn't fix all usb problems so if you have a yellow ! mark there and device status reports a error code. Then it might not be a problem with your usb ports.
Thank you for reading, do leave suggestions, comments, feedback below.
Ekse
usb mouse drivers for windows xp mouse trackball mouse drivers bluetooth mouse computer problems 2.0 usb driver microsoft windows scanner driver usb 2.0 air mouse computer service usb hubs update drivers fix windows computer services computers hub usb usb drivers usb 2.0 hub laptop mouse usb switch 4 port usb 2.0 hub wireless mouse usb driver fix computer windows xp pro usb optical mouse computer support computer repairs update driver 4 port usb hub usb security usb cable windows xp microsoft windows xp computer repair windows xp professional upgrade windows
on May 04, 2008 | Microsoft Windows XP Home Edition
Usb port not recoginzed
w7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
for xp
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb but its not working
ports(com&lpt)right click update driver
hope this helps
Aug 02, 2012 | Kingston Data Traveler 100 G2 4GB USB 2.0...
Support file isrt.dll not installed during loading of wusb300n I unloaded device and reran. I get "Cannot install this hardware. There was a problem installing this hardware." I followed Microsofts...
That would be correct. If it is USB attached and not PCI (internet/ethernet card)
I would try updating drivers for the linksys and then reinstall the software and manually set configuration
Jun 30, 2009 | Linksys WUSB300N Wireless Adapter
Acer extensa 5620
i have laptop acer extensa 5620z, install windows xp professional os 32 bit, inside device manager open that time
Ethernet controller
Ethernet controller
Mass storage controller
Pci device
Pci device
SM Bus controller
Universal serial Bus (USB) controller
biling the yellow(!) mark, and usb device put in the usb port not open how to solve this problem, please reply me, thankyou,
my email senthil_japan@yahoo.com
Jan 26, 2009 | Acer Extensa 5620 Notebook PC
USB Ports
one way would be to download and install latest device drivers from the net. it should help.. if you are using win XP, there is likely a BIOS or Windows configuration problem. On some computers there is a configuration option in the BIOS that asks whether an IRQ should be assigned to USB. Although the option's actual wording varies among BIOS manufacturers, you must enable this option by setting it to either On or Yes (depending on your BIOS manufacturer and BIOS version). Otherwise no USB devices will work on XP. A problem with Windows XP’s USB Controller configuration can also prevent any USB devices from working. To determine whether the USB controllers are working properly, open Device Manager and expand the Universal Serial Bus Controllers node. Beneath this node, you should see a USB Universal Host Controller and a USB Root Hub. Depending on your PC, there will either be a USB Universal Host Controller and a USB Root Hub listed for each of your computer’s USB ports or a USB Universal Host Controller and USB Root Hub for multiple ports
Jan 20, 2008 | Gateway GT5432 Refurbished AMD Desktop...
MISSING SOFTWEAR FROM COMPUTER
Go to Lenovo's support site on another unit, enter the model of your unit (it's on the bottom of the laptop) and download the drivers for the items XP didn't have drivers for.
It's not uncommon these days to have very few drivers provided by the operating system.
No worries.
Good luck
Oct 24, 2007 | Lenovo ThinkPad R51
Gateway 830GM PC Desktop Logo
911 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
