Question about Kenmore 24032\24036 Top Load Washer
Got a used front load washer, As soon as it is turned on, it trips the breaker, Any help
    Sergeant:
    Champion:
  • 338 Answers
Sounds like the power switch may be shorted.
Posted on Mar 06, 2009
Spin cycle trips house circuit breaker on my GE top loading washer
The very likely reason the breaker trips only on spin is because the tub bearing is locked up on the washer since it is locked up its causing way excessive friction at the motor which causes the breaker to trip.Can you rotate the tub by hand or does it seem really hard to rotate by hand indicating that the tub is ceased up due to the tub bearing??
GENE
Oct 29, 2011 | Washing Machines
Washer keeps blowing fuses
Do you mean the houses circuit breaker? If so, WHEN in the cycle does it blow the circuit breaker? WHEN it trips will tell you what to look at. I.E. If the circuit breaker trips during the fill cycle then it would be the walter inlet valve or the timer in the control panel; if it trips as soon as it is in the agitator cycle - then the motor or transmission; if it trips in the spin cycle - then the drain pump or transmission or control panel.
Jul 15, 2011 | Maytag LSG7806A Front Load Stacked Washer...
I was doing a small load of laundry when the breaker tripped
Sounds like an electrical short somewhere in the washer. Needs to be checked out by qualified service tech.
Feb 04, 2010 | Washing Machines
Washer tripped breaker on elec. panel, reset, washer won't turn o
This sounds like something has shorted causing the breaker to trip. You definitely need a qualified LG repairman to check it out.
Jan 11, 2010 | LG WM1814CW Front Load Washer
Why does my washing machine trip the electric
run the machine, after it trips, unplug and carefully touch the motor,it may have a bad capacitor, or dry bearings causing it to draw excessive current,if these 2 things are not it, then look for a bare wire that may be touching case during this part of the cycle,and if you can get an "Amprobe" it reads current and check machines current draw during the start to trip current
Oct 27, 2009 | Hotpoint WMA58 Front Load Washer
Trips breaker when plugged in
If it still does, you have a dead short in the electrical system of the dryer. Don't try to use it until you get it fixed. It could start a fire.
Sep 11, 2009 | Amana Dryers
Hotpoint washing machine keeps tripping electric
First unplug your washer. Check the ground on the washer and make sure it isn't loose; this would be a good time to inspect the wiring harness for any problems. Next check the outlet (turn off the electric to that breaker first) make sure all the wires are tight and are making good contact; pay special attention to the neutral (white) wire. If that seems fine, and you are comfortable with going into you breaker panel, turn off that breaker and check the hot (the wire on the breaker) to make sure it isn't loose and then check the neutral wire. If either of these wires seem loose tighten them down....a loose wire will move when a load is put on it and cause the breaker to trip. If all seems normal and washer is still tripping the breaker you might want to replace the breaker.....they can go bad. Good luck!
Aug 26, 2009 | Hotpoint Washing Machines
Turn washer dryer on ok, then close door then curcuit trips
check the wiring and make sure nothing metal is on the motor because your dryer has a short in it somewhere
Dec 23, 2008 | Hotpoint Ariston Aquarius WD420 Front Load...
Kenmore 24032\24036 Top Load Washer Logo
26 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
