Question about Sys 4.1 pc. 140 Watt Speaker Computer Speakers
DirectSound test results: Failure at step 19 (User verification of software): HRESULT = 0x00000000 (error code)
  • Anonymous Mar 04, 2009
    Please help
  • Anonymous Mar 13, 2009
    podo ndes
Please follow the steps below,
1. Start / Settings / Control Panel / System / Hardware / Device Manager
2. Scroll to bottom of list, click on System devices
3. Scroll down to Microsoft UAA Bus Driver for High Definition Audio
4. Right click on "Microsoft UAA Bus Driver" and select Disable - screen will refresh
5. Right click on "Microsoft UAA Bus Driver" and select Uninstall - screen will refresh
6. Reinstall the RealTek HD Audio
Problem with the Xp SP3 high defination
Regards,
Posted on Feb 11, 2010
2 Suggested Answers
SOURCE: DirectSound test results: Failure at step 19 (User verification of software): HRESULT = 0x00000000 (error code)
help me fix it! (sound cans be displayed)
Posted on Oct 14, 2008
Disable 2 step verification code
Log into your google account, if you cant log in try to get to your google dashboard. You can get there by going to, www.google.com/dashboard
And then go to security setting.There you will see activate or disavle two step verification. From your dashboard you can change all your securitysettings. If you have trouble go to www.google.com/accounthelp
And they will help you deactivate it.
http://www.google.com/accounthelp
Dec 19, 2014 | Samsung Chromebook XE500C21 12.1" LED...
Hello, I dont have any sound on my speaker.When I run dxdiag I found this "DirectSound test results: Failure at step 19 (User verification of software): HRESULT = 0x00000000 (error code)".When...
if you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Apr 03, 2011 | Sys 4.1 pc. 140 Watt Speaker Computer...
I think I need a driver for a Mikomi headset with mike.
mikomi head and mic set drivers for xp pro meed pls
Mar 18, 2009 | Audio Players & Recorders
Today,I open a song to listen it but when i play the song with winamp the message come that bad sound speaker and error 88780078
That is a Bad DirectSound Driver Error. If the problem persists, make sure you have the correct sound card drivers installed. Also try downloading and installing the newest driver for your hardware.
If you click on Start, and then Run... type in dxdiag and press ok.
This will bring up DirectX where you can run some test with your soundcard.
Mar 03, 2009 | Audio Players & Recorders
Install realtech audio driver \ failure error code OXE000227
that sounds pretty ***. maby you should stick to game boys or super nintendos, sumthing **** like that :)
Jan 16, 2009 | Audio Players & Recorders
Rear Speakers do not sound, other 2 do, and boofer.
There are several reasons why there is no sound coming from the rear speakers.
  • Improper connection of the signal cable is a possible reason why there is no sound coming from the rear speakers.
7949.jpgGreen connector is for the front left and right channel. Black connector is for the rear left and right channel. Orange connector is for the LFE (Low Frequency Effects) subwoofer and the center channel.
The connectors for the Logitech products are color coded as explained. The connectors on the sound card may not be color coded or a different color coding maybe used depending on the manufacturer of the sound card. Check the manual for the sound card to make sure the correct connector is connected from the Logitech speaker to the sound card.
  • After verifying that the connections are made correctly, the sound card needs to be checked to make sure it is setup correctly. There are many sound card manufacturers so we cannot possibly cover every make and model. We recommend contacting the manufacturer of the sound card to make sure the sound card is setup correctly for use with analog 5.1 speaker systems.
  • When a software DVD player is being used to watch a DVD, the audio output needs to be set to surround sound mode. Please refer to the user manual for the software DVD player to check the settings.
Many DVDs have more than 1 sound format available. Just as the sound card and the software DVD player, the DVD itself has to be set to the correct sound format.
  • Finally you can test to see if the speakers are working correctly by plugging the front channel cable coming from the sound card to the rear channel connector on the subwoofer. If sound comes out of the rear speakers, then there is no problem with the speakers. The problem could be with the software DVD player, or the audio setting on the DVD.
THIS article can be used to test if your speakers are indeed working.
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. -You can rate this solution with one of four votes (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
May 04, 2008 | Logitech X-530 Computer Speakers
Bad direct sound driver
First, go to control panel, and then device manager, to see if any problems exist. If not, still in control panel. go to check sound. Click on Manage Audio devices to see if all is ok. If you need to redownload your sound controller, like realtek, or it needs an upgrade, you can download that from your computer's support website. You also can check to see if you have configured your system to your speakers==are you using built-ins, or have you purchased others? Let me know if this does the trick for you.
Apr 05, 2008 | Audio Players & Recorders
Error code 88780078
 Showing the Error code 88780078, not installing the audio and ethernet drivers properly.please give the website details or which software I have to install? how to install
Sathish Kumar
email: sathish_daratla@rediff.com
Sep 30, 2007 | Audio Players & Recorders
Sys 4.1 pc. 140 Watt Speaker Computer Speakers Logo
3,560 people viewed this question
Top Sys Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sys Audio Player and Recorder Expert? Answer questions, earn points and help others
