Question about Nintendo DS Console
Touch Screen I have a major problem with my DS. It turns on, then goes to the options screen like it normally does. But the touch screen won't work. I can't select anything. The touch screen won't respond to anything. HELP! If anyone has any suggestions that would be great.
  • j_m_cyr Mar 05, 2009
    I fixed my problem. :)
    Seems like it was just dirt in it. I went to the Nintendo DS website and it shows you how to clean it. Take a dry toothbrush, push down on the edge you want to clean, and brush into the crack between the plastic and the screen.
    Thanks for your advice. :) If it ever became unfixable I'll do that. :)
  • 38 Answers
Just like yours, my DS's touch screen kicked the bucket last october. I went and traded my broken DS in at gamestop and got another one bc nintendo wouldn't replace it for me. I would recommend the same to you =).
Posted on Mar 05, 2009
Hi. The touch screen on my wee girls touch screen has stopped working. Can I fix this myself or can do I need to send away?
You can try sorting the problem yourself before you decide to send it in to Nintendo.
Most DS touch screens stop working if there is dust, hair, sand etc gets under the frame of the DS. They stop working because the particles get pushed down on the touch scream making the DS think that screens already been touched and won't respond.
Get a toothbrush with straight bristles and with your thumb gently press down the touch screen along the frame, use the touch brush to clean under the frame but be vary careful not to press down too much as you could cause damage to DS.
If the screen still doesn't work then you'll have to send it in for repair.
Hope this helps.
Regards.
Apr 24, 2011 | Nintendo DS Lite Console
My old ds has major scratches because my friend used a pencil on it once now the touch screen barely works
Wuts the DS got to do with mother boards?
Oki, you could replace that scratched TOUCH SCREEN only!
No needf to buy the LCD itself!
An expert on DS techman must do the job!
Nov 06, 2010 | Computers & Internet
The touch screen isn't responding very well, sometimes it will react to a tap but mostly the screen is non responsive, the keys work ok when scrolling on a menu screen. any ideas?
first try to calibrate the touch screen.Take all games out turn on then go to the very small ds on the bottom touch screen. If you can't touch it move it with the cross down then hit a. Then select the option all the way to the right it looks like cross hairs that's the calibration screen fallow instructions. If that doesn't fix it it could be a broken screen or a loose ribbon.
Feb 24, 2010 | Nintendo DS Lite Console
DS lite will not read any DS games. When the DS
Thats normal, there should be a flashing part of writting at the bottem of the screen saying "touch the screen to continue" just touch the screen.
Dec 26, 2009 | Nintendo DS Lite - Onyx
Turn on DS Lite, goes to health page, then to calendar/clock page, then to Pictochat automatically. then it picks a room and you can't get out and can't navigate the DS at all. Help, please.
Hi
Chances are your touch screen is faulty.
If you have warranty then send it in, if not you can try and repair it yourself, its pretty easy to do.
Buy yourself a new touch screen (I use ebay at around £3-£4 per screen), take apart your Ds lite, open the respective flexi-cable connectors, remove the flexi-cables from the motherboard, CAREFULLY peel the touch screen away from the bottom screen, peel off the surround, place it onto the new touch screen, attatch the new touch screen to the bottom screen, reverse the dismantling process and with any luck you have sorted out the problem.
Hope this helps.
Regards,
SOD69
Nov 30, 2009 | Nintendo DS Lite Console
I replaced my DS Lite Touch Screen and now it doesn't respond.
Im really bad at describing things but I hope this helps xD
Please don't for the love of pete go buy another screen.You will only have the same problem like 50 times over.
Since the touch screen isn't working use the rrow keys and the "A" button to selct everything
Take the game out of the DS and turn it back on. Go to the options menu when the DS is on the main Screen(If you dunno what the menu icon is it's at the bottom of the screen about the centre.. the icon is a cute mini DS)
Once you are on the options menu go to the yellow screen and select it ... This is where you calibrate your DS.. i.e make the touch screen work again in most cases.
You should probably calibrate the screen weekly cause the DS is lazy and doesn't remember where the touch sensors are ..
I hope I've helped you and Good Luck xD
Apr 17, 2009 | Nintendo DS Lite Console
Code insert buttons
Have you tried just using the Normal DS buttons rather than the touch screen? I don't know how bad your touch screen is calibration is for your AR (mines pretty close to fine), but if you find that the touch-screen is frustrating you too much, just use the normal DS buttons. Sure it will be a bit slower, but it won't be as frustrating.
Jun 23, 2008 | Nintendo DS Lite Console
Touch screen doesn't light up
Your problem is with the LCD behind the touch screen. The bottom scren on your DS is actually two screens. An LCD and a touch screen on top of it. Either your cable has come loose inside the DS or the LCD is possibly bad. This can be fixed.
The other option is that the electronics feeding the LCD have gone bad in which case you might as well buy a new DS. But check the screen first.
If the DS is under a year old you can send it to Nintendo for free repair.
Mar 04, 2008 | Nintendo DS Console
Touch screen
Contact Nintendo. as you didnt say if it was a DS or a DS lite
go to http://www.nintendo.com/consumer/systems/selectds.jsp
its Nintendos DS Customer Support.
Dec 25, 2007 | Nintendo DS Lite Console
Touch screen problems
Hi penny_od.....The following excerpts has been extracted from the Nintendo Help Site. If you would like to view the entire document, please click on the URL below....Please update your post of any progress, whether positive or negative so that I may learn from this too.....good luck my friend. http://www.nintendo.com/consumer/systems/ds/trouble_screen.jsp#touch ============================================= Touch Screen doesn't respond or is inaccurate when touched * Be sure that you're using only the bottom screen of the Nintendo DS with the stylus. The upper screen is not a touch screen. * Use only licensed Nintendo DS styluses and screen protectors. * Unlicensed screen protectors can lower the sensitivity of the touch screen. If the problem you are experiencing started happening after you attached a screen protector, you may want to remove it. Please note that some screen protectors can leave behind a residue that may be difficult to clean. If you are planning on removing a screen protector that has been placed on your Nintendo DS, click here for tips on cleaning your screens. * If the touch screen is not responding when touched, or the accuracy of the screen is off, you may need to recalibrate the touch screen. Click here for help recalibrating the Touch Screen. * If recalibrating the screen didn't solve the problem (see above step), hold the Nintendo DS at an angle so that you can see where the edges of the Touch Screen meet the housing of the system. Look around the entire edge of the Touch Screen for any foreign material (such as crumbs, etc.) that may be wedged in between the Touch Screen and the housing of the DS. Foreign material in this area can cause the Touch Screen to work incorrectly. If there are any visible particles, please follow these steps for cleaning the screen. If the above steps do not solve the problem, your system will need to be repaired. Click here for repair information.
Jul 20, 2007 | Nintendo DS Console
Nintendo DS Console Logo
141 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
