Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Need to replace the gator teeth
I have the thing out of the tub/ cann't get it appart
  • Whirlpool Master
  • 3,361 Answers
Stand on the bottom piece and pull up hard on the top piece.
Posted on Mar 04, 2009
How do you fix an alternator for a ford van 2002 E150 v6
IF YOUR GOOD AT TAKING THINGS APPART AND PUTTING THEM TOGHTER AGAIN, TAKE IT APPART AND CLEAN IT UP AS BEST YOU CAN AND HOPE NOTHING IS BURNT OUT.CHECK THE BRUSHES ,IF THEY LOOK REALLY BEAT,YOUR PROBLY BETTER OFF REPLACING IT THEN DEALNOT STARTING WHEN YOU NEED IT.
Oct 12, 2011 | 2003 Ford E150
Peg perego gator hpx gear slippage
Look carefully at each of the gears. Take them apart and I bet some of the teeth are sheared off. Order new gearboxes should fix the problem. This happened to us.
Aug 03, 2010 | Peg Perego John Deere Gator HPX Ride on...
I have the ball bearings showing up in my lounger in my spa and now realize that it is probably from a spinner jet after reading several postings. I just filled the tub and put in all new chemicals. Does...
Well.. Ummm... Yes. really to be safe & responsible & to prevent any more damage. Just having it hot & using for a little bit, may be OK, but no water jets etc. No Water Pumping jets etc.
Feb 06, 2010 | Qca Spas Majestic Series Aruba Xl Hot Tub
Tub will not spin up
It's usually the teeth are broken/worn off the plastic gears. Sounds like one side may be ate up. Check your belts and gears.
Jun 28, 2009 | Kenmore 44072 Front Load Washer
How do you get the cap off to replace the gator teeth
Flat blade screw driver and pop the top cap off.
After that it depends on your model.
Either a 7/16 socket to remove the bolt and lift the agitator.
Or a 3/8 socket drive extension and remove the agitator.
Mar 04, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Gear clicking in rear
Does it go in reverse without clicking? If so then the teeth are worn over to one side. If thats it you can swap the motor and gearboxes from side to side, left to right and right to left, and get a little more time out of them. Otherwise you will need to replace the gearboxes. There are plenty of places to buy them from and they are not hard to change. No special tools. Best source of info I have found is www.modifiedpowerwheels.com They have lots of info and its all free.
Dec 17, 2008 | Toys
Peg Perego Gator Ride On Toy
Sounds like the gears are stripped. If a bunch of teeth are missing, only the high speed gear will spin the gears fast enough to move the gator forward. I just bought a used one and found it pretty easy to tear apart and diagnose as similar issue. The gear boxes, located inboard of each wheel contain plastic gears and strip relatively easy if the shifter is moved , during motion from forward to reverse.
Aug 11, 2008 | Toys
Focuser broken
Not really a solution, but anything is better than a posting that get's NO response. It sounds like the rack and pinion drive has collapsed. If you're good with your hands and have a knack for things mechanical maybe you can dissassemble the stage mounting and see how it's meant to work. If something has come loose rather than broken maybe you can fix it. If teeth have stripped from the drive gear - you may be unable to effect a repair. I guess trying to fix it is better than doing nothing. Have a good 2008
kevin
Jan 05, 2008 | Meade 8200 Monocular Microscope
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
Dan Webster
Dan Webster
Sal De
