Question about Kenmore 53092 / 53094 Side by Side Refrigerator
Refrigerator wont get cold ice build up behind panel on freezer
Side
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 531 Answers
Defrost problem
Posted on Apr 05, 2009
Refrigerator and freezer not coming up to temperature. replaced start device on compressor what else could be the issue
Some of these brand friges have a tendency to not defrost the freezer side properly. Ice builds up behind the freezer panel thus reducing air flow to the frig side. Having replaced all parts repeatedly on my WP frig, actually two of them, and losing food repeatedly, a WP repair guy said it was unrepairable. WP is crap. Their design is crap. Many side by sides are littered with cooling problems. The defroster coil, defrost sensor, and thermostat just dont work properly. In the end, I bought a diff. brand and will never buy wp again. Keep in mind how many brands are sister brands to wp and avoid them too.
Oct 12, 2014 | Whirlpool Refrigerators
Hotpoint refrigerator side by side
All of the cold air for the refrigerator comes from the freezer. Is there any ice build up behind the shelves in your freezer?
Feb 28, 2014 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
The fridge side is not cooling well. It is cooler than room temp, but not cold. What could cause this problem?
In a side by side, the most likely failure for your type of problem is a failure in the drfrost ciruit (defrost heater, defrost thermostat and defrost timer) that allows an ice build up behind the inner back panel of the freezer. And then you also get an ice build up in the cooling tubes that is susposed to take cold air from the freezer compartment to the refregerator compartment.
The next likely item is the evaporator cooling fan that is located in the freezer compartment. If it is working then there is no cold air transfer. You should be able to feel the air flow in the refrigerator section if it is working.
Jul 22, 2011 | KitchenAid (KSRD22FKST) Side by Side...
Freezer side gets very cold, but the refrigerator side is slightly cool. Replaced thermostate but the results are the same.
It may be a defrost issue. If the freezer is not defrosting then ice encases the fan motor behind the back wall of freezer and wont allow it to circulate the cold are to refer section. To see if that is the issue check behind the freezer back panel if it is iced up try unthawing it, have towels on the floor it will make a mess, if it starts cooling again after you thaw it out then you know its a defrost issue and it will work until the ice builds up again. You may need a new defrost tstat, heater or timer.
Oct 13, 2010 | Whirlpool ED5THAXMS Side by Side...
GE 24 Profile refrigerator: The freezer part
my refrigerator goes into auto defrost every 60hrs for 45 minutes or till the bi metal(defrost thermostat) says it had enough....recently i had ice built up on the coil because my defrost thermostat was stuck open...
ice builds up because the moisture that comes from opening the door or food condenses on the cold coil...tempurature of the coil is below 32 degrees which will ice up the condensed moisture...
defrost is timed to remove this build up
Oct 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Samsung RS253BAVQ freezer Keeps defrosting, and wont dump ice
One posibility is that it is not defrosting a all and that the ice is building up on the evaporator coil behind the rear cover inside the freezer. This condition will block the flow of cold air. Remove the back panel to see what your have. Either no ice , light frost, partial icing or heavy icing blocking the fins. Complete light frosting is normal.
Sep 09, 2009 | Samsung 24.8 Cu. Ft. Side-by-Side...
Freezer
replace the circulating fan motor
Jul 23, 2009 | Refrigerators
Refrig not cold enough, ice buildup on banck panel of freezer
ice build up means your refrigerator is not going through defrost cycle. you have ice build up on evaporator which restricts your cold air flow into the fresh food side. check defrost timer, defrost thermostat located on evaporator behind the wall where your getting frost. check defrost heater. it wraps under the evap.
Jun 21, 2009 | GE Refrigerators
Refrigerator is barley cold, still makes ice, condensation inside of frostless freezer
Hi: The fact that it still makes ice tells me the freezer is a zero degrees. When you said condensation in the freezer did you mean frost? If your defrost heater fails it will cause the frost free freezer to build up frost. The frost will build up and block the vent that supplies the cold air to the fresh food. The defrost heater is behind the metal wall at the back of the freezer, at the very bottom. A glass tube with a metal coil in it. The coil can break and stop the defrosting. Replace that. Use a hair dryer to melt the frost from behind the panel. All of it top to bottom. You need to remove all the frost to free up the airways. I hope this helps, Jeff
Jun 04, 2009 | Maytag MSD2756G Side by Side Refrigerator
Kenmore 53092 / 53094 Side by Side Refrigerator Logo
65 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
