Question about MSI : MS-7061-020 VIAKM400/DDR333/A&V&L/MATX Motherboard (MOT55)
Sometime harddisk is not detected
Some time win-xp sp2 runs and sometime restarts
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Whats the exact problem your having, windows xp restarting or your hard drive not being detected?
  • 158 Answers
This is happening because of some loose connection or cable problem of your hard disk,
Try to reattach all the cable related to hard disk.
And if possible then use the new IDE or SATA data cable depending upon your hard disk configuration.
Posted on Mar 04, 2009
    President:
  • 987 Answers
Check the Hard disk cable it might be loose ...if not then the cable needs to be replaced...
Hye..my acer aspire laptop very bad causes of virus infection and mess with all my files and folders. so, it think reformat is the best solution for me. But unlucky, when i restarted my Laptop and install...
Hello !
You have said that you have done installation and Harddisk are not recognised this is a indication of damaged Harddisk ie its registry is bad or its not working .
I recomend a new Harddisk then you will able to use your laptop
Before you change the harddisk you should check the IDE cables by swapping them coz sometimes they could be faulty, connect new cable to the harddisk then on it try installation again .
Good luck
Nov 11, 2009 | Acer Aspire 5500 5570-2609 Laptop
MAXTOR 250 gb usb hard disk is not detected
On some computers the output power of the USB ports is too low to drive the Ext. HDD.
Have you tried other USB ports on your computer?
Get yourself a powered USB hub and try that, borrow one if possible, if that works get one for yourself....
Aug 21, 2009 | HP/Maxtor 40GB 3.5 IDE/ATA Hard Drive...
Just bought a laptop cheap as on trade me for extra battery was told that it was broken but fired it up and works but is asking me for a user name and password to log on to windows. can i over ride it or...
keep the laptop, hope it got a working cd-rom/dvd-drive !(if not, take-out /replace the harddisk)
-win xp has to be removed from harddisk,
the hd must be formatted so you got a blank hd to set up your new system
you'll need :
- antoher PC with internet connection and cd/dvd-burner
- a win98 installation cd or bootable savecopy of it,
- a new win-xp install cd plus cd-key
- a program called PC Wizard(download)
and a bit of time...(one night or two:-)
follow instructions:
if you can enter bios (press F1 or F2 or Del)
during booting), youre lucky...
enter bios while booting, in the menu look for boot otions or devices, change order of boot devices, so that cd/dvd-drive is 1st, then save and exit (F10)
insert win98-CD, boot from cd, try to setup win98, you'll be asked to erase/ format all data/installations/partitions
on the harddisk (drive c:,probably), do so, format the drive using the FAT32-file system,
then end installation without fully setting up win 98.
now you should have a blank disk witout any operation system on it.
now put in win xp cd, go through the whole installation process
install and run pc wizard(it'll tell you all hardware devices of the laptop)
get the proper drivers for the notebook for win-xp from the net(google might be helpful)
install them.
happy computing!
if all this did not work, remove the harddisk,(you'll have to unscrew a lot of the laptop)
replace it by a new s-ata ide-drive()and..
erh.. come again then, this is a long process as well
Jul 23, 2009 | Microsoft Windows XP Professional SP2 Full...
Seagate 1 TB not detectable on win 2003, xp detects it
As you know,the Seagate sometimes has the firmware problems,so it seems that this firmware designed only valid in XP or Vista system,you may find the firmware update from the seagate official website
Jun 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Error loading operating system
you'll need to run windows setup again.
Insert the cd restart and when asked to start with cd click enter.
Jan 14, 2009 | Gigabyte GA-EP45-DS3L M-b- P45+ICH10, DDR2...
XP RESTARTS
this is caused because a file of your pc has become corrupt and your XP needs to be reinstalled.
Dec 31, 2008 | Microsoft Windows Xp Home Edition Sp2...
Generic host process win32
It is caused due to some spyware. Install a firewall like outpost, and your problem will be solved
Nov 25, 2008 | Intel Motherboard
Cannot install win xp
Hi Phine_24,
I think you've problem with Harddisk.Try to find spare one and install again it should work. Very strange is that if you remove your hardisk out and test externally it should sometime work fine but sometime fail.I think it's a starting sector or some check up that windows or hardware need and it couldn't access it.
goodluck,takecare.
May 04, 2008 | Computers & Internet
My dvd rw is not detected
When installing SP2 version, you possibly corrupted the drivers for the DVD. It is possible there are different drivers for the DVD between XP and XP (sp2). Go to the laptop mfg website and download the newest drivers for the DVD.
Aug 20, 2007 | Microsoft Windows XP Professional With...
MSI : MS-7061-020 VIAKM400/DDR333/A&V&L/MATX Motherboard (MOT55) Logo
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
