This 91 pontiac grand prix was a gift ,it was parked for a few years and was started every once in awhile,well then one time it didnt.battery was dead,so i pulled it home.i checked for codes none stored,i chaged crank synsor also instaled new ecm,and new coiils still wont start.I changed pcm nohing'i did thereprograming method by waiting 10 min. twice nothing. I'm getting fire on the ecm but notthing coming out of coils .this car isn't equiped witth cam syn. So can some one help before I blow this car up?
SOURCE: 04 pontiac grand prix wont start.
first remove the battery and take it to a auto parts place and have them check it. move on from there. if the battery is good the do a starter draw test. take a meter and hook it to your battery. now have someone try and start the car. if the voltage on the battery drops from 12.8 to below 9 volts then the starter is bad. if the voltage doesnt drop much at all then its prolly the solenoid both of which require starter replacement since most solenoids are on starters. if still nothing then check ignition switch. but before anything else ensure vehicle is in park. if it is in part use a meter to test neutral safety switch.
SOURCE: 97 Dodge Stratus...no ES model...4 dr, 2.4L, Auto
did you check the fuseable link wire going from the starter to the alternator
SOURCE: 91 pontiac formula wont start
I BELIEVE THAT THE MEMORY IN THE CAR'S COMPUTER IS LOST. IF YOU CAN GET IT TO THE DEALER OR A CERTIFIED GM SHOP THEY WILL HAVE TO "FLASH THE DRIVE" ON THE P.C.M.(POWERTRAIN CONTROL MODULE). I HOPE THIS HELPS. LET ME KNOW PLEASE.THANKS FOR USING FIX-YA. GOOD LUCK
SOURCE: 97 grand am wont start
It sounds as if you still have a problem with the anti theft system. Possible loose switch wiring in the dash or it was programmed and cycled incorrectly.
SOURCE: my 2002 pontiac grand am2.2 suddenly wont
HAVE CAR HOOK TO SCANNER COULD BE IGNITION MODULE.
