Question about OfficeMax 0M96431 Shredder
Officemax mo.# OM99733 Crosscut Paper Shredder have stripped nylon gear. Where can I purchase gear replacement? thanks Derrick derrick.lee3@hawaiiantel.net
5 Suggested Answers
t_vinson57
  • 58 Answers
SOURCE: OM99733 15-SHEET SHREDDER
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Posted on Mar 27, 2009
t_vinson57
  • 58 Answers
SOURCE: Achiever, Model CCS 5000, shredder, need a part (a large nylon gear)
Good luck, Tom
  • 8404 Answers
SOURCE: Officemax OM96580 has a stripped gear tooth on the
If you expect to repair this, expect to spend weeks waiting for parts if you can get them at all, at least an hour to do the work and expect to spend 2/3 the price of a new one for the parts.
My advice, my friend, save the collection can, discard the shredder. On your new shredder, dont over feed it.
Thanks
Posted on Oct 14, 2009
Scroggrj
SOURCE: Need Nylon Gear for PX110MX Crosscut Shredder
I got mine from the following. Advanced Business Machines Co. http://abmco.webs.com/
Posted on Aug 29, 2010
My shredder has the sound like it is working, but it is not shredding.
From your description, it sounds like when you insert the paper the motor turns on, but the paper is not pulled into the shredder, indicating the two shredder cylinders are not turning. The most likely cause of this is a stripped (missing teeth) main nylon gear. These can be replaced but require some effort.
Apr 17, 2014 | Royal Office Equipment & Supplies
OM99732 shreader Motor operates but won't take in any paper. Motor is quieter than normal
When motor is running, look to see if the cutters are turning. The cutters can be seen by looking into the throat of the shredder. If the cutters aren't moving, the gears may have been stripped and shredder needs to be repaired or replaced.
Good luck.
Apr 14, 2011 | OfficeMax 0M96431 Shredder
I have an office max shredder OM99729 that quit working. the motor runs but it won't pull the paper into the shredder. I opened the cover and found the gear is stripped that runs directly off the motor....
I have the same unit witht he same gear off the motor that has a couple of teeth srtipped. Anyone out there know where to get a replacement gear?
Thanks...
Dec 22, 2010 | OfficeMax 0M96431 Shredder
Thanks! I have a 7x Crosscut Paper Shredder, Model # PCUA:29053U. The teeth are jammed due to I believe a build up of paper. I have run it on reverse & tried to pick out the paper. The motor runs but...
If the motor runs but the cutting teeth dont turn then you have stripped or broken a gear in the drive train. You can get replacement parts from Royal at 1-800-524-0799.
Oct 19, 2010 | Royal Office Equipment & Supplies
Officemax OM96580 has a stripped gear tooth on the nylon gear that meshed to the motor pinion gear
Thanks
Oct 14, 2009 | OfficeMax 0M96431 Shredder
Teflon gear driven by the motor gear stripped on our VF1012MX crosscut -paper shredder
Give Royal a call at 1-800-524-0799;... they will help regarding parts availability and prices.
Sep 28, 2009 | Royal Office Equipment & Supplies
The shredder jammed (too much paper) then stopped and won't shred. It makes a noise, but when I insert paper, it won't shred. Is there a reset button? I picked paper out of the blades with a pair of...
Chances are, the overfeed caused the teeth of the gear that operates off of the motor to break.
This is very common in less expensive machines. I don't know if OM will let you return it because I don't know there policy. Most of the time retailers will attribute broken gears to abuse, which in turn is not warranted. These machines are mainly mass produced in China and obviously are very cheap. The labor and part (s) to repair are more expensive than replacing the machine.
If you do, look for a higher quality German machine i.e. Intimus, Olympia, HSM or Dahle. They cost more but they have a nationwide service arena and parts are always available.
Mar 07, 2009 | OfficeMax 0M96431 Shredder
OM99733
Apparently this shredder keeps going until the bin is so full you can't open it easily. That is the problem we had with ours. After unplugging the unit, I pulled the bin back and forth using the front recessed handle until I could squeeze my hand in there. I wasn't too forceful fearing I would break the front door....and this took several minutes to accomplish. I grabbed as much paper as I could....espically the compacted mass in the top section. Eventually I was able to fully open the door and clean out the bin. Hope that helps.
~Mike
Oct 22, 2008 | OfficeMax 0M96431 Shredder
Good luck, Tom
Sep 04, 2008 | OfficeMax 0M96431 Shredder
OfficeMax 0M96431 Shredder Logo
307 people viewed this question
Top OfficeMax Office Equipment & Supplies Experts
ROCKIT957
Randy Schumann
Randy Schumann
Colin Stickland
Colin Stickland
Are you an OfficeMax Office Equipment and Supply Expert? Answer questions, earn points and help others
