Question about Grinders
Older sears bench grinder wont run 1/3 hp model 397 19581
This grinder hums and will not turn when plugged in unless you give it a spin. i dont have a wiring diagram and the wiring had been disconnected for years. the motor has no capacitor and no centrifugal switch but it does have a black rectangual looking item . i think it is a starter relay switch but i have no way of knowing how to test it or to hook it up. the windings coming off the motor consist of two larger wires and two smaller wires.the two larger wires are yellow and red and the two smaller wires are black and white. i have heard of two other grinders having this problem but i have no other like item to compare this grinder with to know how to correctly attach the wires. any help would be appreciated. a wiring diagram would be helpful. thanks
  • 2 more comments
  • grsmith149 Mar 04, 2009
    on the bench grinder , i removed the messed up remaining wires a few
    days ago. the wires had been taken off the bad off/on switch and
    operated by a two terminal house type light switch. it should have
    been a three terminal original on/off switch. however, some terminals
    wire ends broke off and i can,t tell where they went. by the previous
    messed up wiring, i could spin the motor after the hum sound and it
    would gradually pick up speed. i may could clean the rust off the
    terminals of the starter relay switch and wire it correctly with a new
    original off/on switch and get it to work. it,s sorta like, you can,t
    fix something unless you know how it works, or at least the general
    operating principals. a wiring diagram would really help. thanks for
    info
  • hikeorfly Mar 30, 2009
    I have same model grinder and the same problem., of no switch.
    sears-roebuck 397.19581 by reading grsmith's
    post and the various replys i was able to fix mine today. thanks a bunch for the help everybody. i'll try to describe the wiring in mine.
    my relay was labeled klixon 4CR-20-724, had 3 terminals.
    motor has 4 wires coming from it. red,black,yellow,white
    input is 110/120v ac black,white,green.
    green ground to ground screw inside grinder base.
    relay has one terminal on one edge, two on the other.
    white 110v neutral goes to single terminal on relay.
    black and red motor wires go to the other two on relay. the black was connected to terminal on relay that is even with the white terminal on the opposite edge.(i'm not sure if red/black are interchangeable?) red went to the other terminal on same side.
    black 110v line goes to one side of on/off switch,
    the yellow and white motor wires go to other side of on/off switch.
    runs fine. double checked with meter for any shorts etc.
    mine also has a gooseneck light that is wired thru same on/off switch,
    one wire to white 110v neutral coming in and other to the on/off switch
    on same terminal as white n yellow motor wires.
    hope this helps.
  • Dennis Boxerman May 11, 2010
    Usually, this type of motor has to sets of windings. One set is "Start" windings and the other are "Run" windings. Basically, it works like this. Upon start, the "Start" windings are in the circuit along with the "Run", they are wired parallel to each other but in series in the circuit. When the unit reaches it's running speed, usually in about one to one and a half seconds, the "Start" windings drop out of the circuit and the "Run" windings keep things going. The way you can tell which is which is to take resistance readings of the windings. The higher resistant set is the start windings, generally. The higher the resistance, the higher the starting torque.
    As far as the black, rectangular items is, you could very well be right. Makes sense. Some how, it would have to energize both sets of windings and when you let go, the start windings drop out of the circuit but the run windings stay in the circuit.
    Hope this helps.
    Good Luck
  • Jim London
    Jim London May 11, 2010
    Hi again, I answered your other post on this subject and since you have included a model number I have something to go on. As I told you before it had to be a cap or starter windings. This old motor has starter windings. I am confused however on your description. First you say it will spin if you help it but then you say the wiring has been disconnected for years. I would like more detail as this is important in helping you reconnect it. The black box is indeed a starter relay and that part is still available for $22. There are no wiring diagrams that I can find but it is not much different than newer ones. The fact that you say it runs is helpful. Can you get back to me with any more details, please.
  • 257 Answers
Hi again, OK, Well since I don't have a wiring diagram and the colors don't help. I am also going to assume it is 110VAC. The larger wires are probably the run or primary, it you remember which ones were connected it will help with polarizing. ( getting it to run in the right direction as well as the start and primary working together). You can use the two terminal switch but you should use a three wire cord. Use the switch to break the neutral and ground the case. The connections should be as follows: Connection 1, would have one of the primaries and one of the starts to neutral. Connection 2, the other start to the relay. Connection 3, the coil side of the relay to the remaining primary. ( if the relay has two connections on one end and one on the other it would be the single) Connection 4, the 3rd position on the relay to hot. That is how a split phase is wired. You may find a simple wiring diagram on the net if you type split phase motor wiring diagram. Good Luck to you, this should Fixya!
Posted on Mar 04, 2009
2 Suggested Answers
SOURCE: older sears bench grinder wont run 1/3 hp model 397 19581
Can you get a replacement? If not, we could probably figure out some suitable substitute.
Charlie
Posted on May 31, 2009
When I turn on grinder, the motor hums but wheels don't turn. I tried to adjust the wheel nuts and finally got the wheels to turn but the motor will stop with just a slight amount of pressure to the...
the drive belt is most likely broke, you can check with the store you got it from ,if they dont have they mite know where you can get one . I hope this helps you .
Feb 03, 2011 | Black & Decker Black Decker 5 In Crimped...
I have a ludell (machine tool) bench grinder. The problem is that the grinder disc will not turn. The motor hums but won't turn. I took the disc off and turned the shaft by hand with the powder on and it...
Ah, the start winding is not operating. When you turn the motor by hand. When the motor speeds up, do you hear a click sound? This is the start winding switch working. There might be a capacitor that is wired in with this switch that is used to start the grinder. If this capacitor is fried, the motor will not start. If the switch is shot, also the motor will not start. There could also be a wire or connector in this part of the motor that is not connected, or fried and not making contact. These are a few things to look for.
Jan 30, 2011 | Grinders
MOTOR HUMS. BUT BLADE NOT SPINNING.
See if you can turn the blades or reach a knife balde in to turn the blades....if something has jammed them.... get it removed... if they spin feely, then the motor is bad and replacement will probably cost more then a new one...
heatman101
Nov 30, 2010 | Krups 203-42 Electric Blades Grinder
I have cleaned it and now it won't start
Hi. Use the process of elimination. When it is pluged to the wall socket. does the motor hum? If yes, that means it is getting electric. If no hum, the motor is not getting electric and there is a brake in the wire or the on/off switch, most time it is at the plug. ( a lot of people just pull the wire out by pulling the cord , thus pulling the wires out and away from the plug prongs. I would UNPULG the chopper and try turning the the blades, they should turn back and forth, if they don't turn it could be a build up of coffee grinds and dust. If your handi take the thing apart and clean out the motor conpartment and oil it. The unit if made like everything today is made in China and there is no place to have it fixed. Take in to account the shipping charges to and fro. Then go out and try to buy one made in the USA. Good luck. Ron
Aug 27, 2010 | Cuisinart CBM18 Electric Burr Grinder
Grinder ceased working. I pulled it apart, found broken wire but had to pull fully apart to correct. Grinder now spins discs off and arcs badly at brushes. I think I have connected wiring wrongly. Can I...
you can try going to Makitatools.com and downloading a breakdown for this tool. If it arcing badly at brushes there could be a wiring problem or damage to the armature, check the wiring first and also the wheel spinning off might mean that you are running in reverse. did you take the field out of it and if so it might be in 180 degrees out. Let me know
Feb 14, 2010 | Makita 9005B 5" Electric Angle Grinder
It hums but won't turn. are there brushes? what is the black canister hooked to wiring going to motor? aloha, chip
Hi Chip , have you tried !!carefully!! turning the grinding wheels whilst the grinder is powered up and humming and does this start the machine , if it does your motor start capacitor ( a cylinder/tube with 2 wires or connectors on it ) will be deffective or the leads might have became detached from it , a replacement capacitor is quite cheap but you must replace it with the exact one ( a motor start/run capacitor of the correct Mfd or uF rating typically 30 uF/Mfd and at the correct voltage 110/220V )
if this dosent fix your problem most likely your motor start windings in the motor field coils are burnt out and the grinder is uneconomical to repair .
hope this helps .
Jan 22, 2010 | Delta Shopmaster 8" Bench Grinder
Bench grinder, 110/220?? wired up properly according to diagram on grinder, just turns on as soon as it's plugged in but it just humms, it does not spin the grinding wheel.it is a monster w/ a 3/4 hp...
LIKELY the capacitor which is usually in the base is bad.
The capacitor shifts the phase angle in one of the two windings which creates a pseudo rotating field to start rotation.
Nov 07, 2009 | Saws
I know this is an old post, but maybe it will help others looking for information.
I have the Craftsman 1/3-HP grinder models: 397.19580 & 397.19581.
They are Split-Phase single voltage (115 V), and use a Klixon start-up current style relay - 2CR14-224.
The relay is normally open. When the large starting current in the main/run winding circuit is sensed by the the relay coil (term 3 & 4) which is in series with the main winding, the relay contacts close (term 2 & 4).
The one end of the start-up winding is connected to the main coil's BLK wire in the coil pack.
When the relay contacts close the start-up winding is energized. The start-up coil is used to provide a boost to over-come the resting inertia of the rotor.
Once the rotor reaches between 65% - 75% of operating speed, the current through the main winding circuit is reduced to the point that the relay coil cannot over come the return-springs force, acting on the relay contact arm. With the contacts open, the start-up winding is no longer energized.
This should take about 2-3 seconds, if the relay malfunctions, the high current through the start-up windings (thin wires) may be damaged.
Here is a diagram I have made.
Klixon 2CR relays are no longer available.
You may find a suitable replacement here:
http://www.herbach.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=HAR&Product_
May 31, 2009 | Craftsman 6" Bench Grinder with Lamp
Grinders Logo
2,535 people viewed this question
Top Grinders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Tom Chichester
Are you a Grinder Expert? Answer questions, earn points and help others
