Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
How do you get the cap off to replace the gator teeth
  • Whirlpool Master
  • 3,361 Answers
Flat blade screw driver and pop the top cap off.
After that it depends on your model.
Either a 7/16 socket to remove the bolt and lift the agitator.
Or a 3/8 socket drive extension and remove the agitator.
Posted on Mar 04, 2009
John Deere Gator
check your gas tank screw on cap......if there is a breather hose coming out of the cap....make sure the hose is not kinked thus causing a vapor lock in the tank
Jul 07, 2014 | John Deere ATVs
Peg perego gator hpx gear slippage
Look carefully at each of the gears. Take them apart and I bet some of the teeth are sheared off. Order new gearboxes should fix the problem. This happened to us.
Aug 03, 2010 | Peg Perego John Deere Gator HPX Ride on...
How do we replace the rear wheels on the John Deere Gator?
remove the center cap then bend the metal push nut with a needle nose pliers and pull it off then pull the wheels off leaving the axle in place
Jun 07, 2010 | Peg Perego John Deere Gator HPX
John Deere Gator HPX 12 Volt Ride on Toy by: Can anyone tell me how to get the tires off of a j...
1. Remove the center caps from the rear wheels
2. use a 13mm wrench on each side and loosen the bolts
3. remove the rear wheels
May 18, 2010 | Peg Perego John Deere Gator HPX Ride on...
I am replacing the wheels on a john deere gator. Is there a trick to getting the wheels off and putting the new ones on. I thought I'd ask before I tried.
Dec 02, 2009 | Peg Perego John Deere Gator HPX Ride on...
Please let me know how I can change the rear tires of the John Deere Gator HPX 12 Volt Ride Toy
I want to add additional traction to my John Deere electric Gator. I have heard that you can somehow slip a bicycle tire over the plastic tires. Has anyone done this and how do you do it?
Sep 06, 2009 | Peg Perego John Deere Gator HPX Ride on...
Need to replace the gator teeth
Stand on the bottom piece and pull up hard on the top piece.
Mar 04, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Gear clicking in rear
Does it go in reverse without clicking? If so then the teeth are worn over to one side. If thats it you can swap the motor and gearboxes from side to side, left to right and right to left, and get a little more time out of them. Otherwise you will need to replace the gearboxes. There are plenty of places to buy them from and they are not hard to change. No special tools. Best source of info I have found is www.modifiedpowerwheels.com They have lots of info and its all free.
Dec 17, 2008 | Toys
Peg Perego Gator Ride On Toy
Sounds like the gears are stripped. If a bunch of teeth are missing, only the high speed gear will spin the gears fast enough to move the gator forward. I just bought a used one and found it pretty easy to tear apart and diagnose as similar issue. The gear boxes, located inboard of each wheel contain plastic gears and strip relatively easy if the shifter is moved , during motion from forward to reverse.
Aug 11, 2008 | Toys
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
35 people viewed this question
Dan Webster
Dan Webster
prem mathew
