Question about Matsonic MS8147C+ (N82E16813184008) Motherboard
Ms8157e on board video problems
How do I shut down the on board video , to enable use of agp graphics card ?
    Scholar:
  • 67 Answers
You would need to do this from the BIOS. You would gain access to the BIOS during the first boot screen prior to Windows. It will either be "F12" or the "del" key most likely.
Once there, you'll most likely be looking fo something related to Integrated Peripherals and specifically onboard video adapter. You'd want to select some sort of disable option for this.
Posted on Mar 04, 2009
Ok i have a Biostar P4M80-M4 Motherboard and i can not get it to sense any graphic card i own pci or agp. i have been told that i must disable the onboard graphics first and it wont work, i have tried...
Disconnect the hard disk and reboot - wait for its absence to be detected then shut down the pc , reboot and go into the BIOS and make sure the AGP is enabled. Shut down the pc again, insert the new video card, connect the monitor to it then start the pc and go into the BIOS - now you should be able to disable the onboard one.
Connect the hard disk and you're good to go.
Sep 05, 2011 | Biostar P4M80-M4 Motherboard
Ive installed the ati his radeon ice q graphics card and my computer will not boot,Why?
hook monitor cable back to your onboard video port then 1st make sure you have already downloaded the driver for your new graphics card. then at start up go into system setup and go to your display and make sure that you have your new graphics card enabled as your primary graphics instead of onboard video. it will say something like 1.Onboard 2. AGP/OR PCI MAKE SURE YOU DONT HAVE YOUR ONBOARD ENABLED AS YOUR PRIMARY VIDEO. AFTER THAT JUST SAVE AND EXIT THE JUST HOLD POWER BUTTON DOWN TILL PC SHUTS DOWN THEN SWITCH YOUR CABLE MONITOR CABLE FROM THE ONBOARD TO THE AGP/PCI CARD THEN RESTART YOUR PC. THEN YOUR PC WILL SAY FOUND NEW DATA AND WILL INSTALL THE DRIVER YOU HAVE DOWNLOADED FOR IT THEN YOU SHOULD BE OK IF THE CARD IS COMPATIBLE WITH THE MOTHERBOARD
Jun 07, 2011 | MSI KT4V (MS-6712) Motherboard
Agp texture acceleration not enabled
make suree that you installed correctly the video card software , then go to start then run,
type in "dxdiag" there you can enable your acceleration for your video card,
this thing helps?
Jan 11, 2010 | ATI RADEON® 9250, (128 MB) AGP Graphic...
No output from Geforce 6200 AGP
check in your bios settings that the correct settings is enabled if its pci or agp, maybe its some thing like this. hope this helps. also remove your drivers before your take out the card to changed it with another card, by add remove programnmes in control panel.
Dec 01, 2009 | XFX GeForce 6200 Graphic Card
Blue screen on my P.C.,windows shut down
If you are using an AGP or PCI graphic card try disabling the on board video adapter from BIOS.
Ensure that you have the latest drivers for this video card installed.
If the video adapter is using shared memory, then you may have a faulty RAM module.
Reinstall Direct X and any graphic acceleration software.
Go to BIOS and disable memory caching and shadowing options, this usually does not solve the problem, but you never know.
Contact video card or Motherboard manufacturer, there may be an issue between video adapter and your motherboard, or the specific software that you are using. In that case manufacturer may require to download a patch.
May 16, 2009 | Palit Microsystems GeForce 8400GS,, PCI...
Is visiontek a radeon hd 2400 pro agp 8 compatible w/ p4s800- mx?
ATI has recently written some better drivers for the 2400 Pro AGP cards,... Make sure the setting in the BIOS for the motherboard is set to the AGP or PCI for primary video. For AGP, make sure that you have the power from the power supply connected to the video card. Make sure that your motherboard does support 8X AGP video cards. If you are not sure, please check with motherboard manufacturer for compatibility.
Dec 13, 2008 | VisionTek ATI RADEON HD2400 Pro Edition...
I have a Sony Unit - with ASUS P450-VX motherboard. I put in a AGP video card in it and it works fine except on cold boot -in POST, The onboard video is used (only on cold boot - once the AGP card is...
I'm not exactly sure what you are explaining but to disable in Windows go to: My computer: Properties: Hardware: Device Mgr: Graphics Card and for the one listed that is not your AGP card click: Disable This Device. It's just that simple. Also, in some BIOS,maybe all, there is an AGP: enable/disable box. This of course should be enabled.
Dec 11, 2008 | ASUS Terminator P4 PC Desktop
Motherboard installation
Hello mecompe,
If you installed an AGP graphics card before your fist boot of the system, you will not receive display. By default the onboard graphics is set to boot display. (If this is the case, remove the AGP graphics card & boot the system). The Asus P4SGX-MX can only use a 4x AGP 1.5volt (only) card.
There is an order of sequences to perform before installing/ adding an AGP graphics card on to the board when the board also uses an integrated graphics card.
First, shut down the system & unplug the power supply from the PC. Connect your monitor to the VGA port at the rear of the board. Remove the AGP card. Re-connect the power supply & boot the system. You should have display? Re-boot the system. As the system starts up press the delete key on the keyboard every 2 seconds. The bios main menu will load. (Open your manual). Go to
section 2.4.3, page 2-20 under Advanced, PCI configuration. Set Primary VGA bios to
[AGP VGA Card]. Save the bios & exit. The system will auto restart. Press & hold the power on/ off button on the PC case until the system shuts off. Unplug the power cord from the PC. Insert the AGP card into the AGP slot. Connect your monitor to the AGP card.
Check all internal data & power cables, (Incase something came loose). Re-connect the power cord & boot the system. You should have display! Install your video software.
If your using the integrated VGA PCI graphics card, go over the bios settings page 2-18 & 2-20.
Need the Asus manual? Click this link;
http://support.asus.com/download/download.aspx?modelname=P4SGX-MX&SLanguage=en-us
To view the manual you'll also need Adobe PDF reader, click this next link for Adobe.
http://www.adobe.com/products/reader/
(The green led (light), means standby. The board is receiving 5volts DC.
If you still do not have display just let me know.
Good luck mecompe!
Mike
Oct 28, 2008 | ASUS P4SGX-MX Motherboard
PLEASE HELP WITH AGP SLOT DISABLE ON VECTRA XE320 ....
you can't enable/disable the AGP slot in your bios unless you have integrated Graphic card inside your motherboard ..
does your previous graphic card work with the motherboard ?
Dec 25, 2007 | HP Vectra Xe320 PC Desktop
Is my main board defective??
Hi, The problem sounds to me like you need to access the bios and make sure the AGP is enabled. If this is enabled then you may need to go to the manufacturers site and download the drivers for your board and operating system. With a P3 you should have no trouble running XP so if you are not using this already then perhaps you need to upgrade as XP has a very good set of drivers built in and will run most video cards and sound cards Regards mistyman
Aug 29, 2007 | AMD K7 , 800Mhz (amdk7800mpr24b)
Matsonic MS8147C+ (N82E16813184008) Motherboard Logo
128 people viewed this question
Top Matsonic Computers & Internet Experts
David
David
Robert Karst
Robert Karst
TheJustin
Are you a Matsonic Computer and Internet Expert? Answer questions, earn points and help others
