Question about Dell E228WFP LCD Monitor
Black LCD Monitor Dell Inspiron 8600
If I connect the laptop to a external monitor, it works fine. The LCD monitor is black and I hardly see the image, if I look deeply.
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Problem is going to be either the lcd or the inverter. Either the backlight is going out on the lcd or the inverter is not providing enough power to the lcd.
  • Dell Master
  • 32,281 Answers
Since the external monitor displays and dim image on the laptop's LCD screen then the fault is the LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on Mar 04, 2009
Hi, I have a dell inspiron 5100. I have two problems. 1) My screen is completely black and I have to use an external monitor. When I start my laptop, I can see the Dell Logo and after that is when...
for your video problem, you may be stuck in a different mode try holding the Fn key and hit F8 this toggles through the modes
1 - LCD on laptop only
2 - LCD and external Monitor
3 - External monitor Only
if this does not work you may have a LCD issue with the laptop .. let me know how it goes first
Feb 02, 2010 | Dell Inspiron 5100 Laptop
Dell computer monitor suddenly gone black
If the monitor remains black when you try to reboot, the CCFL (backlight) in the monitor has probably failed. If your look at the monitor from a sideways angle, you may be able to make out some graphics when the computer is on. If this is the case, you need to replace the CCFL or the whole LCD assembly. If you are uncertain, you should check the ribbon connectors going from the main case to the screen. If you get different results when on AC power, this could be a shorted battery or a bad power supply board. If your laptop has an output for an external monitor, you could use this to determine if the problem is with the monitor only, or with the graphics card and/or motherboard.
Dec 29, 2009 | Dell Inspiron 8600 Notebook
My screen on my Dell Inspiron Notebook went black. But I can barely see on the screen that the computer ran a problem check and said my computer was having a problem starting.
The invertor lamp has gone bad, so you would need to replace the LCD screen. there is nothing else you can do. try to connect an external monitor adn then press Fn + F8 to switch the video to the external monitor. if the image on the external monitor is fine then its the lcd. if the external monitor has the same image then motherboard problem. you can also try Fn + Up arrow key to increase the brightness.
Oct 16, 2009 | Dell Inspiron 1000 Notebook
AcerAL1714 LCD Not Connecting With DELL Inspiron 15 Vista Laptop
There is a symbol of Two monitors on F3 Or F4 button
1. Press Fn key and hold it
2. by holding Fn key press F3 key
Your monitor will start displaying
Oct 05, 2009 | Acer AL1714 17" LCD Monitor
Monitor does not work, computer starts up, dell prompts load, windows prompts load then screen goes black. i can hear everything loading but no display.
connect an external monitor on your machine and check if display is ok on the external monitor. if yes, try to re-install your video driver and check if display is ok on your laptop.
if both doesnt have display (external monitor and laptop's display) i suspected your lcd display is faulty.
Jun 30, 2009 | Dell Inspiron 6400 Notebook
Laptop has black screen, woks when hooked up to external monitor
just re-connect LCD connector properly its a loose connections. check also inverter maybe loose.
May 29, 2009 | Dell Inspiron XPS M140 Notebook
MY Dell Inspiron 8600 all of a sudden the LCD only comes up white
There will be a function switch to select the view mode ( Lap top monitor only/ LCD only / Lap top monitor and LCD Monitor) Select either the last two.
I hope this will solve your issue.
Good Luck.
If my solution proves useful please accept it.
Regards
Arjun
Apr 08, 2009 | Dell Inspiron 8600 Notebook
Need External Monitor to Work
The Fn +F8 combo will toggle between 3 options,
LCD
LCD and EXTERNAL
EXTERNAL only
Jan 25, 2009 | Dell Inspiron 8600 Notebook
Display after rain went black
If your video output works fine when connected to an external monitor, then the issue is with the LCD display panel. I’m afraid the only way to fix this is to have the LCD panel replaced.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Oct 19, 2008 | Dell Inspiron 6400 Notebook
Dell inspiron 1150 laptop black screen
Can you hear the Windows startup noises but can't hear it?
Does it work plugged into an external monitor? (Any good CRT or flat screen should work.
Be sure to plug in the screen before you turn it on.
If it doesnt output to the LCD automatically you may have to hit FN-F8 to switch to external.
If it works on external monitor you are just dealing with a screen problem of some sort - either a bad inverter or backlight in the LCD most commonly...
Let us know.
Dec 17, 2007 | Dell INSPIRON 6000 CENTRINO...
Dell E228WFP LCD Monitor Logo
189 people viewed this question
Alun Cox
