Question about Sanyo DP42746 42 in. Plasma Television
Bottom of the screen goes blank - Sanyo DP42746 42 in. Plasma Television
  • 71 Answers
Press pix button.
Posted on Mar 05, 2009
My phones are going blank on screen after I dial out or while dialing.
While the screen goes blank, does it drop the call? Are the handsets fully charged, or are they on the charging dock whenever they are not in use?
The batteries may need to be replaced. Bad batteries can in some cases cause the phone features to not fully work. They are located in the back, bottom of the handset.
Nov 21, 2014 | Uniden DECT15803 3 handsets and Chargers -...
One half of the t.v screen goes blank
Sounds like a back-light fault. Check its back-light inverter. To get more details, http://electronicshelponline.blogspot.com/Pull up older posts.
Nov 30, 2013 | Panasonic TH-42PX75U 42 in. Plasma HDTV
While watching tv the screen will go blank, sound
It might be a loose solder connection inside,try to prove it,the next time it goes blank,firmly give a whack to the back or bottom of the set,if it flashes back......sholud be a loose solder conn that a competent technician can find and repair
Jun 02, 2010 | JVC AV-32F704 32" TV
I turn my monitor on and it lights up then goes blank.
sounds like you have a backlight problem, the wires are known to burn off the ends of the bulbs of the back light..if you try to repair it yourself be careful the lcd screen and bulbs are frigile.. there is 4 bulbs two on the top and two on the bottom of the screen ,, keep every thing in order when taking apart
Aug 01, 2009 | HP w1907 LCD Monitor
Small text and screen blank top and bottom
try to replug the lcd connectors. you have to dismantle it
Jul 06, 2009 | Compaq Evo N620c Notebook
White blank screen
Hi...there,
If you got a white screen, then you need to replaced a new AD board. AD board is a piece of component that you plugged your VGA or DVI cables to the monitor. Good lucks, Have a nice weekend!
Sep 11, 2008 | Relisys RLT1720 17" LCD Monitor
My ? Nuvi 710 GPS froze. I restarted it , now all I can get is a blank screen with a black dot in the bottom left corner and a message saying press dot. Holding the off switch over to the left makes it...
My ? Nuvi 710 GPSicon1.png froze. I restarted it , now all I can get is a blank screen with a black dot in the bottom left corner and a message saying press dot. Holding the off switch over to the left makes it restart but still goes back to the same screen Is there any way I can fix this?
Apr 22, 2008 | Garmin GPS
How do you get the covers off? "Does not support this mode"
Well here I am again trying to get the covers off of an unfamilar device. I found the 2 screws at the bottom and removed them.. On a hp 1702 I just forced the sides open, pulling and bending to pop the cover off.. How do you get this mag cover off?
Problem indicates on screen "Does not support this mode" on power up, then screen goes blank. OSD doesnt work... blank screen... Does not support message looks good though for an instant...
Feb 16, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
1/2 screen blank
Sounds like a bad connection on or in the vertical output circuit, or the drive circuit. Could also be the vertical output IC or the surrounding componets going bad. Good Luck
Jul 21, 2007 | Samsung TXJ2754 27" TV
After power outage, TV screen is blank
It sounds funny but, unplug the set for 30 seconds to allow the TV to reset then see if the problem still is there.
Apr 10, 2007 | JVC LT-26WP84 26 in. LCD Television
Sanyo DP42746 42 in. Plasma Television Logo
35 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
