Question about Sharp AL-1642CS Copier
Getting double images on copies, how can I fix?
RE: Sharp AL-1642CS Copier
Just placed new toner cartridge and started to get double images on copies. Have now cleaned transfer charger, still getting double images. How can I fix?
    Problem Solver:
  • 14 Answers
It's one of two of these solutions. The fixing rollers more so the upper fixing roller which is the hot rollers at the exit end of the copier is dirty or need replacing. Or the drum has a cleaning blade on it that needs replacing. If you look at the drum and see if toner is still on the drum if so then your cleaning blade needs replacing. Also if that copier uses a blanking lamp then it might not be turning on so you can get double images.
Posted on Mar 04, 2009
We have a Sharp AL-1642CS Copier machine. That currently isn't working. What does a CH code mean?
CH code = Toner Cartridge is missing or not installed properly. In rare cases it is a defective toner cartridge. Also double check the right side and front doors proper closure.
Good Luck and Thank You for using Fixya.
Sep 22, 2010 | Sharp AL-1642CS Copier
I am trying to install a new toner cartridge and am getting a CH error. How do I fix?
make sure all doors and covers are completely closed. toner bottle may not be in proper position
Oct 07, 2009 | Sharp AL-1642CS Copier
I have a Sharp AL- 1642CS - broken transfer wire
so does that mean that you were getting blank copies and the transfer wire is broken?
Jun 25, 2009 | Sharp AL-1642CS Copier
I replaced the Sharp AL-1642CS TD toner cartridges twice. Still flashes the toner symbol. Someone mentioned cleaning the toner sensor. Where is the toner senor located? drjanisch
Where the toner bottle inserts into the holder, make sure the OLD bottles nipple is not stuck in there, this issue will not allow the new toner to flow into the system and the machine thinks it has an empty bottle
Apr 04, 2009 | Sharp AL-1642CS Copier
Toner error message on copy machine
Is "CH" steady or flashing? If it's steady, the door is not shut properly.
If it's flashing, the machine doesn't detect the presence of the toner cartridge (defective toner cartridge). Try another toner cartridge (an empty cartridge will do).
To get the blue handle to stay locked sometimes takes fiddling with it when the cartridge is in.
Dec 07, 2008 | Sharp AL 800 Copier
Printing problem on Sharp Copier Al 1642CS
it would have spilled toner on the laser unit glass which can be accessed after removing the developer & drum units. Its on the upper part inside the machine in the drum chamber.
Nov 28, 2008 | Sharp AL-1642CS Copier
Sharp AL-1642CS making blank copies
You have a door on the right side of the machine. in that door is a thin piece of wire mounted inside a bracket. The bracket is white and is at an angle in the door. Do you see that now?
Jul 17, 2008 | Sharp AL-1641CS Laser Digital Copier
AL-1642CS
try to clean the cover glass at the top of the copier with alchol.
be sure that ther is no any dot or lines on top of the glass specialy the right side.ok
Apr 16, 2008 | Sharp AL-1642CS Copier
Sharp AL-1642CS
did you replace the developer?if not try to replace it first ok.
Apr 11, 2008 | Sharp AL-1641CS Laser Digital Copier
Sharp al-1642cs
if scanner is not going all the way back you need to ck the home posinson senser it may be dirty.
Feb 05, 2008 | Sharp AL-1642CS Copier
192 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
