Question about Western Digital My Book Essential 500GB External USB 2.0 - WDH1U5000N 500 GB Hard Drive
I can't locate my power adapter for my WD storage devivce
What is the secondary voltage required for power adapter for a aWD storage book model # wdh1u5000n
  • Lindsay Laing Mar 04, 2009
    I need the DC voltage required is it 12 volts too?
    Many thanks
    Master:
  • 404 Answers
They all use 12V , so just get any 12v transformer that fits
the amp is i think 3.1amp or near.
Posted on Mar 04, 2009
  • lotfi bouakaz
    lotfi bouakaz Mar 04, 2009
    yes, go to your hardware store ask for a 12v adaptor take your hard drive with you and makesure it fits the hole. and that's it.
Power plug it broken
The WD500gb external storage requires a specific adapter supplied by WD itself. You can have it fixed on the nearest electrical service center for your convenience or you could buy an adapter with the same rating (same polarity as well) so you could use your drive.
I'd still recommend purchasing the original drive either from ebay or WD site:
http://store.westerndigital.com/store/wdus/en_US/DisplayAccesoryProductDetailsPage/ThemeID.21986300/productID.108411100/categoryID.13096000/parid.13092600/catid.13096000
Hope this helps,
levibit
Dec 17, 2010 | Western Digital 500GB My Book World...
Where is the reset button to my Wd my book Ex harddrive,The lights at the front of the harddrive are flashing and when I connect it to the computer or medid player no icons show so I can look into my...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Note that W.D. has a "Customer Loyalty" program -- you can buy a new W.D. device, through the W.D. web-site, at a significant discount.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 16, 2010 | Western Digital My Book Essential 1TB...
My WD My Book 500 GB is not recognized by the computer, gets hot and vibrates
* the USB cable
* the power-adapter
Nov 18, 2010 | Western Digital My Book Essential Edition...
Can't turn on book. I have plugged it into wall. I pressed the round button on the front, was that a mistake? Wont' turn blue and power on. I have tried it in a plug I know works.
* the USB cable
* the power-adapter
For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge guarantee".
Nov 13, 2010 | Western Digital My Book Essential Edition...
MY WD sounds like it's powered up but there is no icon on my mac desktop
* the USB cable
* the power-adapter
Nov 11, 2010 | Western Digital My Book Essential Edition...
My Western Digital My Book Essential 1TB External USB suddently won't start,even though i'v plugged in the power cable, theres no lights nor sound coming out from it it just suddently happen out of nowhere
* the USB cable
* the power-adapter
Nov 10, 2010 | Western Digital My Book Essential 1TB...
Its totally not working, all pc cant detect it. i changed the wire already, re install the software. the model is WD10EADS. What I will do, can I recover the data? or Can i just use it again, if the...
* the USB cable
* the power-adapter
Nov 09, 2010 | Western Digital My Book Essential 1TB...
It won't power on. Was fine 2 weeks ago when last used. I have tried different electrical outlets.
* the USB cable
* the power-adapter
Nov 08, 2010 | Western Digital My Book Essential Edition...
The adapter to my Western Digital Book does not respond
The monitor requires a adapter with a current output of 4 amps. but the Western Digital Book adapter can only supply 2 amps (half the current required by the monitor).
This means using the WD adapter on the monitor will stress this adapter beyond its capacity and continual use of this adapter on the monitor will cause it to fail and/or switch off if it has overload protection.
If you are having problems with the 2 amp adapter on the WD Book, then the power adapter could be faulty or it maybe OK when the adapter cools down.
I suggest you get a 12 volt 4 or more amps adapter for the monitor.
You may need an adapter for the WB book too if the adapter is faulty.
Dec 06, 2009 | Western Digital My Book Essential Edition...
Is the secondary voltage required for a WD external storage book wdh1u5000n 12 volts DC?
There is no absolute answer to this, it depends on the USB ports of the computer. Normally on a dekstop it might not be required, on most laptops it would be.
But ... if there are ports available, I'd use them both all the time, reduce the risk of power problems.
Mar 04, 2009 | Western Digital My Book Essential 500GB...
Western Digital My Book Essential 500GB External USB 2.0 - WDH1U5000N 500 GB Hard Drive Logo
513 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
