Question about Toshiba 61H71 61" Rear Projection Television
I have a line going throught the center of the tv with no picture I have no clue what is wrong with it can some one help
  • Dave'stv Mar 06, 2009
    what is the IC and how would i fix something like that
  • Toshiba Master
  • 8,617 Answers
Vertical output failure. Most likely the IC has failed
Posted on Mar 04, 2009
Red indicator light is on but no picture or sound. Help!
If the indicator light is on but you get no pic/sound then you have a bad power supply on the unit. Since you are not sure of the warranty status your best bet is to call samsung (or get online with them) and they can check the warranty of it for you. If it is under a warranty they will set you up and if it is not then (depending on if you like the tv or not) you can contact a service center in your area and the repair is a pretty basic fix that shouldn't cost you an arm and a leg.
Aug 10, 2012 | Samsung LN-T4665F 46 in. LCD Television
My Toshiba 46XV540U LCD TV. Has ghost image plus many white vertical and horizontal line when it is turned on. These lines and the ghost image stay for 20 to 30 minutes and than the picture becomes clear....
Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish board that call T-CON board to do a replacement.This T-CON board sit in the middle at the bottom of the tv LCD screen panel.This T-CON board control all the picture pixels going throught to the tv LCD screen panel.
Jun 11, 2011 | Toshiba 46XV540U 46 in. LCD HDTV
Picture is greenish / purplish and curved lines at top & bottom of screen. definitely not an input issue, distortion is the same on all inputs and even on the menu/settings...
Very common problem throught out ur DLP tv live,will happen again again many times for the tv life times.Ur tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts must be replaced on the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 05, 2011 | Sony KP-65WV700 65" Rear Projection HDTV
My television has no picture just one thin line in the center. Does anyone have any suggestions as to what is wrong?
You have a problem in vertical deviation in your television.It's need to be repaired by specialist.
Sep 28, 2009 | Symphonic ST419E TV
RCA 52in stretched picture
1) Do you have a cable box or converter box hooked up to the TV? 2) How old is the TV ? 3) Is it a rear projection TV? 4) Does this happen when watching a DVD, Game Source, VCR Tape?
Feb 23, 2009 | RCA P52926 52" Rear Projection Television
Green line problem
I had the same problem when we hooked up an hd satellite box. It's a simple solution using the Philips remote that came with your tv. The dial in the center of the remote with up down left right control will move the picture left or right up or down by holding the direction you want to go. Make sure to stand in front of tv.
Oct 28, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Polaroid FLU-2632
I had the same problem. It's caused by the picture setting on your Sky box. Go ibto Services, select Picture Settings and set the mode to PAL not RGB.
Jun 07, 2007 | Polaroid FLM-2632 Television
Toshiba 61H71 61" Rear Projection Television Logo
51 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
