Re: i can't get out of my hands-free when i am not using...
I had a kind of same problem if your problem is; when u call u can hear from the ear piece but can not hear from the speaker, its no problem simply reboot it and it will start working
You have a speaker problem. Confirm this using a hands free device. If you can hear the conversation, the speaker problem is therefore confirmed. You would have to get the phone's speaker fixed, and this might not be something you could do yourself. So taking it to a neighbouring repairer could be the option. But in the mean time, pending when you fix the speaker, conveniently make and receive your calls using the hands free device.
Mind you, if testing with the hands free device did not solve the problem, it then evidently is a network problem, at which your mobile service operators are to be informed for further assistance.
This process erases from your Nokia 9300 all of your user data and
settings, including your phone book, calendar, email, downloads,
recordings, and certain factory installed programs such as Instant
Messaging and BlackBerry Connect.
REMEMBER: Create a device data backup or synchronization before formatting.
You can restore device data and settings later. See the Nokia 9300 User Guide for further instructions.
STEP 1 - Format the Nokia 9300 memory
* Remove the battery for 10 seconds
* Replace the battery
* Open the Nokia 9300 to view the inside display
* When you see the screen with "NOKIA" in blue text,
* Press and hold the following four keys until a Format Message is displayed:
CRTL + Shift + F
* Confirm the process by selecting Format
* Formatting will begin
* After formatting is complete the Nokia 9300 will reboot with some
basic settings. If prompted, accept the request to reboot
* Follow the instructions on your Nokia 9300 to set the time, date and city and to enter your contact information.
STEP 2 - Download the install-cingular-default-603.SIS to a compatible PC.
STEP 3 - Prepare a Multimedia Memory Card (MMC)1
* Transfer the .sis file from your PC to your device using MMC,
data cable, Bluetooth or infrared. For instructions see the Nokia 9300
User Guide.
STEP 4 - Install the file install-cingular-default-603.SIS to your Nokia 93002
Note: This step is required to install Cingular specific settings and programs to your Nokia 9300.
* Insert the Multimeda Memory Card created in Step 2 to your Nokia 9300.
* Replace the battery cover (so the Nokia 9300 can read the MMC)
* Open your device, then open the File Manager:
Press the Desk application key
Scroll to and select Office
Scroll to and open File Manager
* Using the arrow keys, scroll to Memory Card
* Highlight the file install-cingular-default-603.SIS
* Press Open to start the installation process
* Follow and accept all prompts and requests
* Reformatting is now complete
(1) You may choose to install the file above using Nokia PC Suite.
Please see the Nokia 9300 User Guide for general instructions to
install software using Nokia PC Suite, and follow those instructions
instead of Step 4 above.
(2) CAUTION: The .sis file above is ONLY intended for use with a Nokia
9300 with the appropriate software version. DO NOT install this file to
a Nokia 9300 with any other software version. DO NOT install this file
to any other model device.
Pull the battery out (or use a program like Roman Keller's Rebooter) and
when the Nokia big and little hands are showing on the screen, press
the CTRL, SHIFT and 'F' key at the same time. Your Nokia will be reset
to its FACTORY state and ALL data will be lost, so be warned!
You can use the headset enhancement directly when you make a call but for the hands free mode, your phone doesn't support that feature. Only nokia 1112 and above support hands free mode or it's loudspeaker mode but not in nokia 1100.
It seems that your phone is in Offline mode, to bring it out from Offline mode press the power button on your phone once, it shall give you the options to change profiles, switch off the phone, etc. from there select the General profile and then check if you can make the calls?
ALL YOU HAV TO IS TO FORMAT YOUR NOKIA 9300 USING KEY CTRL+SHIFT+F, YOU MUST TYPE THIS KEY WHEN YOU PHONE STILL APPEARING THE WORD NOKIA ON BOOTING SCREEN DONT WAIT TO SEE THE HANDS IF SO U R LATE
