WHERE IS TTHE SOURCE I HAVE IT PLUGGED IN?
You need to go into the menu and actually switch the aux to on. If you have your owners manual it will tell you how to turn it on. It is under the menu option "built in auxiliary input setting" If you do not have the manual i have a link to it for you. Hope this helps.
http://inform3.kenwoodusa.com/manuals/KDC-MP435U.pdf
I put the radio in "stand by" mode and then hit the "menu" button, I used the big knob to scroll down to where it said AUX OFF, you simply push the knob to the right and it turns to AUX ON and thats it!. Now when you go through the sourcs button you'll see AUX.
thank you Socal Chuck i fix mine it work
I have the same problem. The manual states :
in the standby mode.
Built-in Auxiliary input Setting.
Set the built-in auxiliary input function.
then it says:
Display Setting
Aux off when selecting the source there's no auxiliary input
aux on when selecting the source there's auxiliary input
but none of this tells you how to access the aux once it is in standby mode. flipping through the src mode only shows usb, standby,cd,and tuner.
no aux.
if anyone can help it would be greatly appreciated!
