Question about Dryers
My husband just bought me the Roper red4440vq0 dryer from lowes. However when you dry something in it it takes almost 90 minutes for something to dry.
  • 547 Answers
Make sure vent is free of bends and is direct to outside thank you for useing fixya please rate me
Posted on Mar 03, 2009
Kenmore dryer 90 series
Since no model number was given, check to see if you have a setting commonly noted as "wrinkle guard", "wrinkle shield", "press care" or something to that affect. Those settings will run the dryer for as much as 90 min after a completed drying cycle to prevent wrinkles in clothing, allowing you time to remove the cloths after a dry cycle if you are busy. Pleazer Appliance...
Apr 09, 2014 | Dryers
Takes 2 cycles on high to dry cloths. i hooked osiloscope up to it and it will draw 22.5 amps for about 25 seconds and bounce between 2 and 7 amps for about 90 seconds and keep repeating this way (on high...
Hello. Generally, when clothes take a long time to dry the problem is excessive lint in the exhaust pipe. pull the dryer out from the wall, disconnect the vent pipe and remove lint going to the outdoors and also back inside of the dryer. Regards, joe
Dec 07, 2009 | Roper RES7648E Dryer
Clothes taking more time to dry than normal
First, ensure the exhaust is not restricted, this includes the actual blower. if all is well in the exhaust, test the hi/limit therm stats. lety me know what you find
Apr 07, 2009 | Dryers
Dryer not drying
You have a venting problem and air is not leaving. Its either kinked or clogged.
Mar 29, 2009 | Dryers
Dryer takes longer and longer to dry
The dryer vent may be partially blocked. First of all check the outdoor end of the vent to make sure it is not covered with something, in the north snow is often the culprit. If that end is clear, pull out the dryer and disconnect the vent pipe from the dryer then check inside with a flashlight to make sure it is clear. Remove any built up lint. that should do it.
Feb 05, 2009 | Roper REX4634KQ Electric Dryer
Warm heat..clothes not drying
john there is only one heating element.ither it works or it dosent.when acustomer complains of low heat or long dry times 99out of100 its the venting or the dryer is blocked with lint.remove the dryer from the venting and try a load.if better clean house venting.you .........if not better you should have a great air flow leaving the dryer so if not drying well with venting off.take dryer apart a clean all araes that air is moving,where lint can block that flow.god bless .tom
Jan 01, 2009 | Roper REX3614KW Electric Dryer
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
Dryers Logo
130 people viewed this question
Top Dryers Experts
