Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Convergence setting on Philips 60PP9202
Can't adjust convergence on my remote
  • Anonymous Apr 27, 2009
    I have a color issue with mt tv. It is blurry. I cant do any thing with my remote. Any Ideas?
  • Philips Master
  • 8,617 Answers
Convergence circuits have failed you can get the DPtv305-DPTV345 convergence repair kit at the following link. The kit contains Both ICs and all 12 feed resistors plus step by step instructions on how to do the repair.
http://servicemanuals.vstore.ca/
Posted on Mar 04, 2009
How do I adjust the convergence
In some cases you will need the original remote to adjust convergence. Check that first. You can also find more detailed guides on www.TvRepairKits.com - there is a tips page with service mode codes, etc, also.
Jan 29, 2013 | Philips 60PP9202 60" Rear Projection...
I have a Philips projection screen hd tv great picture but the color is way out off adjustment
see attached photo, it is a convergence problem.
If you have similar problem in customer menu is a way with the remote to adjust.
If it will not adjust there then the convergence chips are bad.
SD TECH
Oct 30, 2011 | Philips 60PP9202 60" Rear Projection...
Having i think convegence board problems with my phillips model # 60pp9202/17F called tv repair guy said it was my convergence ..colors are alll orange and bottom of picture kinda bubbles up can i replace...
Replacing the convergence board will require a complete convergence adjustment. A better solution would be the replacing of the defective convergence IC. This would retain the convergence settings for the set. I'll locate the part numbers and costs and update this later.
Dan
Aug 31, 2010 | Philips 60PP9202 60" Rear Projection...
We have a philips projection tv 60PP920217F we can not alighn the blue color the picture is concaved on bottom and top
This is a convergence problem and can be repaired by replacing the two STK-392-120 convergence chips and adjusting the set with the original remote control
I have specific instructions for this repair from start to finish.
SD TECH
Feb 16, 2010 | Philips 60PP9202 60" Rear Projection...
Philips 60PP9202 red shadow in the battom of the screen
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly.
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 05, 2009 | Philips 60PP9202 60" Rear Projection...
BLUE CONVERGE NOT WORKING
most likely convergence IC's usually 2 of them
Aug 10, 2009 | Philips 60PP9202 60" Rear Projection...
Convergence board
You can just swap the boards - then use your remote to goto the convergence settings screen to reset the blue and red allignments. Its fairly simple.
Dec 30, 2008 | Philips 60PP9202 60" Rear Projection...
Convergence
If the convergence can't be adjusted with the remote are if a tech comes out and he can't adjust it from the back of the set or the SAM replace the SSM part number 313503710091 that's where the convergence adjustments are done.
Aug 19, 2008 | Philips 60PP9202 60" Rear Projection...
Phillips 60pp9202 60 in
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Mar 08, 2008 | Philips 60PP9202 60" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
386 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
