Question about Kenwood Food Mixers
Need a new k beater blade for kenwood chef mixer km210
Looking for Kenwood bowl 28589 for KM210
Hi, are you after a used or brand new?
Nov 19, 2013 | Food Mixers
Have a 20 plus year old Kenwood chef [navyblue and white] don't know the model number. When the K beater or whisk are attached they rotate for a few seconds then fall out any ideas what to do
for both attachments to fall out the planet hub must be worn out. check that there is a spring clip in the groove of the beaters. if you have had it repaired recently it may be running backwards which woluld eject the attachments.
Aug 18, 2010 | Kenwood KM300 Chef Stand Mixer
Kenwood chef a701 beater shaft is broke can i buy a new one
yes go to kenwood web site look for dealers who still support a701 mixers.
Apr 06, 2010 | Kenwood KM800 Major Classic Stand Mixer
I need a splashguard for standmixer rival select model KM210
I need one too so if you find a fit, be sure to post it. I thought I was buying a replacement. Unfortunately it is a DeLonghi product made for round bowls and has a flap on the side, not the front, so it won't fit the bowl.
Nov 30, 2009 | Kenwood KM300 Chef Stand Mixer
Manual for km210 please
kitchen.manualsonline.com/ex/thread/view/.../2371332
www.manualsnguides.com/search.php?cmarque...KM210 use this link
Sep 11, 2009 | Kenwood KM300 Chef Stand Mixer
Kenwood Chef A701A Blender needs new shaft seal
It uses a different thread = turn clockwise to undo - not the normal turn ccw to undo and the nut is attached to the 2 blades.
Jan 11, 2009 | Kenwood KM300 Chef Stand Mixer
New Kenwood chef km 001 - I can't get the beaters out!
Try turning the beater in the reverse direction to the direction it normally turns - clockwise looking at the beater (I think), this should make the shaft pins ride up on some cams which should release the beater.
Sep 23, 2008 | Kenwood KM800 Major Classic Stand Mixer
The K Beater
It is most probably the nickel plating seperating of the the beater surface unless it is actually hitting the side of the bowl. You may need to replace the beater as it is not good to eat food with metal in it.
Ashburton
May 17, 2008 | Kenwood KM400 / KM410 Chef Classic Stand...
Food Mixers Logo
380 people viewed this question
Top Kenwood Food Mixers Experts
EugenesDIYDen
EugenesDIYDen
Electro Med Services...
Are you a Kenwood Food Mixer Expert? Answer questions, earn points and help others
