Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Motor burned up & now it shuts off with new motor
I have a Whirlpool Ultimate Care top loader washer. First the motor burned up so I replaced the motor but now it keeps shutting off once it starts washing. You can manually twist the knob around & turn it back on but it will wash for a few minutes & then shut off again. What in the world id going on????? Is that like an enternal breaker or something shutting off the motor so it doesn't fry or what????
  • Whirlpool Master
  • 3,361 Answers
There may be a clog in the drain pump that is stopping the motor.
Remove the drain pump from the motor and run the machine in the agition mode.
Did you replace the run capactitor also?
Posted on Mar 04, 2009
How to fix a broken belt of motor of whirpool wash ultimate care 2
  • Replacing the Belt in a Whirlpool Ultimate Care II ' Home ... homeguides.sfgate.com > ... > Mortgage-Backed Securities Replacing the Belt in a Whirlpool Ultimate Care II by Rogue Parrish. Email; ... The Ultimate Care II washer, ... it may have a broken belt.
  • Whirlpool Washer: Ulitimate Care II - YouTube www.youtube.com/watch?v=bVmjmSzMXHE
    • BY CHERRY HILL
    • 3 MIN
    • 36K VIEWS
    2012-05-30 · Video embedded · Whirlpool Ultimate Care II: ... This is fully funcational washer. Direct Motor Drive works perfectly through each ... Whirlpool Washer: Ulitimate Care II
  • How to replace a broken dryer belt. Whirlpool Ultimate ... www.youtube.com/watch?v=PU8QZeDRl_0
    • BY BAILSOFSTEEL
    • 5 MIN
    • 3.5K VIEWS
    2015-04-04 · Video embedded · This video shows me replacing a belt in a Whirlpool Ultimate Care II ... a broken dryer belt. ... Whirlpool ultimate care II clothes washing
  • http://www.bing.com/videos/search?q=broken+belt+of+motor+of+whirpool+wash+ultimate+care+2&FORM=HDRSC3
    Jul 15, 2016 | Washing Machines
    How do I repair my Whirlpool Ultimate Care 2 LSQ9549L Top Loader Washer?
    check the motor coupling,if the coupling is broken you'll hear the motor run but the agitiator won't move and no spin,the coupling connects the motor to the transmission.watch this video
    http://www.youtube.com/watch?v=9K1KHEogf3c
    May 30, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
    Need to replace coupling between tub and motor? How does tub come off?
    If you are referring to the motor coupling, it is actually located between the drive motor and teh gearcase. You DO NOT have to remove the wash tub in order to access and replace it. The following link explains step-by-step how to replace a motor coupling on a Whirlpool top loader:
    http://www.fixya.com/support/r3574231-replacing_a_motor_coupling
    If you have questions about this repair, or if the model washer you have differs from the one you listed this question under, please post back and let me know. I hope this helps you.
    Apr 19, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
    Whirlpool Ultimate Care will not stop spinning
    I work on these every day for the past 8 years and have never once seen this problem. If i had to guess i would assume its a stuck contact on the timer. The timer is the only thing that sends power down to the motor but its an expensive guess.
    Hope this helps _MJ_
    Jan 29, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
    Washer motor runs, but the drum does not spin on the spin cycle
    It is most probably the motor coupling if you have a Whirlpool top loader.
    Ash
    Oct 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Agitating, ticking noise and then burning rubber smell
    HI, the motor is failing slowly and, i recommend replacing this damaged motor asap before it starts to over heat and present a fire hazard.
    Jun 04, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
    Whirlpool Ultimate Care II washer went dead during fill cycle
    Start with the capacitor. It has a funny smell when they go bad. The motor will smell bad as well when it burns up.
    May 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    go to www.repairclinic.com enter model number and the first part you see may be the culprit. This part is located between the transmission and the motor. To see if it is broken you'll need to tilt it back enough so that you can take out the pump and the motor each individually and if any of the six finger look things are broken replace the part. My in-laws had this problem and now i'm the fav in-law. By the way it's an easy task.
    Apr 06, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
    Slow agitating
    Sounds like a failure in the gear case but the burning smell makes me wonder if you have a problem with the motor. You will need a appliance tech to verify
    Feb 26, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
    Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
    50 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
