Question about Radio Shack Pro-96 Scanner
Pro 96 not picking up APCo 25 transmissions. Had it in the store - they cant figure it out.
  • 1 more comment
  • mriley7212 May 08, 2009
    Albany county in New York
  • mriley7212 May 09, 2009
    I have the scanner all programmed. It just will not pick up Colonie. Even Radio shack store managers can't figure it out.
  • Robert McClure May 11, 2010
    what state and county are you in
    New Friend:
  • 160 Answers
Http://www.radioreference.com/apps/db/?ctid=1825
Posted on May 08, 2009
  • Robert McClure May 09, 2009
    what more do you want then
Is this APCO-25 capable,the APCO-25 is the digital
No. The PRO-97 can receive both standard and trunked analog signals, but it is not digital capable. Also, there are no add-on boards or circuit modifications that can enable digital operation.
Bill B.
Listening in since the 60's
Feb 17, 2011 | Radio Shack Pro-97 Handheld Scanner
How can i get my pro 164 to pick up digital broadcast frequencies
Sorry, but your PRO-164 is an analog-only scanner. There's nothing you can do to or with it to receive and listen to digital transmissions. If digital systems are in use in your area you'll need a digital (APCO-25) equipped scanner to listen in to them.
Bill B.
Jan 11, 2011 | Radio Shack Pro-97 Handheld Scanner
I have a uniden bearcat scanner and cant pick up my local police dept. I put the frequency in and still dont hear anything. I have a bc145xl 16 channel scanning radio and want to know if its compatible...
If you programmed the correct frequency, you should be getting reception. Check www.RadioReference.com to verify the frequency. Otherwise, you may be too far from the transmitter to receive signals. Try your scanner in other locations, check your antenna, and try receiving the PD on another scanner.
The MARCS - Ohio Multi-Agency Radio Communications system - is a Motorola Type II SmartZone Omnilink Trunking system that utilizes APCO-25 digital transmissions. Your BC145XL is not compatible with trunking or digital systems. In order to follow the MARCS you will need one of the following scanners:
GRE PSR-500, PSR-600
Radio Shack PRO-106, PRO-197, PRO-96, PRO-2096
Uniden BC250D, BC785D, BC296D, BC796D, BCD396T, BCD396T, BCD996T, BCD996XT, or the brand new HomePatrol-1
Bill B.
Nov 11, 2010 | Radio Communications
Is the pro 2055 digital ?
The PRO-2055 is a versatile conventional/trunking scanner, but it does not have the capability to monitor APCO-25 digital transmissions. For an operating manual that is "Easier To Read" than the factory operating instructions, follow this link:
http://marksscanners.com/97/97.shtml#receive_modes
Bill B
Sep 09, 2010 | Radio Shack Pro-2055 Base Scanner
How do i program my scanner
Your scanner is capable of receiving conventional, trunked, and digital (APCO-25) signals. As such, programming options are detailed and much too involved to be presented here. I suggest that you review the operating manual for your scanner (which can be downloaded/printed by following the link below), visit www.RadioReference.com for a comprehensive database of active frequencies and systems in your area, and consider joining a users group for the PRO-96. You can find groups on RadioReference, Yahoo, etc.
http://scancat.com/OnLineHelp/OEM_Radio_Owners_Manuals/RadioShack-OlderManuals/Pro-96/pro96.pdf
Bill B
Apr 27, 2010 | Radio Shack Pro-96 Scanner
Can the pro-94 receive digital signals
Unfortunately, no. The PRO-94 can monitor conventional or trunked analog systems, but it cannot process digital signals. To do that you'll need a scanner that specifies DIGITAL, APCO, APCO-25, or P25.
Need the manual for your PRO-94? You can download/print it here:
http://support.radioshack.com/support_electronics/doc61/61426.pdf
For a comprehensive database of active frequencies and systems in your area, visit:
BillB
Jan 19, 2010 | Radio Shack Pro-94 Scanner
Some frequncies come in with tone not voice ,lower channels come in but higher one started this morning
find out if what you are listening to has gone to digital... in particular apco 25. if so you'll need at the minimum a scanner that will work on apco 25. look at the specs on a pro-96 to see what you will need.
Jan 11, 2010 | Radio Shack Pro-2051 Base Scanner
Radio Shack PRO-96 What mode do I use for scanning==866.600 to 868.450 range and 44.82 to 155.175. The choices are== AM Mode (AM) FM/Digital (FM) CTCSS Mode (CT) DCS Mode (Dc) Motorola/APCO-25 Trunking...
You more than likely want the FM mode. If you are listening to a trunked agency then you will have to know if they are on the MOT, or EDACS system and choose the correct one.
Mar 24, 2009 | Radio Shack Pro-96 Scanner
Just wondering???
LA probably uses a trunked system or APCO 25, you can find out more at www.radioreference.com go to the data base and click on california, then click on the county and it should tell you the frequencies and which systems they use.
Jun 25, 2008 | Radio Shack Pro-96 Scanner
Radio Shack Pro-96 Scanner Logo
241 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
