Question about Microsoft Windows XP Home Edition
Active X controls error msg on computer
I have a printer problem. I tried to reach troubleshooting for printer. I can't get the page which I have used repeatedly because
Error msg ''Active X controls couldn't be displayed as 1)security setting prohibits running on this page 2) blocked a publisher of one of the controls.
What I have tried 1) removed webroot spy sweeper (not the problem)
2) went into security under tool to change settings for this feature...made no difference
3)downloaded Active X control
still the same error msg that prohibits my use of the troubleshooting guide for printer
Any thoughts about what to try?
I have been at this for days and am rough around the edges
Thanks jan
  • Anonymous Mar 30, 2009
    activex controler couldn't be displayed
    Problem Solver:
  • 14 Answers
Http://msdn.microsoft.com/en-us/library/aa751972(VS.85).aspx try this link its help u pls dont forget to rate me
Posted on Mar 04, 2009
What does error 20 mean
Who is the printer manufacturer?
The error may be caused if the wrong printer is set as the default printer, the printer driver is missing, or if there are conflicts in the device manager.
Step 1:
Make sure the desired printer is set as the default printer
http://windows.microsoft.com/en-US/windows7/Change-your-default-printer
Step 2:
Re-install the USB Composite Device from Device Manager
a.ClickStart and then Run .
b.Type devmgmt.msc in the Run window and then press Enter to open the Device Manager Window.
c.Click the plus sign (+) next to Universal Serial Bus Controllers.
d.Right clickUSB Composite Device , click Uninstall , and then clickOK .
e.Disconnect the USB cable from the computer and then reconnect it.
f.Follow the instructions in the Found New Hardware wizard to install the drivers.
g.Right-click the printer icon, and then clickPrint Test Page to print a Windows self-test page.
h.Close all windows and try printing from the application you were using before.
Step 3:
You can also try runningPrinter troubleshooter and check.
http://windows.microsoft.com/en-US/windows7/Open-the-Printer-troubleshooter
Aug 16, 2016 | Office Equipment & Supplies
OKI c6150 with error msg 002-fatal error. please, I need a quick answer. do not have time to scroll through pages of older posts
If you printer has an additional memory card fitted then remove it (powered off of course) and turn on and see what happens. If the fatal error is still there then with the age of the machine (getting on in years) it is better to replace it as the error refers to the cpu in the control board and that's expensive on older machines to replace.
Jun 20, 2016 | OKI C Office Equipment & Supplies
How do I reach this special page to ?get the activation code on.
Windows activation or validation fails and may generate ...
https://support.microsoft.com/en-us/kb/921471
Microsoft CorporationDiscusses that activation or validation fails and generates error code ... Level: Error Description: Acquisition of Secure Processor Certificate failed. ... To do this, follow these steps for your version of the operating system. ... Volume Activation error codes on Windows Vista-based computers ... Get help with activation errors
Standalone Product Activation FAQs - SOLIDWORKS
https://www.solidworks.com/sw/.../1090_ENU_HTML.htm
SolidWorksWhat does SOLIDWORKS do with the computer-specific information sent during the ...Does product activation make the software harder to use? ... number which is then down sampled to reduce the size of the activation request code. .... name, version, and language; and your computer's processor and hard-disk type.
Activation Keys and Serial Numbers
georeference.org/doc/activation_keys_and_serial_numbers.htm
Jan 09, 2016 | Computers & Internet
Printer not functioning properly,download software will no install, get error msg
What make of printer ?
What is the error message ?
click start control panel administrative tools computer management then select event viewer depending on what operating system you have this may vary
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
you might be able work your way through the problem
if it's a program file you might uninstall the program restart your computer then reinstall some of these files/software if its driver related
you might have to uninstall the printer restart your computer then reinstall your printer
click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port
you might see a yellow? ! question exclamation mark or a red X this will mean you need to install a new driver for this device right click you will have options to update driver disable uninstall or select properties again you will have the similiar options also you can troubleshoot the device
Mar 08, 2014 | Computers & Internet
I use outlook 2003 and this error msg. for the first time today, I get the error message when replying or forwarding and email: One or more ActiveX controls could not be displayed because either: 1) Your...
ok well its what it is sayin , i will bet if you go into your setting your active x controls are not clicked, and if its the sending look at your spam controls i will venture a bet the sender is on your blocked list. or a known spanner that your anti virus is blocking.for active z goto
open ie, goto top of page and select tools, internet options, then advanced scroll down and look for the word active x , and click it on . turn off machine and reboot.
Mel
Jun 02, 2010 | Microsoft Outlook 2003 for PC
Dell 3110cn - Load MPF 024-969 letter plain error msg
dell mfp laser 3115cn giving me 024-969 no paper detected
Oct 26, 2009 | Dell 3110cn Laser Printer
Epson Stylus C3200 Red Error Light Stays On
Ink level at chip reach zero. Reset ink level counter using hardware resetter. Or Use CISS chip with autoreset.
Jun 15, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Operation failed due to print spooler.
Try downloading the drivers from the following location. This should solve the issue:
http://software.canon-europe.com/products/0010383.asp
Apr 09, 2009 | Canon PIXMA iP1300 Printer
Microsoft Windows XP Home Edition Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
