Question about E-Machines eMachines Desktop PC
No Power I have a T2885 emachines. I cannot get it to power up at all. I took off the cover and plugged it in and saw a small green led light on the motherboard. Does this mean it's not the power supply that needs replacing? Any suggestions would be recommended
  • Matt H
    Matt H May 11, 2010
    If the green light is on, the motherboard is getting power. Do the fans spin up at all when the power button is pressed? If not, it may be a problem with the motherboard. Ensure the power switch is proper plugged into the motherboard and isn't lose or not attached. You should be able to follow the path of the twisted wire combo from the switch to the motherboard location.
    When working in computers, be sure to always discharge static electricity by touching a bare, unpainted piece of metal such as the power supply chasis or wearing a static wrist guard.
    Master:
  • 404 Answers
No it means its a dead motherboard.
Posted on Mar 04, 2009
Have an emachine T2885 took side panel off to clean put back on now no power. and there is no switch in back so i couldnt of turned it off
Nothing serious, sounds like you may have accidentally disconnected some of the wiring by accident while wiping the dust away! Just reopen it and check what's unplugged in the system. - Hope that helped =]
Mar 23, 2010 | eMachines T2885 PC Desktop
Took side panel off to clean the inside put it back on and now i got no power please help
Check that you did not turn off power switch on the back of the cpu. That switch has to be on before the one in the front of the unit will work.
Mar 22, 2010 | eMachines T2885 PC Desktop
Emachine wont start up
This is a DESKTOP machine, not a laptop. It has to be plugged into a wall outlet that has power, for the machine to run.
Jan 05, 2010 | E-Machines eMachines Desktop PC
I have an E-Machines T2885 that has a green light on the motherboard I did try a different power supply this did not work.
Make sure that the connector from the power supply and the mother board is properly plugged in. Also make sure that the voltage selector of the power supply at the back is correct. Try reseating the memory module, or replacing them with a known good one.
Dec 19, 2009 | E-Machines eMachines Desktop PC
Replaced mother board, forgot where power switch plugs into
you can look for the power switch terminal by its label.like PW for power button and PLED for power led.reset is RS.
May 20, 2009 | E-Machines eMachines Desktop PC
Emachine T2885 won't start up after I cleaned it with vacuum
unplug and remove the ram and battery remove the jumper on the clear mos for 5minutes Put everything back together make sure everything is seated firmly
Apr 12, 2009 | Intel Motherboard
NEED POWER SWITCH WIRING FOR A EMACHINE T-3095
check on the motherboard there should be a small prints on it near control panel.
Mar 05, 2009 | E-Machines eMachines T3830 PC Desktop
Wiring info
Most Mobo's have printing next to the places that are jumpered or pluged into. The ones you need sould be close to the edge of the mobo, that is close to the front {power button} side.
May 30, 2008 | E-Machines (308714) Motherboard
Emachine with XP home edition doesn't start
Hi hearalso, down to the basic's. Replace power cord.
No help there than, remove the case's side panel to expose the motherboard. (Normally it is the left side panel while facing the front of the PC.)
Look closely for a small (green in color) led light. The power cord must be connected to the PC & connected to you're power strip but do not press the power on button on the PC.
The green led tell's you the board is receiving 5volts. Check all connections. Un-plug & reconnect every data & power connector in your PC. (Double check). There is a fuse inside your power supply that may have blown. Check you're manual page, Approva Statements B-1. Fuse Warning Instruction Caution.
Check fuse in power supply. (Unplug power cord before opening).
If you can not power up the PC after all of the above than if possible, swap out the power supply.
Replacing the power supply is the last step.
If you have more questions, feel free to ask.
Good Luck!
Mike
Apr 09, 2008 | E-Machines eMachines Desktop PC
Wiring diagram for T2885
Give me also model serial number (printed on your motherboard or on seller's receipt).
http://www.dealtime.com/xPF-E-Machines-Desktop-with-Intel-Celeron-Processor-2-8GHz-T2885
Feb 17, 2008 | E-Machines T2885 PC Desktop
E-Machines eMachines Desktop PC Logo
95 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
