Question about Sharp AL 1215 Black and White Copier
I have a Sharp al 1010 that is always indicating the toner is out, even though I replaced the cartridge with a new one (twice..thought there was an issue with the toner cartridge). Also recently replaced the drum as well. Machine turns on ok, then runs & runs & finals stops indicating no toner. Help! Can this be repaired or is it time to get a new copier?
I fixed This! On ours it was a secondary motor that turns the toner gears that was siezed up. It is the one with the blue leads. We were lucky enough to have an AL 1631 for parts and it has the same motor.
Posted on Jul 01, 2010
  • Tonerman888 Jul 07, 2010
    The Xerox XD100 and similar models also have that same motor!
  • 29 Answers
If you have replaced the toner unit the main cpu is bad not realLY worth fixing but this is a very good copier you can get them on ebay , this the only copier you can refilll the toner unit for $6 & DRUM FOR $15 get a AL1655 best deal
Posted on Mar 09, 2009
Red LED's on Sharp AL 1010 shaped like bowling pins
This is your out of toner indicator. I describe them as a stack of 6 dots. In any case you will need to buy a new toner cartridge or have your current cartridge refilled.
Good Luck and Thank You for using Fixya.
Sep 22, 2010 | Sharp AL-1010 Copier
My Sharp AL-800 copier only returns blank pages even after I replaced the toner cartridge with a new one.
toner is not the problem remove the photoreceptor and gently clean the inside very well expecialy the two charging unit.
Jul 30, 2010 | Sharp AL 800 Copier
I replaced the Sharp AL-1642CS TD toner cartridges twice. Still flashes the toner symbol. Someone mentioned cleaning the toner sensor. Where is the toner senor located? drjanisch
Where the toner bottle inserts into the holder, make sure the OLD bottles nipple is not stuck in there, this issue will not allow the new toner to flow into the system and the machine thinks it has an empty bottle
Apr 04, 2009 | Sharp AL-1642CS Copier
NEED HELP WITH SHARP AL-1010
Hello sir; According our service manual 'L6" sub code 10 is laser drive, motor, problem, replace laser unit . the laser unit item# is DUNTK0013QSZZ, it located at left hand side of the toner cartridge inside the machine.
Jan 23, 2009 | Office Equipment & Supplies
STAUS INDICATOR SHOWS "L-6" ON SHARP AL-1010
Dear sir; The L-6 error code it means "laser drive, motor", It can be reset, the procedure as follow;
1, press "clear", "exposure mode", "clear", "exposure" those keys.then machine go dead.
2, enter 14, then press print.follow the direction willtake car the problem.
If you need more help just let me know I'm always around, or generously give me good rating. thank you,
HAVE A MERRY CHRISTMAS !!!
Dec 23, 2008 | Sharp AL 1215 Black and White Copier
Toner error message on copy machine
Is "CH" steady or flashing? If it's steady, the door is not shut properly.
If it's flashing, the machine doesn't detect the presence of the toner cartridge (defective toner cartridge). Try another toner cartridge (an empty cartridge will do).
To get the blue handle to stay locked sometimes takes fiddling with it when the cartridge is in.
Dec 07, 2008 | Sharp AL 800 Copier
Replace toner
Dear sir,
Commonly the sharp and toshiba toners are normally sealed units, therefore no toner refill avaibable.
Contact your service outlet to order a new toner cartridge
May 09, 2008 | Sharp AL 1631 Copier
Manual for Sharp AL 800 digital copier
hi im jules_09.you need a new toner cartridge for the copier when the toner light comes on it indicate the cartridge is empty.buy a new cartridge there is a instruction on the packaging that will guide you to install it your self
Dec 01, 2007 | Sharp AL 800 Copier
Sharp AL 1215 Black and White Copier Logo
79 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
