Question about Sony FD Trinitron WEGA KV-36HS500 36" TV
Wont turn on red light flashes six times - Sony FD Trinitron WEGA KV-36HS500 36" TV
  • 4,234 Answers
The 6 blinks actually means a loss of the +5V line in this particular set. This can be a faulty IC504 (5V regulator) or something on the A,B pr M boards is loading down the 5V. This is not an easy one to diagnose remotely. Unfortunately, the part (IC504) is no longer available from Sony. The A board ( the more likely to be bad) is available but costs around $300 for the part retail. If you can pay for a detailed component level estimate, perhaps we can work through the actual repair. Sorry I can't be of further help, but this type of problem requires examination of test points with test gear to narrow down.
Dan
Posted on Mar 23, 2009
4 Suggested Answers
techman
  • 3130 Answers
SOURCE: Sony KV-32HS510, worked perfect, turned on the next day and all I got is flashing red light.
Im sorry matt, its a solid state set and has no user replaceable parts inside the set unless your frained in solid state repair and printed circuit board repair. not as easy as to replace a module like the good old days. Its most likly in the sweep or the sweep power supply. it could also be a small of a problem like cold solder connections on the driver transformer, or the main high voltage transformer. Not a job for the untrained. Please be safe and call in a pro to assist you in this repair... Good Luck PS please rate this thread.
Posted on Oct 19, 2006
  • 178 Answers
SOURCE: have a kv-34hs510 wega that will not come on. red
This is a common failure with this set, it is in the power supply, switch mode regulators in the ps need replaced, the repair would be typically cost around 200 - 250 from a shop to repair. if you want to fix it yourself i can get the part numbers just post back and let me know if you are a do-it-yourself er.
Posted on Sep 25, 2009
  • 1274 Answers
SOURCE: Keeps shutting off, when turned back on shuts off
check C515 & C516 & IC206.hope this helps
Posted on Feb 18, 2010
Morning, it flashes red light six times
From the manual:
Press the (ON/STANDBY) switch to turn on the projector. If
the power is not turned on, disconnect the AC power cord, then
confirm the ON/STANDBY lamp is turned off. After about 10
seconds, reconnect the AC power cord and turn on the power
again. If the indicators still light up, the electrical system has a
problem. Consult with qualified Sony personnel.
Jul 08, 2016 | Sony VPL-VW95ES Full HD 3D Home Cinema...
Red flashing after tv turn on for KDS-R60XBR1
How many times does the red light flash before it pauses and then starts again? This is important info as it helps to diagnose your problem.
Mar 20, 2013 | Sony Grand WEGA KDF-55WF655 36" Rear...
50PF9631D won't turn on... red light flashing/blinking 6 times
Your TV main board is damaged and you need a new one. You can order one on ebay and fix it yourself. Make sure you have the TV model/serial number on the back label of the TV to have the right part when ordering.
Jan 09, 2013 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Tv will not turn on, red flashing light comes then turns off
tv will not turn on, red flashing light comes then turns off.
light flashes six times.
Aug 15, 2012 | Sony KP-53HS30 53" Rear Projection...
Red light flashing, tv wont turn on
need the model number of the panasonic and also how many times it is blinking. The blinking is an error code.
Aug 03, 2012 | Panasonic Televison & Video
My sony won't turn on. when I use the remote to turn on it flashes green six times, I hear a click and then it flashes red six time.
six times means the thermal fuse on top of the lamp tripped. Replace it and give it a good cleaning and it should work.
Feb 20, 2011 | Sony Grand WEGA KF42WE610 42" Rear...
MY wega 42inch wont turn on...the little green light flashes like five time as if it where to turn on but never does...and then it turns red and flash six times pauses and then again the red light flashes...
Six blinks indicates a faulty power supply. often caused by open thermistor located at under lamp assembly or beside it. Or a defective regulator on power supply section.. Check the thermistor and replace if found defective.. Or contact the nearest Sony service center at your area.
Oct 01, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
TV does not turn ON and red light keeps flashing six times stops reapeats again with six times red flashing
Sounds like a power supply issue. order a new power supply or trouble-shoot the current. Look for any capacitors that are bulged up on the top and not flat.
Jan 29, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
Will not power on, red light flashing six times
the problem is in the power supply most likely. The overvoltage protect circuit is causing you not to be able to turn the tv on. This is common to all tv's. Solution unfortuantely is get another tv unless you know someone who can either work on or replace the internal power supply
Jul 01, 2009 | Sony KP-61HS30 TV
Sony FD Trinitron WEGA KV-36HS500 36" TV Logo
139 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
