Question about HP Pavilion ze5375us Notebook
Black screen with HP logo in center of screen. I checked to make sure my ram strips were seated tightly.
  • lotfi bouakaz
    lotfi bouakaz May 11, 2010
    yeah so what is the problem?
    New Friend:
  • 13 Answers
Can you enter the bios when its first switched on? ( press F2 or F10?)
Remove power, take the battery out, wait for 5minutes then try and startup again with only mainspower. If that works, shut down replace battery and power and startup.
If none of that works sounds like faulty mainboard. You could also try and and boot from a PE disk, like Bart PE or Knoppix if you can download and burn form another PC. This way you'll also be able to get your files off easily if it is kaput.
Posted on Mar 03, 2009
    Master:
  • 404 Answers
Well your operating system isn't loading its just loading the bios. I think your xp is lost so put the recovery disks boot from there and install osx. otherwise it points to a faulty hard drive
Posted on Mar 05, 2009
CPU freezes on boot up
try reset CMOS.or re-wiring the electrical wires,make sure they are seated tight.
Jul 24, 2013 | Biostar M7VIG-400 (M7VIG 400-COMBO4)...
Screen stays black when I turn it on
My point of view RAM section direct connect to display so first you check RAM.Then check processor Fan proper working or not. and finally power connection in screen.
Thanks..
May 08, 2013 | HP Pavilion ze4935wm PC Notebook
Dell 3000 beeps twice no video after blue dell logo.
The most possible cause is that RAM isnt attached properly on motherboard, it might loosen up sometimes. So just try to check your motherboard, pull out the RAM carefully from the RAM SLOT & attach it precisely. Hope it will work....
Feb 29, 2012 | Dell Dimension 3000 PC Desktop
Pavilion does not boot. Lights on strip below screen flash on and off. HDD drive does not come on
-If you are not able to boot in Windows but still able to get error codes like from windows you can just reinstall the Operating system using your recovery discs
-If there's no display at all even the HP logo upon startup its a motherboard issue
- if you are able to get the hp logo in startup but not able to go to windows its a RAM issue
Dec 29, 2010 | HP Computers & Internet
My hp pavilion a1330n computer freezes on the HP
the dreaded Blue-Screen of death.
Usually caused by:- Ram Failure ( memory Modules )
CPU Failure ( Processor Failure )
Hard-Disk faulty, not spinning et,c.
Cmos battery fault.
Missing/deleted/corrupted operating System files.
Possible Solutions:- remove cmos battery, from Motherboard for 10 seconds and replace. ( eliminates cmos/bios errors )
remove 1 stick of Memory ( Ram ) and test individually ( eliminates 1 or More Faulty sticks Of memory Or Slots )
remove, CPU Fan/heatsink, remove CPU and re-seat, re-grease with Artic-Silver or similar ( thermal-Compound ) replace heatsink/Fan. test.
Hope this points you towards a Sucessful repair.
Mike @ Compurepair. No-Links No-Nonsense Just Good Practical Advise :-)
Nov 04, 2009 | HP Pavilion Media Center a1330n - AMD...
Screen stuck on black with gateway logo
That indicates a hardware problem. From your description I would check the cpu or suspect it as being the problem. It can be a ram problem as well.
Aug 21, 2009 | Gateway Computers & Internet
Screen black computer laptop not starting ,hp pavillion entertainment pc,power lights on but screen black screen black computer laptop not starting ,hp pavillion entertainment pc,power lights on but screen...
hi,
if nothing(even hp logo ) is not coming on the display then please try this.
1.remove the battery and then press the power button for 30 sec.Again refix it and check.
2.If windows sound is there then this mught be the issue with display.
3.If there is no windows sound might be the issue with RAM so please get it checked.
May 29, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
HP Pavilion dv6000 Black Screen!
have you tried an external screen? did the same happen there
Mar 12, 2009 | HP Pavilion dv6000z Notebook
My HP NX 7010 won't start it diplays the hp logo and that it
it might be a hard disk failure or Ram failure check first by changing ram
Feb 19, 2009 | HP Compaq nx7010 Notebook
Compac presario v2000
try reseating the RAM,if that doesn't work replace the RAM
2 Beeps = bad RAM
Mar 24, 2008 | HP Compaq Presario V2000 Notebook
HP Pavilion ze5375us Notebook Logo
60 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
