I would like to know where is the Convergence Ic's located on the main board on a panasonic PT-53wx52F and if this is what really cause the TV to come on then off
  • 583 Answers
Http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
click the link to get the location of convergence ic
Posted on Mar 03, 2009
Convergence problem on panasonic rear projection TV model PT-53WX52F
the PT47WX42 Convergence repair kit from www.tvrepairworld.com also works for your model. The kit contains the ICs, resistors and the CD with instructions.
Sep 21, 2010 | Panasonic Televison & Video
Panasonic pt-51hx42f replaced 2 convergence chips and 6 convergence resistors. still can move any of the convergence set-up arrows. was told it might be the pico fuses. But I cant locate them on the...
No thats not the Problem you have to know HOW TO ENTER SERVICE MENU Their is a Long Step in getting into the SM
if not done correctly you can really Mess this TV up! Once you Enter the service menu then you can go to convergence and adjust
to correct Pattern,Then you Must Exit correctly with the Save Mode to Save alinement or you will have to adjust all over again.
Sep 20, 2010 | Panasonic PT-51HX42 51" Rear Projection...
Screen plays double
It is called convergence out IC failure and you need to replace 2, ICs in convergence section of TV.
If you are familiar with TV repair or can solder electronics parts in circuit board then let me know exact model number of Panasonic TV to guide you more with technical info or call local TV repair shop for repair.
Apr 24, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic PT-53WX52F Color blue adjustment
most likely the two convergence Ics need to be replaced. They are STK392-110 you can get replacements at the following link with free instalation instructions with pictures.
http://servicemanuals.vstore.ca/
Jul 09, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic pt-47wx42f
Yes you can get replacement IC STK392-110 convergence ICs at the following link and they provide free instalation instructions with pictures. The Ics are located on the board on the left side attached to a large heatsink. You will need to replace both ICs heres the link.
May 19, 2008 | Panasonic PT-47WX53 47" Rear Projection...
PT-53WX42F
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 26, 2008 | Panasonic PT-47WX49 47" Rear Projection...
IC Convergence on a Panasonic PT-51HX43
Sep 19, 2007 | Panasonic PT-51HX43 51" Rear Projection...
CONVERGENCE ic CHIP
if you can remove the rear panel assy. look for the convergence ic's they start with stk--- and you got the part number you need a source panasonic is 814 source and the number on the ic's stk 390 ----/
Aug 22, 2007 | Panasonic PT-53WX42 53" Rear Projection...
PT-47WX53 blue convergence PROBLEM
Sounds like you have a blue foldover in the convergence. Since tv has been worked on it could be bad ic, maybe not original, generic. I would say if you can open set and look in, look for the blue it should be marked. look for a loose connection. If you can have someone to gently tap around that blue amp and see if it moves are go away, it might be a simple loose connection and needs soldering. If not then my have to change ic again. Becareful cause set would need to be on to really check. Hope this helps.
Aug 15, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-47WX49 Convergence IC
usjavelin. I have the pdf files for the tv. I own the same one. I can send them to you if you'd like.
Dec 16, 2006 | Panasonic PT-47WX49 47" Rear Projection...
Televison & Video Logo
120 people viewed this question
Top Televison & Video Experts
Electro Med Services...
