Question about Canon MX300 Office All-In-One Printer
Same problem : Paper Jam when is no paper... What to do, I need FAX !!!
  • 1 more comment
  • awedell Apr 01, 2009
    My Canon MX300 Office All-In-One Printer, displays:
    ' Paper jammed' Clear paper jam and press(OK)
    but there is no paper jammed, not even a ..tiny bit.
    What is the solution?
    Thanks
    Alessandro Wedell
    (alessandro.wedell@gmail.com)
  • theonehbpowa May 20, 2009
    Paper Jam messager error always displays and i cant do anything. PLZ Help
  • Anonymous May 20, 2009
    This only works if you can convince the printer to print something... right now, it just says "jammed and won't let me print anything still, manilla folder or not
Take a piece of stock card (I cut a piece of a manila folder to size) and put it in the feeder. Copy or print something and when the printer grabs the card stock, help it along by pushing it gently. You'll see that it prints. After that it will print on regular paper. Don't ask me why...
Posted on Mar 17, 2009
Paper jam 2 but no paper is stuck
Most printers/faxes need more than one or two sheets of paper in the hopper in order for printing to commence. If it's not that, take out all paper. Turn off the printer/fax. Wait five minutes and turn printer/fax back on. With some printers/faxes, that almost acts like a re-boot. Good luck!
Mar 28, 2012 | Samsung SF-5100 Plain Paper Laser Fax
Paper jam
Sir/Mam
The problem mite be dirty rollers that feed the paper, try cleaning with alcohol or worn out replace. Problem is the paper roller is miss feeding not taking up the paper instead of hitting something in the machine paper jam.
Apr 18, 2010 | HP 1010 Plain Paper Inkjet Fax
I have a paper jam on my Pitney Bowes 1630. The
Good Luck, When the paper is stuck in the back, it is in the fuser and you may be able to get the paper out, but probably the drive for the fuser is messed up, which caused the jam in the 1st place, if you get the paper out, the next one through will probably jam up again. Technicians usually just replace the fuser. Oce is the repair entity for these machines now. 1 800 2423 5556
Jun 09, 2009 | Pitney Bowes 9920 Plain Paper Fax
Paper jam message but there is no paper jammed. opening and closing cover doesn't work.
hi,are you sure no paper jam ok check very very small paper in your machine or clean the sensor.
Apr 28, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
Flashing paper jam, no jammed paper
Check to see if there is dust on the senor inside the fax machine, blow with some air can help
Apr 22, 2009 | HP 1010 Plain Paper Inkjet Fax
Fax will shows a Paper jam but no paper found in machine.
Are the all sensor flappers whole?Or it may be an PCB problem
Jan 26, 2009 | Canon LaserClass 9000L Plain Paper Fax
Printer says paper jam, but there is no paper in the printer. (mfc 210c)
If the paper tore when removing it, chances are there could be a small piece of paper still causing the paper jam. Sometimes all you need to do is turn the fax off for a few minutes and then turn it on again and the paper jam message is gone
May 10, 2008 | Brother MFC 210C All-In-One InkJet Printer
Canon B820
please confirm that no foregin object droped inside like (stapler-pins)--confirm that paper jam switch in good condition and it is lever not broken and can move in free motion.-chek for small pieces of torn paper and clean the paper path.
Mar 12, 2008 | Canon FAX-B820 Plain Paper Bubblejet
Paper jam
There is either a jam in there somewhere where you can't see it, or if it clears, the feed roller is not feeding the paper, in either case you probably need a tech.
Jan 07, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Canon MX300 Office All-In-One Printer Logo
226 people viewed this question
old marine
old marine
