Question about Microsoft Xbox Console
Xbox controller port 1 & 2 will not work.
Had trouble with a couple of rented discs. They froze on me and at one point the dirty disc or damaged disc note came up. most of the time it just says to reconnect the controller to the console, which I do and makes no difference. 2 & 3 still work.
  • lizandco Mar 05, 2009
    Thanks for that. Any idea what to do about it tho!
  • 81 Answers
Rented disks are used by so many so they render with your firmwareit may cause hardware problems
Posted on Mar 04, 2009
  • venkatesh babu
    venkatesh babu Mar 05, 2009
    you can get pirated instead of buying rental in cheap cost first mod your console
When i put an Xbox 360 game in it tries to play it as a DVD movie. please help!!!
When you try to play a DVD movie or an Xbox 360 game disc on your Xbox 360 console, you may receive an error message. This article presents step-by-step guidance to help you determine whether your disc is playable.
SYMPTOMS When you try to play a disc, you may receive the following error message: Can’t read this DVD.
CAUSE The DVD or game disc may be dirty or damaged. Because the console cannot read the disc well, it may even mistake a game disc for a DVD and report this error. If this problem occurs with multiple discs, even clean and undamaged discs, there may be a problem with your Xbox 360 console.
Note If you receive a different error message, such as one of the following messages, the problem is a different problem:
Error message 1 Can't play DVD. Wrong region code. Error message 2 Can’t play DVD. Family settings restrict playback of this DVD. If you receive one of these error messages, see the corresponding Knowledge Base article: 907620 While attempting to play a standard DVD movie using your Xbox 360 console, you receive the error message: "Can't play DVD. Wrong region code" 908645 While attempting to play a DVD movie using your Xbox 360 console, you receive the error message: "Can’t play DVD. Family settings restrict playback of this DVD"
THINGS TO TRY Here are some things that you can do to try to fix the problem or to determine what caused it.
Determine whether the disc is dirty or damaged Discs that are smudged, scratched, or otherwise damaged cannot be read by the Xbox 360 console. You will want to examine the disc to see whether it has smudges, scratches, or other damage. To do this, follow these steps: 1. Examine the disc for dirt or damage: a. Pick up the disc by its edges. Do not touch the top or bottom surface. b. Examine the shiny side of the disc to make sure that the disc is clean and has no damage.
NoteScratches that follow the curve of the disc are very damaging and prevent a disc from being read. If your disc has even one of these kinds of scratches, the disc is damaged, and you will no longer be able to play it. If this is the case, see step 4. 2. If the disc is dirty, clean the disc by hand: • Use a soft, clean, dry, chemical-free cloth to clean the disc. • Lightly wipe from the center of the disc outward. 3. After you clean the disc, try to load it in the Xbox 360 console. If the disc still will not load or you receive the same error message, the disc is damaged, and you will no longer be able to play it. If this is the case, see step 4. 4. If the disc is damaged, do one of the following: • Because DVD discs are not game discs and the disc was damaged because of misuse of some type, such as not storing the disc in its case, the only thing that you can do is buy a new one. • If you feel that the disc was damaged by the Xbox 360 console in some way, please contact Xbox Customer Support. To do this, please visit the following Microsoft Web site: http://www.xbox.com/support/contact
Feb 18, 2010 | Microsoft Xbox 360 Console
Tip
When you try to play a DVD game on Xbox 360 it tries to play as a movie?
on Feb 18, 2010 | Video Game Consoles & Games
My xbox 360 dvd tray keeps opening
Determine whether the disc is dirty or damagedDiscs that are smudged, scratched or otherwise damaged cannot be read by the Xbox 360 console. You will want to examine the disc to see whether it has smudges, scratches, or other damage. To do this, follow these steps: 1. Examine the disc for dirt or damage: a. Pick up the disc by its edges. Do not touch the top or the bottom surface. b. Examine the shiny side of the disc to make sure that the disc is clean and has no damage.
Note Scratches that follow the curve of the disc are very damaging and prevent a disc from being read. If you see that your disc has even one of these types of scratches, the disc is damaged, and you will no longer be able to play it. If this is the case, see step 4. 2. If the disc is dirty, clean the disc by hand: a. Use a soft, clean, dry, chemical-free cloth to clean the disc. b. Lightly wipe from the center of the disc outward. 3. After cleaning the disc, try to load it in the Xbox 360 console. If the disc still won't load or you receive the same error message, the disc is damaged, and you will no longer be able to play it. If this is the case, see step 4. 4. If the disc is damaged, do one of the following: • If you think that the disc was already damaged when you bought it, try to exchange it. • If you have a damaged Microsoft Xbox 360 game disc and would like to order a new one, please visit the following Web site: http://support.xbox.com/support/en/us/xbox360/gamesandmedia/games/discreplacement/DiscReplacementPlan.aspx (http://support.xbox.com/support/en/us/xbox360/gamesandmedia/games/discreplacement/DiscReplacementPlan.aspx) • If the game is a non-Microsoft Xbox 360 game disc and was damaged because of misuse of some type, such as not storing the disc properly in its case, the only thing you can do is buy a new one. • If you feel that the disc was damaged by the Xbox 360 console in some way, please contact Xbox Customer Support. To do this, please visit the following Microsoft Web site: http://www.xbox.com/support/contactIf the disk is bad or damaged your unit will open when trying to read it. Hope this information helps, let me know if I can help you with anything else.
JimmyC
Oct 04, 2009 | Microsoft Xbox 360 Console
My xbox can't read disc & can't save the clock
Hey,
when it says its either dirty or damaged it usally means your disc i very scracthed or dirty/dust / abouth the clock thing i have the same problem but found out last year they dont save anyway
Aug 17, 2009 | Microsoft Xbox Console
Everytime i insert the disc counter strike the screen shos this message - Unable to read from the disc. Please check if the disc is dirty or damaged.
then try cleaning it or maybe its true that your disc is is dirty or damaged. and to avoid this clone your discs for backup. or try downloading games from pirate bay. download your counter strike there.
Aug 16, 2009 | Microsoft Counter Strike for Xbox
PS3 froze while playing a BD, then it would not rcognize anything
Most PS3 systems end up doing this due to an over heating of the laser lens. Let me explain: The laser lens in the PS3 is made to read mainly Blue Ray games. The movies need to be read faster than the game discs which causes it to work harder thus the problem arising.
Sometimes, your lucky enough for this to only be a dirty lens problem due to rental movies which are most of the time, if not always, dirty.
Have you tried a lens cleaner kit?
This is the CD-ROM with a small brush on it to clean your laser lens head.
This problem has happened to me in the past and this solved the problem.
It is a common problem for any lens reading console.
Regards,
Aug 02, 2009 | Sony Playstation 3 (PS3) Console
The cut scenes freeze
Sounds like the disc may be damaged. Has the disc got scraches on? if it has, you may want to go take the disc to be repaired. This can normally be done at most video game stores.
Jun 17, 2009 | Microsoft Blue Dragon for Xbox 360
Disc is dirty ordammaged
LOOK FOR WAVY RAINBOWS ON THE READ SIDE OF THE DISC. IT COULD BE AN OVERHEATED DISC AND SOME PARTS OF THE GAME WILL WORK AN OTHER PARTS OF THE GAME WILL NEVER WORK.
Xbox not recognizing disc
please consult to xbox technician.there is nothing you can do because your laser or lens which read your disc probably either dirty or damages...if it is dirty, i suggest you to buy disc that has a tiny brush attach onto that disc...but if it damages,well............nothing u can do other than send it for service...
May 26, 2009 | Microsoft Xbox Console
Grand theft auto is not working it loads up but then says i have a dirty disc i think it's something to do wit the xbox 360 ?
is the game rented or is it store bought? Most rented games have problems like that because of people just messing around with the disc cause the dont own it but if its store bought then there is probably a big scratch under the disc lamination.
Jul 30, 2008 | Video Game Consoles & Games
Microsoft Xbox Console Logo
60 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
