Question about Sony KP-53HS10 TV
Sony KP-53HS10 AND "5" FLASHES at Timer/Stand by Indicator
Anyone know what the "5" flashes might mean? The picture goes black (audio is fine) to get my attention so I will then notice the
"flashes". The picture then comes back on and the tv runs fine
for a few seconds-10 minutes. Then it repeats cycle.
Any info on what the "5 flashes" mean would be greatly appreciated.
Thanks-Dave
  • mestrella984 Mar 09, 2009
    ours does the same. the timer light blinks about 5 times then the tv flashes and it does it all over again. can someone please help.....it's making me dizzy!
  • ochristian Dec 16, 2009
    I have a sony big screen that comes on and works fine and then just turns off and sound play for a few seconds and the sounds goes off , you can turn back on and works fine for xtime and then just turn off again .
I had the same problem someone told me to take the front cover off were the speakers are there the middle were you change the channels take them screws out and becareful there is electric stored up in there dont touch anything there is a square box with3 screws on top and three screws on bottom
turn your tv to video 1 and the first screw on top closes to middle turn it to your right a little at a time you will see bright colored lines then turn it to the left until they go a way then do the same with the other 2 on the top then shut off tv for 5 mins turn back on ahit the focus button it workd for me but be careful
Posted on Mar 16, 2009
Sony Projection Stand by indicator flashing red
Ur FBT,Fly Back Transformer high voltage is dead, the black block of plastic with a red wire with cap hook to a CRT(Tv Tube).
Sep 14, 2009 | Sony KP-46S25 TV
Sony KP-41T65
is there a cadence to the blinking timer light?
Jul 17, 2009 | Sony KP-41T65 41" Rear Projection...
Sony kp-61hs10 tv, has sound but picture goes black after 3 min.
I just had the same problem. If your lucky it might be a free 5 minute fix. The five light flashes mean impropper current. I took the front grill off, then behind that is another black cover, I took that off and noticed the circuit boards COVERED in dust. I then took an air can duster and blew off all the dust... works like new. No more flashes and in an out picture. The collection of dust was interfereing with the electrical current.
Ben
Apr 15, 2009 | Sony KP-61HS10 61" Rear Projection...
I have a Sony Projection TV KP-53v80. I tried to turn it on today bu there is no picture no sound. The Timer/Standby indicator flashes 4 times. What does this mean?
No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted.
Check IC1509, Q1505
Please rate this solution
Jan 18, 2009 | Sony KP-53V80 53" Rear Projection...
Hello..i have a sony kp-61v80 tv year 2000
I have a sony codes for sony TVs that tell what is wrong by the blinks as soon as a can will ck it to see what it says.
Dec 03, 2008 | Sony KP-57WS500 57" Rear Projection...
Timer Standby light flashing No pitcher
Sony
Model # KP-53HS10
Serial # 9718217
MFG 2000
Plugged in TV. Timer Standby Light just flashes continusly. No Picture and No Sound.
Apr 02, 2008 | Sony KP-51WS500 51" Rear Projection...
Sony KP-51WS520 Stand by flashes 5 times
When a Sony TV flashes five times, that means that there is an AKB circuit fault.
This means that there is something wrong with the video.
When you get this error, several IC and components concerning the video signal must be tested and eventually replaced.
Mar 13, 2008 | Sony KP-51WS520 51" Rear Projection...
Sony KP-57HW40 57 in
Bad blue CRT ...........common problem...........T.
Nov 10, 2007 | Sony KP-57HW40 57" Rear Projection...
Sony KP-61HS10 61 in. Rear Projection Television
plug it out to reset itself and if that does not work,you will have to call a tech as the tv has a problem in its power supply an its related circuit good luck.
Apr 06, 2007 | Sony KP-61HS10 61" Rear Projection...
Timer / Stand by light flashes
could be high voltage problem. time for your local repair shop.
May 27, 2006 | Sony KP-53HS10 TV
Sony KP-53HS10 TV Logo
762 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
