Question about Volfenhag ZX-7160 Car Audio Amplifier
Volfenhag ZX-7160 Car Audio Amplifier owners manual to adjust the frequency also wiring diagram
  • 1,147 Answers
Its very easy to hook it up. your best bet is to join www.carstereo and ask your question there.but it is easy to set and hook up amp if you really need help email me
Posted on Aug 24, 2009
Volfenhag zx 8200 amplifier cooling fan not working
open the back of your amp and see if the leads from the fan are burnt anywhere. trace them from the fan to where they are soldered into the board. if the wires appear to be fine, then test them using a volt meter. if the positive is not recieveing power you may want to solder the lead to your remote turn on.
Aug 24, 2010 | Volfenhag ZX-8200 Car Audio Amplifier
How to switch protection off (red LED to blue)
The protection light is on indicating a short or over- voltage problem. If you disconnect the speaker leads and the light goes off or green then the problem is a shorted speaker or wiring problem. If the light stays red the problem is inside the amp and it will need service and parts.
May 03, 2010 | Volfenhag ZX-5007 Car Audio Amplifier
Scosche EFX work with MOS-FET Amplifiers
Mar 22, 2010 | Scosche Industries EFX Amplifier Wiring...
Zx-8100 amplifier is red lighting.
try wiring them differently. here is a link for u to go to . once there find your amp configuration (ie. mono, or 2 channel) then down to the type of subs an how many subs ( ie. 2 dvc (dual voice coil) 4 ohm subs) an that will show u how the subs should be wired and wired to the amp.
Mar 21, 2010 | Volfenhag ZX-8100 Car Audio Amplifier
Volfenhag 2050 staying on prtection mode
Oct 14, 2009 | Volfenhag ZX-5007 Car Audio Amplifier
I have a volfenhag zx-8400 and it just geos into protection mode
The most likely problem would be a blown fuse. I would replace all of the fuses.
Oct 04, 2009 | Volfenhag ZX-8400 Car Audio Amplifier
Volfenhag amp adjustments
Firstly, you will want to set all options to a low pass, so the high frequencies are filtered away from the subs, avoiding damaging the voice coil. Start with the Gain of the amp about 3/4 of the way up, and all other knobs, such as the bass knob to the lowest setting. From there, test your subs for soujnd, and then change the gain and amount of bass for the sound you desire, since each person is different. I have my gain about 1/2 way up and the bass about 1/4 of the way up. If you have a crossover knob, set it to the highest frequency available, since the low pass will filter all the high frequencies out anyway.
Sep 23, 2009 | Volfenhag ZX-5007 Car Audio Amplifier
Do you have instructions for wiring install on volfenhag GX8200??
Amplifier Class AB
Number of Channels 2
RMS Power (4 ohms) 120 watts x 2 channels
RMS Power (2 ohms) 200 watts x 2 channels
RMS Power (1 ohm) Not Stable
Bridged RMS Power 400 watts x 1 channel
Total RMS Power Output 400 watts
Peak Power Output 1000 watts watts x 1 channel
Minimum Impedance Unbridged 2 ohms
Minimum Impedance Bridged 4 ohms
THD at Rated RMS Power 0.1%
Speaker Level Inputs No
Preamp Outputs 1 pair
Built-in Crossover High-pass (HP), Low-pass (LP), Full (AP)
High-Pass Crossover Frequency 40 - 250 Hz
Low-Pass Crossover Frequency 40 - 250 Hz
Subsonic Filter N/A
Signal-to-Noise Ratio N/A
Channel Separation N/A
Bass Boost 0 - 18 dB
Bass/Gain Remote Yes
Fan Cooled Yes
Fuse Rating 20A x 2
Dec 24, 2008 | Volfenhag ZX-8200 Car Audio Amplifier
How to mount amp
Turn your amp over and you'll see 4 holes one in each corner and you should gotten 4 v shapped pieces of metal with 2 holes each and 4 normally have to mount them on manually. I hope that helps.
Mar 17, 2008 | Volfenhag ZX-8300 Car Audio Amplifier
Open Questions:
Volfenhag ZX-7160 Car Audio Amplifier Logo
376 people viewed this question
Top Volfenhag Car Audio & Video Experts
Robert Rankin
Are you a Volfenhag Car Audio and Video Expert? Answer questions, earn points and help others
