Question about Kenmore Dryers
I have a Kenmore electric dryer that suddenly went ''poof'' (like when a light bulb that goes out). It threw the breaker. I reset the breaker and the dryer started. I thought that was all there was to it, but now it won't heat the air. I checked continuity of the fuse, both thermostats, and the heating element. All checked out. I did not check the continuity with the wires disconnected, but got no continuity in the temp switch, so I replaced it to no avail. (still no heat) I read in the repair manual to disconnect the wires from the posts to check each component. The thermostat that has 4 wires checked out on two of the terminals, but not the two others. I then replaced it and still no heat... I hate to call a repair guy out at this point. Any suggestions?
  • 583 Answers
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Posted on Mar 03, 2009
4 Suggested Answers
  • 1122 Answers
SOURCE: I have a Kenmore electric dryer that suddenly went
did you check the main fuse on the blower box with the wires off?also check the heater box fuse(top)and the high temp thermostat on heater box(bottom)with the wires off-mike
Posted on Mar 04, 2009
kachbibi1
  • 979 Answers
SOURCE: Kenmore Dryer won't heat
There is a thermal overload switch that is located under the top of the dryer. It probably is bad. You can find it close or next to the drum. Bypass it and see if it comes on and if it does, then replace it. This is probably where it is since you have apparently checked out everything else.
kachbibi1
  • 979 Answers
rmtg
My dryers plug shorted out and tripped the breaker. I replaced the plug and turned it all back on and it worked.....then seconds later a loud poof sound from the dryer and now nothing is working. Please...
when a plug shorts out like your has,it creates a surge of current for a moment,it could have ruined or weakened the element,motor,thermal fuse or even pierced a wire electrically and when you re-powered the circuit it blew out this weakened component,the loud poof you stated sounds like the element burned through and blew out creating an arc and the poof sound
May 05, 2012 | Kenmore Elite HE4 Electric Dryer
Our dryer just suddenly stopped! We have no light and it seems no power. We checked out fuse box and everything is fine there. Does this dryer have a fuse that would cause all electricity to stop?
Hello
No .Double check your cicuit breakers.If your dryer is electric there are two breakers.Switch all the way off then all the way on to reset.
I if ok then suspect door switch .It kills everything and if stuck ,the light too.
Happy hunting
Jul 28, 2011 | Kenmore 600 7962 Dryer
I have an electric dryer. The breaker went off and when reset the dryer would not come back on. I am not sure if the push button on/off switch is now working or if there is a reset on the dryer
I have a Kenmore 80 series electric dryer. The light comes on when the door is open so I know it is getting power but dryer will not turn on. Is the push button not working or can I reset the dyer?
Dec 06, 2009 | Roper REX4634KQ Electric Dryer
My electricity went out during a storm. Now my
Yes its in the rear under the panel, I would look at the breakers in the electrical box first the dryer is on a circuit alone. The breaker could be thrown, it mite not look as it is just turn it off and then back to on.
Aug 09, 2009 | Dryers
Unplug the dryer.
Always remove wires to check continuity or Ohms on any part.
Remove the terminal cover where the cord connects and check all wires.
Also, check them to ground on the chassis. The only one that should read continuity is the ground wire.
After removing the wires from the heater check the heater terminals to the heat canister.
If it reads continuity it is bad.
Pay special attention to the relay on the top side of the heat canister.
Mar 04, 2009 | Kenmore 62622 Electric Dryer
I have a Kenmore electric dryer that suddenly went ''poof'' (like when a light bulb that goes out). It threw the breaker. I reset the breaker and the dryer started. I thought that was all there was to it,...
Mar 03, 2009 | Kenmore 62622 Electric Dryer
KENMORE Elite HE 3T
no but there is a control bd it is probably gone
Jul 30, 2008 | Kenmore Elite 45986 Front Load Washer
Dryers Logo
99 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
