Canon i865 suddenly stopped printing anything in colour.
Hi
I'm hoping you can help me. My Canon printer i865 has stopped printing anything in colour. All cartridges are full. Normal black printing is ok. I have been through the troubleshooting guide, and done all the maintenance as in cleaning, deep cleaning, print head alignment etc many times but nothing changes.
Thanks
Noelene
  • Anonymous May 05, 2009
    Oh, very ******* useful
  • Anonymous May 10, 2009
    I have clean several time - no luck!!!
  • 685 Answers
Clean the heads
Posted on Mar 04, 2009
My Lexmark prevail pro 705 has stopped printing anything colour even after i have replaced all the cartridges??
This article on How to Troubleshoot the Vizix Ink Technology will help fix print quality problems on your printer. To run the Deep Clean Printhead function on your printer -> on the printer operator panel, press Setup -> Maintenance -> select Deep Clean Printhead. Your printer will then print the test page. Hope this helps. Thanks.
Jan 11, 2011 | Lexmark Prevail Pro705 Wireless All-In-One...
I have got Canon i560 printer but not recieving print order the software is loaded what is the solution ?
Try i560 Reset Procedures for Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  1. Turn off Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the printer should turn off, if not, press the Power button once more.
  8. Your Canon i550, i560, i850, i860, i865, i9100, i9950 Printers should respond as normal.
Pl let me know if this works
Nov 12, 2010 | Office Equipment & Supplies
Suddenly stopped printing all colors. Will only
Hi, it could be few things wich you having problem with.
First, how old are the ink tanks, it could be clodged.
Second the print head nozzles are clodged at that places.
Third, the purge unit does not work OK.
First remove all inks out and remove print head. Then on wet cloth, wet it with distiled water, few times press the bottom of print head ( nozzles ), then the 4 circles must change from colour to white. That means that nozzles are cleaned.
Dry head by pressing it on dry cloth.
Put it in, also the inks, and run few times the deep head cleaning. Every time take a look at print pattern.
If the head is to badlly clodged, test pattern would be just a little bit more better.
But now you know if the problem is in head or something else ( purge unit or inks ). The new head isnt so cheap regarding the printer so then the best solution would be to buy new printer.
If you do not want to buy laser colour printer, atleast buy one on wich ink tanks has printhead on. Its slightly costly, but you have one worry less - the print head is changed every time you change the ink.
Hope that helped
Jul 17, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
After a month or two of disuse my i860 6BK cartridge will not print. On a nozzle alignment printout the 6bk color bar below the 6y bar is absent. The square labeled "F" in the lower part of the printout is...
Hi
You can try this I found.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Mar 03, 2009 | Canon i860 InkJet Photo Printer
The printer suddenly refuses to print black but will print colour
try to set it in the default printer settings. it will go back to the original set up
Nov 28, 2008 | Canon PIXMA MP810 All-In-One InkJet...
Cannon i865,(no colour printing)
Hi all of you
you have to open the printer setting dialog box , thereby a check box set it off.
Hope this fix your problem
thanks
Hamedo
Nov 21, 2008 | Canon Office Equipment & Supplies
I am trying to print a full colour picture on a canon i865; the picture only prints in green(and black). How do I get it to print normally as it used to?
is your magenta color cartridge is out of ink or your magenta head of dried up clean it with nozzel cleand option from your printer maintanance software.
Jun 03, 2008 | Canon Office Equipment & Supplies
CANON PRINTER
ok man ur printer colur cardige has a problem u have do this open our printer take oute clour cardige of a printer then take a tishu papar & put in cardinge nozzel be carefule dont give pressor on nozl ur cardig nozal have some dust so clen it by tisu paper
or other way is ur pariner manageing software there was a option in clen the crdige or clibarte the printer cardige do this if problemm occres
then u have to chage the colour cardige
Feb 26, 2008 | Office Equipment & Supplies
Canon i865 printer
Hi! I've got same problem. Canon userguide says that 5 flashes means the print head is not installed/not properly installed, or it is defective.Not yet sorted problem out - new print-heads are expensive!
Feb 12, 2008 | Canon i860 InkJet Photo Printer
656 people viewed this question
jasbo
jasbo
