Question about IBM ThinkPad T30 2366 Notebook
Thinkpad T30 2367-23S will not use 2GB Ram Card
I have a Thinkpad t30 2367-23S.  One of the DIMM slots has malfunctioned, leaving me one 333mhz 512mb RAM card.  This no longer works for me, and I purchased an OCZ 2GB SODIMM card (OCZ2M8002G) to upgrade the one working slot.
I heard there was a way to fix the T30 and make it recognize this much RAM.  Does anybody know? (I have upgraded the BIOS to 2.10 already).
P.S. I am getting the cold shoulder from both IBM and OCZ because IBM made the max RAM specification before 1GB RAM cards came out.  They choose to stick by this faulty spec, and I get left out in the rain.
  • 404 Answers
Noway max is max. buy yourself a 1gb and don't try to beat the system or lose it.
Posted on Mar 03, 2009
IBM T23 wont turn on after adding new RAM
Hi - according to memory suppliers your T23 has the following memory capacity / requirements:
  • IBM ThinkPad T23 maximum RAM capacity: 1GB
  • Your IBM has Two (2) memory slots or sockets
  • Module upgrade PIN count is: 144-PIN
  • The memory speed is: SDRAM 133MHz, PC133
  • The laptop DIMM type for the ThinkPad T23 is: SODIMM, SO-DIMM, Small Outline DIMM
  • Non ECC
If you are meeting these requirements, you may have a defective module.
Also, according to Lenovo's page on the machine:
The system has 128MB or 256MB of memory standard and can be configured for up to 1GB of addressable memory. Memory options up to 512MB SDRAM SO DIMMs each can be added in the two available slots for memory expansion. The standard 128MB of memory is expandable up to 640MB and the 256MB of memory is expandable up to 768 MB of addressable memory with 64, 128, 256, or 512MB SO DIMMs without removing the 128MB SO DIMM that is standard in one of the internal slots for memory. For customers that need the maximum 1GB to which memory can be expanded, it is necessary to replace the 128MB or 256MB card with a 512MB card plus add another 512MB card in the extra slot. Only 133MHz DIMM memory can be used in this system. The use of 100MHz DIMM memory is not supported in the T23 systems.
This means yo can trouble shoot the 512MB modules individually by installing one of the original 128MB modules and one of the new 512MB modules (for a total system memory of 640MB). If it does not boot, try again with the other 512MB module. This will help you identify a defective module that may be preventing the machine from booting.
I hope this helps & good luck!
Sep 28, 2012 | IBM ThinkPad T23 Notebook
I have a Dell Dimension 2400. I want to upgrade from 512mb of memory to 1GB. The manual says I have two memory connectors. Do I get the 1GB, or two 512mb to upgrade? Thank you for your response.
Yes, you can upgrade your system upto 2GB RAM, buy another 512MB RAM DDR 333Mhz and install it to empty slot of RAM, it will upgrade the RAM to 1 GB.
Hope it will help, if so do rate the solution
Good Luck
Dec 15, 2010 | Dell Dimension 2400 PC Desktop
Is it possible to install high desnsity memory RAM on a T42
The T42 can support up to 2 Gb of RAM.
The laptop comes with 512Mb of RAM under the keyboard and a spare memory slot on the bottom of the laptop.
To install 2Gb of RAM put 1Gb in the memory slot under the kerboard - need to remove the old RAM and put the other 1Gb in the memory on the bottom of the laptop
T42 Memory specs.
  • 64-bit Double Data Rate (DDR) non-parity SDRAM memory
  • PC2700 at 333MHz
  • Two 200 pin SO-DIMM memory slots, one slot is pre-populated with 256MB or 512MB, leaving one socket available
  • Supports up to two 1GB SDRAM SO DIMMs
  • Supports maximum memory up to 2GB
Sep 22, 2009 | IBM ThinkPad T42 Notebook
Have DIMM1 512MB RAM-what is highest avail RAM to update - Only 1 input for card
You need to check the specs of your laptop to see what is the maxium amount of RAM your laptop can support.
Although you can see one DIMM slot there may be another under the keyboard that already has a DIMM installed.
DIMM are avail in up to 4Gb most common 1Gb and 2Gb.
Jul 27, 2009 | Acer Aspire 4315 Notebook
ECS GREEN556E Laptop Memory
the manual is here
pages 87 & 88 show how to install
it uses' ddr1 memory up to 2gb max total in the laptop
0MB on board, 2 SO-DIMM slots, up to 2GB
Support DDR 266/333MHz system memory
Feb 04, 2009 | EliteGroup ECS G556 Notebook
Hello, I would like to upgrade lenovo ram memory. I have a RAM card. How can I place it there?
On the bottom of the laptop there are one or two panels, remove the screw securing the panel. The RAM module are behind one of the panels. If the memory module does not fit in the memory slot, then you have the wrong type and you need to purchase the correct memory type.
Your friendly computer shop can advise you on the correct type and speed of the memory module your laptop requires.
Jan 21, 2009 | Lenovo ThinkPad R51e Notebook
Upgrading ram
Hi reisrui, yes it is odd. (It's not the first time I have seen this.)
According to you're manual on page 6, under Specifications. The manual say's you can run up to a Max speed of PC3200 400MHz, 1GB in slot one. In slot 2 you can run a Max of 1GB of PC2700 333MHz in slot 2. Every motherboard I have come across that can run two different speeds of memory. The system will reduce the Max speed to the lower MHz memory speed. If you currently are using 512MB PC3200 400MHz in slot 1 & add 1GB of PC3200 400MHz into slot 2 for a total of 1.5GB of memory. The motherboard will ruduce the total memory over all speed to PC2700 333MHz. Motherboards alway run at the lower memory speed if two different speeds are presant.
I can’t be 100% sure of the 1GB of PC3200 400MHz into slot 2, will run at all! Or if it will be reduce down to 333MHz. I am sure you can run 2GB of PC2700 333MHz, 1GB of memory per slot in you're board for a total of 2GB.
If I can help you further, feel free to post.
Suggestions & comments welcomed.
May 27, 2008 | Asrock 775VM800 Motherboard
IBM ThinkPad T30 2366 Notebook Logo
690 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
