Question about Amana AGS1740BDW / AGS1740BDQ / AGS1740BDB Gas Kitchen Range
Amana AGS 745W surface burners electric ignitor does not work
The surface burners on my Amana gas range AGS745W no longer light automatically. Is this something I can fix myself?
SOURCE: Amana ARG7300w oven inop
It has a bad oven igniter.
Posted on Aug 27, 2007
SOURCE: Amana Range ARG7300W
yep open the oven door unplug the range remove the racks on the bottom liner should be some screws remove them then take the liner up and out if there is a flame spreadder on the burner tube remove it at the back of the burner bar should be the ignighter most new ones are generic you just cut the wires on the old one and splice the new one on with cerramic wire nuts make sure the wires are away from the burner bar reverse dissambily turn oven on should light within 30 secs if ya pluggedit back in
Posted on Dec 29, 2007
buffalonyman
  • 1865 Answers
SOURCE: MY AMANA OVEN DOES NOT WORK. THE TOP BURNERS
Possibly ignitor coil defective
Posted on Apr 16, 2009
  • 3 Answers
SOURCE: Igniter of Gas Burner does not ignite gas
Does your Amana range get very very hot on the exterior part mostly by the control panel?
Posted on Aug 21, 2009
jumptrout51
  • 3361 Answers
SOURCE: Amana gas oven not working
The ignitor may be too weak to open the gas valve. If you have a volt/ohm meter capable of reading AMPS you can hook up to a ignitor wire and turn the oven ON. If you read less than 3.5 amps replace the ignitor. If 3.5 amps or more are read,replace the gas valve.
Posted on Aug 30, 2009
Testimonial: "Thanks for the good info."
Can't seem to access Hotpoint Stove Pilot Light?
Your range uses electronic ignition, not pilot lights. For surface burners the igniter sparks when the gas valve is turned to the "light" position. All burners should spark when any gas valve is in the light position. For the oven the ignitor is also electric but does not spark but rather heats up or glows. What is the problem with your range?
Nov 30, 2014 | Hotpoint RGB745 Gas Kitchen Range
Surface ignitors dont work
The oven and burners have separate igniters. There may be a battery that needs to be replaced for the burner's igniter module.
Feb 16, 2012 | Amana ACS3350 Gas Kitchen Range
Hi there. there is no spark to ignite the gas in oven.
You will need to replace the spark module if you don't hear any clicking, or there is no spark present when trying to ignite the gas.
To test the Spark Module:
When properly operating, the spark module repeatedly produces a spark at the ignitor accompanied by a sharp snapping sound.
  1. Turn off gas and power supply to unit.
  2. Check wiring diagram to verify all terminals and wire connections are correct and tight with no cuts in the wiring.
  3. Prepare to measure voltage on spark module from terminal L to N.
  4. Turn power supply back on.
  5. Turn top burner to LITE position.
  6. If no voltage is present on the meter, this will indicate the electrical circuit is interrupted before the spark module
  7. If voltage is present, then check ignitor.
  8. If ignitors are ok; then replace spark module.
To access the Spark Module:
  1. Turn off electrical power and gas to the range.
  2. Disconnect gas and power from unit.
  3. Remove screws securing top surface burners.
  4. Remove surface burner and disconnect spark ignitor wire from surface burner.
  5. Raise and remove maintop from unit.
  6. Remove screws securing spark module bracket.
  7. Disconnect wire terminals from spark module.
  8. Replace and reassemble in reverse order.
May 18, 2011 | Amana Ovens
Oven takes to long to lite
If the oven is taking longer to light the oven ignitor is starting to go bad. Even tho it is glowing orange the ignitor is not sending the correct volts to the oven control valve to open properly. Change the oven ignitor and you will be good to go. Not an expensive repair but always be careful when working with gas because the ignitor must be aligned with the burner correctly to avoid flashback. Hope this helps.
May 31, 2010 | Amana ARGS7650SS Gas Kitchen Range
Aug 30, 2009 | Amana ARGS7650SS Gas Kitchen Range
Amana oven does not work
Check the oven glow bar ignitor. Replace it if it does not glow.
Jun 08, 2009 | Amana ARGS7650SS Gas Kitchen Range
Burner ignitor will not turn off after the burner lights Viking
replace the electrode that's the wire or pilot tip, it has a sensor built in, when it gets hot it stops automatically. if the electrode is between the front and rear burners, there are small holes on the burners going down on the side of the burner facing the ignition. they need to be clean. try a paper clip and insert the clip in side the holes.
Dec 14, 2008 | Viking VDSC365-6B Dual Fuel (Electric and...
Amana AGS1740BDW / AGS1740BDQ / AGS1740BDB Gas Kitchen Range Logo
71 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
