When powering up the desktop, it will not turn on, power button just blinks. The unit sat in the cold for 7 hours, so i warmed it sitting by the furnace, it worked! But once again, i removed the power from the wall and power button just blinks now.
  • 404 Answers
Freezing has nothing to do with pc not powering up actualy freezing makes it work faster! pc dont work when they're hot. so this is realy strange..there are many steps to go by to diagnose this and you have to be prepared to open the case and inspect there's no easy 123 solution
Posted on Mar 03, 2009
Leave it unpluged for a little bit
Display powers of with power up of AVC
how many blinks does the red light give in a row? This would be an error code?
The problem for 7 blinks would be an Interface board. Apparently there is a glitch in the interface board that sends signals to the television. Basically the glitch shorts out the board and the t.v wont turn on and you will see the power light blink 7 times pause then 7 more. You can replace the board with a new one and update the software on the new interface board.
If is isn't 7, let me know and I will help you out with this
Apr 26, 2008 | Sharp Aquos LC-37HV4U 37 in. LCD HDTV
Where is the fuse on a Dell Optiplex gx 620 PC
The computer is receiving electrical power, but an internal power problem may exist,Ensure that the processor power cable is securely connected to the system board,.It sounds like it may have had a power surge and may have burned something in your board.. You could try removing RAM unhooking everything hard drive cd drive un plug machine, hold power button till you see the amber light go out. reverse installing everything after it has sat for awhile and try to reboot
Jan 17, 2013 | Dell OptiPlex GX620 PC Desktop
How do I set the clock on my iLive I Pod/CD stereo?
SETTING THE CLOCK1. Press the Power Button to turn the unitoff.2. The Power Indicator Light will illuminate red, indicating that the unit isin Standby Mode.3. Press the Mem/Clk Adj Button.4. The Hour will begin to blink.5. Press the Skip/Tune Buttons to adjustthe hour.6. Press the Mem/Clk Adj Button to set thehour.7. The Minute will begin to blink.8. Press the Skip/Tune Buttons to adjustthe minute.9. Press the Mem/Clk Adj Button to set theminute, and finish setting the clock.
Feb 23, 2012 | Audio Players & Recorders
Just been given crock pot with 3 settings can you explain them no manual came with pot
It sure would help us to help you if you could get the model number off of the bottom of the unit. I can probably locate a user's manual with that information. Try this site to locate the manual: (my best guess without a model number)
Find the little blue print that says enter security code and then you can dounload the manual.
The settings should be OFF High 4 High 6, Low 8 Low 10 and warm.
1. Place food in stoneware according to recipe.
2. Plug in Smart-Pot™ slow cooker. The Power light will begin to flash
indicating that the unit is plugged in, but not turned on.
3. Push the Cook Time button to scroll through the timed cooking
options. Push once and the 4 hour light will illuminate, twice and the
6 hour light will come on, etc. Select the time based on the length of
time indicated in the recipe. Two time options are usually given. The 4
and 6 hour settings are the HIGH temperature setting and may be
used when you want your food done quicker. The 8 and 10 hour
settings correspond to the LOW temperature setting and is used for all
day cooking. In addition your Smart-Pot™ can be set to the Warm
Setting by scrolling through the timed cooking options until the warm
light illuminates.
NOTE: The Warm setting is for keeping already hot food warm. Do not use
the warm setting to cook or reheat food.
4. When the cooking time is completed, the Smart-Pot™ slow cooker will
automatically shift to the Warm setting and the Warm light will come
on. NOTE: We do not recommend using the Warm setting for more
than 4 hours.
5. To turn the Smart-Pot™ off push the OFF button. Unplug unit from the
wall outlet.
6. For other recipes that give a range of times, select the time closest
to the setting on your Smart-Pot™. For instance a recipe calling for
cooking time of 7 to 9 hours on LOW, set your Smart-Pot™ to 8 hours.
NOTE: If power goes off then power light will blink and settings must be
reset. If cook time is changed before the cycle is complete the time will
reset to the new setting.
Thanks for choosing FixYa,
Mar 04, 2011 | Rival 38601 Smart Pot 6-Quart
WS-55313 55in. Stored in cold garage fo two days will not power up in warm house. What next?
Leave it unplugged and let it sit for atleast 6 to 8 hours to become at room temp..Do not try to turn on anymore to where it could blow the bulb.After its sat that long atleast plug it in and enjoy..There is a protection relay in the tv to protect the bulb.Hope this helps you and have a great day
Dec 08, 2009 | Mitsubishi WS-55313 55" Rear Projection...
Hannstar HN199DP Monitor power button just blinks on wont come on
I've noticed this problem as well with mine. I noticed it does it mainly when the unit is cold, like less than 70 degrees F. A quick fix is to warm the unit by whatever means you possess. If the blinking is rhythmic, that may be the unit trying to communicate a problem, so check your connections, change the cords, clean any dust from the ducts.
May 17, 2009 | Hannstar I-Inc iF191DPB 19" LCD Monitor
Honeywell oil radiator
Press the *power button* once to start the heater on high power, continuous run. If left at this setting, the unit will run continuously on high power (1500 watts, 12.5 amps) and will not shut off until the unit is manually turned off.
Press the *power button* again, to change to low power, continuous run, (900 watts, 7.5 amps) and will not shut off until the unit is manually turned off.
Set temperature:
Press the temp/timer button until the temperature icon blinks. Use the up and down arrows to set the desired temperature.
The temperature icon will stop blinking and the current room temperature will reappear after the desired temperature is set.
The heater will turn off and on to achieve the desired temperature.
Set timer: (auto off)
Press the timer/timer button until the timer icon blinks. The hour display will appear. The auto off icon will also appear.
Use the up and down arrow buttons to set the heater operation time between 1 and 10 hours. This function will activate once the timer icon stops blinking. The heater will automatically turn off whn the times runs out.
Set timer: (auto on)
Press the temp/timer button until the timer icon blinks. The hour display will appear. The auto on icon will also appear.
Use the up and down arrow buttons to set the heater start time between 1 and 10 hours. This function will activate once the timer icon stops blinking.
The heater will automatically turn on when time expires.
Hope this helps!
Sep 24, 2007 | Honeywell /KAZ HOME ENVIRONME HZ-705 7Fin...
TV won't turn on
your dog sitting on the remote is unlikely to cause the problem, it is a coincidence. You need a television engineer to diagnose and fix the set.
Thread RCA TV power light flashes on off on off
RCA television blink codes Google Search
Nov 06, 2017 | RCA T19060GY 19 in. Combo
Computers & Internet Logo
69 people viewed this question
David Payne
David Payne
