Question about Zebra 110XiIIIPlus Label Printer
My 110xiIII Plus 600 dpi is printing a random line on each label. It can't be my printhead because the line moves from the left to right side of the label when I adjust the text/graphics positioning on the label. How can I get rid of the line???
4 Suggested Answers
  • 54 Answers
SOURCE: only printing 1/2 a label
recalibrate the printer in the set up.
Don't just do a quick cal from the front panel.
Make sure your driver is the correct dpi zebra driver, either zebra or my preferred seagull scientific.
by .5 of the label, do you mean width or heigth.
If it is heigth, check to make sure you are set for top of print correctly. Also you will have to back feed for a label that short.
Posted on Feb 24, 2009
  • 15 Answers
SOURCE: I have a zebra 110XiIII Plus 300 DPI printer that
I have seen that some label manufacturers have used inconsistent backing material on their label rolls. The opacity of the backing material was dramatically different in various sections of the roll. Because of this the label sensor cannot read the gap as well, and it spits out blank labels until it can detect the label gap again (or it issues the message "Paper out"...
Posted on Dec 15, 2009
SOURCE: We presently have a Zebra 110XiIII Plus Printer
@ gould804.
I have the same model printer and utilizing it the same way with text and bar code. My issue is not the the font but rather the text is not printing, only the bar code. Maybe we can contact and work with each other to resolve both of your issues. let me know?
Posted on Jan 29, 2010
Why datamax M class 4208 only prints on one side of the label?
When printing on less than full width media, the printer has a printhead-leveling cam to adjust the right side of the printhead
for even pressure distribution. To adjust the leveling cam:
1. With media loaded in the printer, print a label (press the
FEED + CANCEL buttons simultaneously) and
examine it..
2. While observing the printed labels, loosen the
Thumbscrew and move it to the left most position. (see
Example 1, below).
3. Next, move the Thumbscrew to the right until the
printed labels contain a complete, even image (see
Example 2). Tighten the Thumbscrew.
Apr 30, 2014 | Datamax I-4208 Thermal Label Printer
Zebra 105sl printer labels print too small
There are 3 different DPI Printheads for Zebra printers if you print a label set up for a 200 DPI Printhead on a printer with a 300 DPI Printhead installed it will be about 66% of the size.
Feb 13, 2014 | Zebra 105SL Thermal Label Printer
Horizontal alignment ok, but right half not printing.
One of two situations exists:
1. If the printing stops with clear stopping edge, then the PRINT WIDTH setting has been changed from the default full width setting of 104mm.
Check this by pressing MENU and then the NEXT button until you see a setting for MAX WIDTH. It should be set to full width of 104mm. Anything less will stop printing beyond whatever the setting is. Change it back to the full width setting.
2. If the printing stops by fading away to the right side, then that is caused by a pressure imbalance across the printhead. There is more pressure on the left side than the right side. There are two toggles that press down on the printhead and the pressure can be adjusted by moving the right toggle to the right so that more pressure falls on that side of the printhead.
Hope that helps !
Jul 20, 2010 | Zebra 140XiIII Plus Thermal Label Printer
Hi There How do you print a test page from the Zebra printer itself which shows print head condition etc We've used teh self test print but are lookign for somethign more detailed etc. many thanks
Printing the "PAUSE" test will print a nice black box that will show white lines or voids for any printhead elements that are not functioning. Turn the printer off, press and hold the PAUSE key while turning on the printer. After 5-6 seconds, let go of PAUSE and let the power up self test finish.
The test label will starting printing. To stop, press PAUSE. This is also usefull for seeing the "parallelism" of the printhead by looking at the lines that print at the begining of each label. Should be the same number of lines on the left as the on the right.
Easiest way to cancel the pattern is to cycle power.
Hope that helps !
May 04, 2010 | Zebra 140XiIII Plus Thermal Label Printer
After changing the print head and setting the Ohm resistance, the left side of the printed labels are faded. I adjusted both head pressure and slid them back and forth but I can't get it to print right....
It's very possible the printhead wasn't installed correctly. It's pretty easy to get it wrong, as there are two pins on the latched printhead bracket that have to fit into two holes on the printhead itself. You have to get the alignment of these pins and holes just perfect before you tighten the screw. You have to make sure the aluminum plate on the printhead is sitting flat against the printer's printhead bracket before you turn the screw on top of the bracket.
Sep 24, 2009 | Zebra 140XiIII Plus Thermal Label Printer
I have a zebra 110XiIII Plus 300 DPI printer that is randomly printing blank reciepts. It's connected to the computer via a USB cable. There is no rhyme or reason to the blank printing, just does it...
This is usually caused by the sensors being dirty or the printer needing calibrated. Blow off the media and ribbon sensors and also do a manual calibration. If it is still skipping after this then it is software related.
Jun 11, 2009 | Zebra 110Xi III Plus Thermal Printer
Out of paper error in Zebra 110XiIII plus
There is a small thumb screw under the paper guide that has an adjustable stop to hold the paper. If you load it correctly, you should have one on each side to guide the paper into the printer. Also, the machine has either a roller or a bar to hang the labels on, correct? The bar has an adjustable stop to keep the roll from moving around while you print. You may want to setup the media sensor about 1 cm from the left of the printer to make it less subject to this type of error. They come from the factory very close to the edge of the paper to allow for some card printers to work well out of the box. Most people use labels and this is not necessary. I hope I have given you some helpful information.
May 06, 2009 | Zebra 110Xi III Plus Thermal Printer
Only printing 1/2 a label
Feb 24, 2009 | Zebra 110Xi III Plus Thermal Printer
Labels enlarged
if they are diferent resolutions, ex. you change from 200 dpi to 300 dpi, you need to change something inside the printer like the gears (just reversing the platten roller gear and the the withe gera on the motor) and you are printing on 300 dpi with very small fontes.
Mar 11, 2008 | Zebra Z4Mplus Label Printer
Zebra 110XiIIIPlus Label Printer Logo
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
