Question about Kicker Solo-Baric L7 S15L72 Car Subwoofer
Kicker CVR 10" "stuck"
I have a 10" Kicker CVR that was bumping the other day at low and high volume. I was on a road trip and went over a couple bumps and it kicks on every once in a great while for no apparent reason. I checked and wiring is still in tact along with all of my fuses. If I push on the sub while music is playing it kicks on for a bit then goes back off if volume gets turned low or whenever there is a long pause. I don't know what it could be...anyone have any ideas?
  • 77 Answers
Sounds like the wiring in the speaker from the factory is shoty. rare but does happen. if you bought this from a retailer and have all of your warranty information id send it back and let em fix it
Posted on Mar 04, 2009
What's the best way to wire a 12 inch kicker CVR
Ok, first you need to have at least ten gauge wire cause the amp needs agility of juice. Next you want to find a good ground to frame of the car (if its wrong you'll hear road noise through speaker.) Next look on the fire wall and find the terminal that has other wire coming to it (one from positive to the amplifier on battery the rest out top other you want to put an inline fuse to amp.and have ground write other side of the cart than the power. run write to amp then to your speaker I believe I made it is simple for you as possible good luck
Dec 07, 2011 | Kicker Car Audio & Video
I have a pair of kicker cvr 124 with a kole 1500 watt amp that is bridged to the woofers. the amp is 385 rms at 2 ohms where should the gain be to get the most power without distortion.
When setting your gain you want to set the gain high usually between 75% to 95%. if the gain is low than turning up the volume on your radio will only amplify the distortion coming from the under powered head unit. By turning up the gain you are maximizing the signal that is amplified coming from your head unit
Mar 20, 2011 | Kicker Car Audio & Video
Kicker cvr 12 sounds clangy at high volume. its on the right speaker. seems to go away when you push on the back of the box
Hmmm... well there could be an air leak in your box, something hitting the suspension inside the box like a broken tensil lead or most likely you have a voice coil that's getting ready to **** out. I've heard this many many times and usually that's what it is but I've been suprised by a broken tinsel lead a time or two.
May 27, 2010 | Kicker CVR12 Car Subwoofer
Box size
http://kicker.com/Product_Manuals/93/104 , look at the tech manual, it will give you dimensions of sealed or vented and it will give you a couple of box ideas.
Feb 21, 2009 | Jl Audio CVR12 Kicker 12" CompVR Series...
Kicker zx1000 only plays at low volume
how high did you turn the gain up and or the freq. mode most soun good at 90to 120hz. any higher some amps trip, and your speakers may not be able to handel the amp.
Jul 20, 2008 | Kicker ZX10001 Car Audio Amplifier
10 inch cvr kickers
Option 1 (series/parallel) = 1 ohm load
Voice coils wired in series, speakers wired in parallel
Recommended Amplifier: Stable at 1 ohm mono 4_2ohm_dvc_1ohm.gif
Dec 17, 2007 | Kicker CVR12 Car Subwoofer
Kicker Solo-Baric L7 S15L72 Car Subwoofer Logo
179 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
