Question about Encore ENUWI-G2 802.11G WIRELESS USB 2.0 ADAPTER (54 MBPS)
I can not connect to the internet but it still has strong signal strength. It will only connect to the internet when I am right next to the router. Why is this happening and what should I do?
    Scholar:
  • 67 Answers
One thing to keep in mind is that there are several different router/adapter models, types, and signal strengths. If your house/apartment is older, it may have poor wire insulation. This would create large electromagnetic interference for your wireless signal. This can also happen with large appliances such as a refridgerator or generator. Wireless also has diminished returns when passing through concrete or walls made with thick/heavy material.
You may try moving the router to a different, more central portion of your residence to see if the signal improves in all areas. Try to determine which direction, from the router, it tends to have the lowest signal strength and determine what may be causing the loss of signal strength.
Aside from that, if possible test with a different router/wireless adapter. You can accomplish this by having a friend visit you with their laptop or visiting a friend's wireless network and seeing if you have the same problem. The later of that advice applies to wireless hot spots like Starbucks or McDonalds/Dairy Queen.
Posted on Mar 04, 2009
Cant get wifi unless I am a couple of inches from router. All other wifi devices work perfectly. I even downloaded the latest driver directly from Intel and problem still exists.
Having a wireless Internet signal in your home allows multiple devices to use the same Internet connection without having to run lengths of Ethernet cable to each device. Given that the wireless network is transmitted over the air, the consistency of your Internet connection depends on the strength of the wireless signal. If wireless signal strength is not strong enough to give you a consistent Internet connection, there are a few simple steps for finding the problem and improving your signal strength.
Reset all devices. The majority of Internet issues, including poor wireless signal strength, are very often solved by a simple power cycle of all the devices in the network. Locate the power cords of both your modem and your wireless router and remove them (if you use a modem/router combination, simply unplug the power to that device). Leave them unplugged for a full 30 seconds, plug them back in and restart your computer. When your computer fully reboots, check your wireless signal strength to see if it has improved. If it has not, further troubleshooting is required. Move your computer closer to your router, or your router closer to your computer. Wireless routers do not have unlimited range. One reason your computer may be getting a weak signal strength from your wireless network could be because your computer is simply outside of the router's range. Typically, ISPs (Internet Service Providers) will install your modem in one specific location in the house and the modem will not work at other locations, so moving the modem or modem/router combination may not be a possibility. If this is the case, you may need to move the computer to a location that is within the range of the wireless router's broadcast. If you still get poor signal strength, your router may be experiencing a malfunction. Contact the technical support department of your router manufacturer. Router malfunctions often are not the result of a bad or broken router, but of something much simpler, such as the router's needing a firmware upgrade or an incorrect setting on the router's internal setup. If your router manufacturer is unable to improve your wireless signal strength, it may be time to purchase a new router. Purchase a new router. Wireless routers are priced in part based on how widely their wireless signal broadcasts (in other words, the more expensive the router you buy, the larger a wireless signal the router will broadcast). Included in the packaging of each wireless router is the approximated range, in square footage, of that router's wireless network. A good rule of thumb is to know the square footage of your house and buy a router that can accommodate that square footage. That way, as long as the router is functioning properly, you will have strong wireless signal strength throughout your entire home.
Mar 01, 2013 | Samsung 19628 NP300V5A-A0AUS NP300V5AI
Poor signal with WiFi on my zeepad
Reset all devices. The majority of Internet issues, including poor wireless signal strength, are very often solved by a simple power cycle of all the devices in the network. Locate the power cords of both your modem and your wireless router and remove them (if you use a modem/router combination, simply unplug the power to that device). Leave them unplugged for a full 30 seconds, plug them back in and restart your computer. When your computer fully reboots, check your wireless signal strength to see if it has improved. If it has not, further troubleshooting is required. Move your computer closer to your router, or your router closer to your computer. Wireless routers do not have unlimited range. One reason your computer may be getting a weak signal strength from your wireless network could be because your computer is simply outside of the router's range. Typically, ISPs (Internet Service Providers) will install your modem in one specific location in the house and the modem will not work at other locations, so moving the modem or modem/router combination may not be a possibility. If this is the case, you may need to move the computer to a location that is within the range of the wireless router's broadcast. If you still get poor signal strength, your router may be experiencing a malfunction. Contact the technical support department of your router manufacturer. Router malfunctions often are not the result of a bad or broken router, but of something much simpler, such as the router's needing a firmware upgrade or an incorrect setting on the router's internal setup. If your router manufacturer is unable to improve your wireless signal strength, it may be time to purchase a new router. Purchase a new router. Wireless routers are priced in part based on how widely their wireless signal broadcasts (in other words, the more expensive the router you buy, the larger a wireless signal the router will broadcast). Included in the packaging of each wireless router is the approximated range, in square footage, of that router's wireless network. A good rule of thumb is to know the square footage of your house and buy a router that can accommodate that square footage. That way, as long as the router is functioning properly, you will have strong wireless signal strength throughout your entire home. Hope this helps.
b>
Dec 13, 2012 | Computers & Internet
Router gives strong and weak signal in same place
If you think that your router signal is weak then you can follow the given points:
->Router positioning has an impact on the strength of a wireless signal. Brick walls and metal objects such as radiators, refrigerators and file cabinets can weaken a signal.
->Change the WiFi Channel
->Update firmware or drivers
->Reduce wireless interference
If you need any technical help on wireless router then you can reach at http://www.vtechsquad.com/
Nov 14, 2012 | Vizio Xwr100 Dual-band Hd Wireless...
I have the router right by my PC, it appears connected but no signal strength at all (no bars) what is wrong?
try changing the wireless channel on the router and see if that makes any difference.
Open the setup page of the router.
Go to wireless tan and change the standard channel to 11. save the settings.
You can also try updating the drivers of the wireless adapter on your computer.
If your router is too old then you must upgrade the firmware on the router.
See how to upgrade Linksys router firmware
Mar 21, 2012 | Linksys Wireless-G Broadband Router
My touch hd could not connect to my home wifi although the connection is visible/detectied.
Even though it is visible and detected the signal strength may not be strong enough to establish a connection. Various factors affect connecting a device to the internet with a WiFi connection, including overall signal strength (G Routers are the weakest), distance from the wireless router to the console and obstacles such as walls and ceilings that interfere with the signal. If you're using a G router and you have your device is too far away or, has obstacles in the way, it will not connect. You should use an N-Router if there is a significant distance between the console and/or there are obstacles. Try connecting right next to the router and see what happens. Also, make sure you are putting in your router's WEP key in correctly.
May 13, 2011 | Computers & Internet
I have just purchased a belkin enhanced wireless usb adapter N 150, i have managed to install the software and and connect to my router, the signal strength is strong, but when clicking on to internet...
Take an Ethernet cable, and connect one of the LAN ports on the router to the network-port on your computer. If you cannot get Internet access, then it is the router that is the problem, namely, that the 'WAN' side of the router has not connected to the Internet.
Oct 19, 2010 | Belkin (F5D7230-4) Router (587009)
It seems that the signal is strong next to the router, but drops to 1 bar within 30 feet away? What is the most likely solution.
Routers generally have a strong signal for up to 10 meters. However no obstacles should be in the way. 30 feets is about 10 meters so the router is loosing its signal strength. If you would like to extend the strength of your router you can buy a range expander. This device acts as a repeater of the signal so from 10 meters you can go to 15 or 20 meters.
Mar 08, 2010 | Hawking Hi-Gain 802.11g MIMO Wireless...
When I go into other rooms I can't connect to router
How is the signal strength? Check and make sure the antennas are not loose. Is your house the old style concrete? Sometimes thick block or concrete walls are tough for the wireless signal to get through. They do make larger antennas or signal boosters for wireless routers. You may need to install one of these to boost signal strength. Also is it wireless B,G,or N? Wireless B has a very weak signal while wireless N has a very strong signal. Sometimes the router settings can be changed to adjust the signal strength and may be set too low also.
Sep 05, 2009 | Linksys Wireless-G WRT54G Router
Connecting to internet
i am connected and signal strength is strong but i still cannot get on the interned (time-warner cable)
"dsl server error"
Aug 06, 2008 | Arris Wireless G Broadband Router (wr850g)
Poor signal strength on wireless router? ?
k login to the w/l router and change the channels to 11>or 1 use always use these only and delete all teh temp files and delete cookies and clear history and check with antena which is straight>and reboot the router and laptop>and rate me solved if its help full
Oct 30, 2007 | Belkin (F5D6230-3) Wireless Router
Encore ENUWI-G2 802.11G WIRELESS USB 2.0 ADAPTER (54 MBPS) Logo
460 people viewed this question
Top Encore Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
Are you an Encore Computer and Internet Expert? Answer questions, earn points and help others
